Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a30dd424-da0c-4ddb-9ad7-7c9a15102428 rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: Dell product: Inspiron 3501 v: N/A
Mobo: Dell model: 0MF26F v: A00 serial: <superuser required> UEFI: Dell
v: 1.19.0 date: 09/06/2022
ID-1: BAT0 charge: 32.4 Wh (100.0%) condition: 32.4/42.0 Wh (77.2%)
volts: 13.0 min: 11.4 model: SMP DELL VM73283 type: Li-poly serial: <filter>
status: full
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1729 high: 2400 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 646 2: 2400 3: 2400
4: 2400 5: 401 6: 792 7: 2400 8: 2400 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Dell driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d16
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0c45:671e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.5 with: Xwayland v: 22.1.6
Monitor-1: eDP-1 model: AU Optronics 0x23ed built: 2017 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
chip-ID: 0cf3:e009 class-ID: e001
address: <filter>
Local Storage: total: 232.89 GiB used: 32.43 GiB (13.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 250GB SSD
type: SSD serial: <filter> rev: 0BB3 scheme: GPT
used: 32.43 GiB (13.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.49 GiB used: 752.2 MiB (9.8%)
System Temperatures: cpu: 66.0 C mobo: 52.0 C
Fan Speeds (RPM): cpu: 4735
Processes: 290 Uptime: 23m wakeups: 8555 Memory: 7.49 GiB
used: 3.15 GiB (42.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1472
libs: 475 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.10-1):
System install date: 2022-12-18
Last full system update: 2022-12-18
Problem:
I've been running CSGO on native steam without any lag but after i changed from gaming edition to normal dragonized edition I've been facing extreme fps drop and stutters in the game. Game settings are all kept to the lowest possible from the game settings.
