Hello people first time here.
I just re-installed garuda cause i run into some troubles and after to do so I just installed the usual thing to play some CS:GO like GPU drivers (NVIDIA in my case), Steam and CS:GO.
So my problem starts when i try to open CS:GO right after starting the game an black fullscreen opens for like 10 seconds the audio stops after 4-5 seconds and keep like that till the crash
Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=6cc4deca-f8f3-4fdf-ae70-a121e32f8448 rw rootflags=subvol=@
resume=UUID=87a71efb-cf98-4712-bff1-18403784ccc1 loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: MAG B560 TORPEDO (MS-7D15) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.80
date: 10/31/2022
Info: model: 11th Gen Intel Core i5-11600K bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x58
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4900 scaling:
5: 801 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 93888
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: ZOTAC driver: nvidia
v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2482 class-ID: 0300
s-diag: 610mm (24")
Monitor-1: DP-0 res: 1920x1080 hz: 144 dpi: 93
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX 3070
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Kingston HyperX Cloud Core Wireless
lanes: 1 mode: 1.1 bus-ID: 1-3.2:4 chip-ID: 0951:173f class-ID: 0300
API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Device-3: ASUSTek ROG GLADIUS III WIRELESS driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.4:8
chip-ID: 0b05:197f class-ID: 0300
Hardware-1: Intel Device driver: N/A v: N/A port: 5020 bus-ID: 00:17.0
chip-ID: 8086:43de rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 102.21 GiB (11.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z44106 temp: 38.9 C
ID-1: / raw-size: 914.16 GiB size: 914.16 GiB (100.00%)
used: 102.21 GiB (11.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 914.16 GiB size: 914.16 GiB (100.00%)
ID-4: /var/log raw-size: 914.16 GiB size: 914.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.16 GiB size: 914.16 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.05 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 52 C
Processes: 279 Uptime: 58m wakeups: 0 Memory: available: 15.5 GiB
used: 6.42 GiB (41.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1219
libs: 329 tools: octopi,paru pm: flatpak pkgs: 0 Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2023-07-09
Last full system update: 2023-07-11
Things that I tried:
Use different start options like -vulkan -opengl(used sepparetly)
Run CS:GO with proton
Update and install possible missing drivers
