Hello,
after a short while when playing Crusader Kings III my pc will crash.
Any solutions?
This is the output of journal -b -1 -e:
mai 13 17:17:39 win plasmashell[459431]: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(459431)
mai 13 17:17:39 win plasmashell[459432]: Installing breakpad exception handler for appid(gameoverlayui)/version(20230428183304)/tid(459432)
mai 13 17:17:39 win plasmashell[459432]: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(459432)
mai 13 17:17:39 win plasmashell[459433]: Installing breakpad exception handler for appid(gameoverlayui)/version(20230428183304)/tid(459433)
mai 13 17:17:39 win plasmashell[459433]: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(459433)
mai 13 17:17:39 win plasmashell[459434]: Installing breakpad exception handler for appid(gameoverlayui)/version(20230428183304)/tid(459434)
mai 13 17:17:39 win plasmashell[459434]: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(459434)
mai 13 17:17:39 win plasmashell[459435]: Installing breakpad exception handler for appid(gameoverlayui)/version(20230428183304)/tid(459435)
mai 13 17:17:39 win plasmashell[459435]: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(459435)
mai 13 17:17:44 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 457164 -- gameoverlayui
mai 13 17:17:44 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459199 -- gameoverlayui
mai 13 17:17:54 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459199 -- gameoverlayui
mai 13 17:17:54 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459431 -- gameoverlayui
mai 13 17:18:04 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459431 -- gameoverlayui
mai 13 17:18:04 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459432 -- gameoverlayui
mai 13 17:18:14 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459432 -- gameoverlayui
mai 13 17:18:14 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459433 -- gameoverlayui
mai 13 17:18:24 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459433 -- gameoverlayui
mai 13 17:18:24 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459434 -- gameoverlayui
mai 13 17:18:34 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459434 -- gameoverlayui
mai 13 17:18:34 win plasmashell[450345]: src/steamexe/main.cpp (255) : Assertion Failed: reaping pid: 459435 -- gameoverlayui
mai 13 17:19:35 win kernel: [UFW BLOCK] IN=enp39s0 OUT= MAC=01:00:5e:00:00:01:f0:81:75:23:29:59:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x0>
mai 13 17:21:40 win kernel: [UFW BLOCK] IN=enp39s0 OUT= MAC=01:00:5e:00:00:01:f0:81:75:23:29:59:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x0>
mai 13 17:23:45 win kernel: [UFW BLOCK] IN=enp39s0 OUT= MAC=01:00:5e:00:00:01:f0:81:75:23:29:59:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x0>
mai 13 17:25:50 win kernel: [UFW BLOCK] IN=enp39s0 OUT= MAC=01:00:5e:00:00:01:f0:81:75:23:29:59:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x0>
mai 13 17:27:20 win kernel: snd_hda_intel 0000:2f:00.1: Unable to change power state from D3hot to D0, device inaccessible
mai 13 17:27:20 win kernel: snd_hda_intel 0000:2f:00.1: CORB reset timeout#2, CORBRP = 65535
Kernel: 6.3.2-AMD-znver2 arch: x86_64 bits: 64 compiler: gcc
v: 13.1.1 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver2
root=UUID=2f466eca-95cf-416b-bade-e69db71ffa5e rw
[email protected] quiet quiet rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 splash ibt=off
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI
(MS-7C37) v: 1.0 serial: <superuser required> UEFI: American
Megatrends LLC. v: 1.K0 date: 02/28/2023
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0
microcode: 0x8701030
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled
cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3871 high: 4490 min/max: 2200/4672
boost: enabled scaling: driver: acpi-cpufreq governor: performance
cores: 1: 3800 2: 3612 3: 3800 4: 4388 5: 4490 6: 4243 7: 3606
8: 3602 9: 3602 10: 3870 11: 3605 12: 3800 13: 3800 14: 3800
15: 3800 16: 3982 17: 4062 18: 3869 19: 3759 20: 3607 21: 3953
22: 3800 23: 3800 24: 4257 bogomips: 182480
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20
pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 2f:00.0 chip-ID: 1002:687f
compositor: kwin_x11 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 2560x1440 s-dpi: 96
s-size: 677x381mm (26.65x15.00") s-diag: 777mm (30.58")
Monitor-1: DP-3 mapped: DisplayPort-2 model: Samsung C32HG7x
serial: <filter> built: 2034 res: 2560x1440 hz: 144 dpi: 93
gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX Vega
(vega10 LLVM 15.0.7 DRM 3.52 6.3.2-AMD-znver2) direct-render: Yes
Device-1: AMD Vega 10 HDMI Audio [Radeon 56/64]
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:aaf8 class-ID: 0403
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS GameDAC
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4.2:4
chip-ID: 1038:1282 class-ID: 0300 serial: <filter>
API: ALSA v: k6.3.2-AMD-znver2 status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.70 status: active with:
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 29:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp41s0 state: down mac: <filter>
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3
chip-ID: 8087:0aa7 class-ID: e001
address: <filter>
Local Storage: total: 2.95 TiB used: 2.56 TiB (86.7%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: 2B2QEXM7 temp: 46.9 C
model: WD20EARS-00J2GB0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0004
used: 641.03 GiB (68.8%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
used: 29.6 MiB (9.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 44.4 C mobo: N/A gpu: amdgpu temp: 30.0 C
mem: 28.0 C
Processes: 461 Uptime: 10m wakeups: 0 Memory: available: 31.28 GiB
used: 4.47 GiB (14.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages:
pm: pacman pkgs: 1907 libs: 556 tools: pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2023-03-22
Last full system update: 2023-05-13
Failed units: cpupower-gui.service
