I have no clue when this started happening exactly, but I think it must have been within the last few weeks or so, so not sure if it is something related to a kernel update or pipewire etc. I have tried different kernels (bore, zen and lts) and different browsers too. Unfortunately, though, YouTube videos keep getting these random popping and crackling sounds like milliseconds of pauses and stutters in the audio and I'm not sure what to do as I'm unfamiliar with audio troubleshooting and a lot of what Google suggested seemed unrelated to my problem. Any tips would be great thanks.
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: root=UUID=95b636ca-42a5-47b4-9b7a-038581af6cdf rw
[email protected] quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=41193397-191d-45b5-8c2b-405cf71e73b2 loglevel=3
[email protected]\boot\initramfs-linux-zen.img
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: X510UA v: 1.0
Mobo: ASUSTeK model: X510UA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X510UA.312 date: 04/29/2020
ID-1: BAT0 charge: 22.7 Wh (78.0%) condition: 29.1/42.1 Wh (69.2%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 468
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xB4
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 657 high: 767 min/max: 400/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 767 2: 602 3: 624 4: 637
bogomips: 23199
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916
Device-2: IMC Networks VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 13d3:5a07 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
alternate: fbdev,intel,vesa gpu: i915 display-ID: 0
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.0.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-8:3 chip-ID: 8087:0a2b class-ID: e001
address: <filter>
Local Storage: total: 931.52 GiB used: 245.17 GiB (26.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO M.2 500GB
ID-1: / raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
used: 147.88 GiB (33.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 47.9 MiB (16.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-4: /var/log raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.51 GiB used: 2.8 MiB (0.0%)
ID-2: swap-2 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 68.0 C pch: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3900
Processes: 276 Uptime: 5m wakeups: 1 Memory: 15.51 GiB
used: 3.97 GiB (25.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1573 lib: 395 Shell: fish
v: 3.4.1 running-in: yakuake inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-01
Last full system update: 2022-05-10
Failed units: systemd-sysctl.service
