Maybe another issue with firmware updates.
I have been wondering for 1-2 days why my laptop Lenovo T560 is so slow. Now I realized that the maximum CPU frequency was somehow limited to 800mhz.
After some reading on the internet I added intel_pstate=disable to the kernel parameter and after a reboot the cpu clocks normally again.
root=UUID=d888e546-a95a-413a-9e0e-acb0cef2ded1 rw rootflags=subvol=@
quiet loglevel=3 mitigations=off intel_pstate=disable ibt=off
Type: Laptop System: LENOVO product: 20FH0023GE v: ThinkPad T560
Mobo: LENOVO model: 20FH0023GE v: SDK0J40705 WIN
part-nu: LENOVO_MT_20FH_BU_Think_FM_ThinkPad T560
uuid: <superuser required> UEFI: LENOVO v: N1KET58W (1.45 )
date: 12/12/2022
ID-1: BAT0 charge: 28.9 Wh (73.0%) condition: 39.6/44.5 Wh (89.0%)
volts: 11.9 min: 11.4 model: SONY 45N1743 type: Li-poly serial: <filter>
status: not charging
Info: model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2601 min/max: 400/2801 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2601 2: 2601 3: 2601
4: 2601 bogomips: 22399
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: HDMI-A-2 off: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Monitor-1: HDMI-A-2 model: Idek Iiyama PL3271Q serial: <filter>
built: 2023 res: mode: 2560x1440 hz: 60 scale: 80% (0.8) to: 3200x1800
dpi: 93 gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: eDP-1 model: BOE Display 0x0630 built: 2015 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
device-ID: 8086:1916 memory: 15.11 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 520 (SKL GT2) driver: mesa intel v: 25.1.4-arch1.1
device-ID: 8086:1916 surfaces: N/A device: 1 type: cpu name: llvmpipe
de: kscreen-console,kscreen-doctor gpu: gputop, intel_gpu_top, lsgpu
API: ALSA v: k6.15.3-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 232.89 GiB used: 40.3 GiB (17.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 250GB
ID-1: / raw-size: 205 GiB size: 205 GiB (100.00%) used: 40.3 GiB (19.7%)
used: 616 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 205 GiB size: 205 GiB (100.00%)
used: 40.3 GiB (19.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 205 GiB size: 205 GiB (100.00%)
ID-5: /var/tmp raw-size: 205 GiB size: 205 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.0 C pch: 47.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 3184
Memory: total: 16 GiB available: 15.47 GiB used: 3.81 GiB (24.7%)
Processes: 248 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1469 libs: 411 tools: pacseek,paru Compilers:
gcc: 15.1.1 Shell: garuda-inxi default: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.38
System install date: 2025-05-31
Last full system update: 2025-06-26
