Hi,
I've just converted windows to garuda linux dragonize version and installed it with single boot.
I tried to connect my usb adapter but it didn't shows/recognize any network (No available connections).
I installed its driver through my CD rom (windows installation).
then, i opened up Garuda Network Assistant and clicked Windows drivers tab but it tells me theres no Ndiswrapper. here's the screenshot ;
No picture from terminal outputs.
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
Images can be read worse, are not searchable and copyable for further search.
Should the helpers have to guess everything or laboriously type it in themselves?
Refresh your mirrorlist, garuda-welcome - garuda assistant / Maintenance
error: failed retrieving file 'chaotic-aur.db' from repo.kitsuna.net : Could not resolve host: repo.kitsuna.net
error: failed retrieving file 'chaotic-aur.db' from chaotic.tn.dedyn.io : Could not resolve host: chaotic.tn.dedyn.io
error: failed retrieving file 'chaotic-aur.db' from repo.jkanetwork.com : Could not resolve host: repo.jkanetwork.com
error: failed retrieving file 'chaotic-aur.db' from chaotic.bangl.de : Could not resolve host: chaotic.bangl.de
error: failed retrieving file 'chaotic-aur.db' from mirror.maakpain.kro.kr : Could not resolve host: mirror.maakpain.kro.kr
error: failed to update chaotic-aur (invalid url for server)
error: failed to synchronize all databases
Ndiswrapper is basically only for ancient wifi adapters. Anything produced in the last 10 years shouldn't really need to use an ancient Windows XP driver.
IMO If you need to use Ndiswrapper it's time to buy a new wifi dongle. I haven't had to us Ndiswrapper for more than a dozen years (I'd guess).
We need to know the manufacturers chip ID used in your wifi dongle. The commands below will help us identify your hardware so that we can assist you. Without it, there is really no way to help you.
Please post the outputs of these commands:
lsusb
inxi -Fxxxza
Run those commands from the live boot disk and post them to the forum. If your wifi is not working in the live environment then save the commands output to a text file on another flashdrive to post later.
Is your wifi working on the live disk?
The easiest method to upload the outputs is to either use an Ethernet connection or use "Android USB phone tethering". Search the quoted text online if you don't know what that is.
Please do not post pictures of text outputs. I am currently only using a cell and reading a pic is very difficult on my phone with a small screen and poor vision.
Please post all logs and terminal commands as text only. Please use three of these symbols ~ before and after any terminal outputs that you post. This ensures that the output is formatted correctly in a proper human readable code block on the forum.
Example:
your terminal output here
Welcome to Garuda, looking forward to helping you once the outputs are posted.
//lsusb//
Bus 002 Device 003: ID 1bcf:2805 Sunplus Innovation Technology Inc. HP HD Webcam [Fixed]
Bus 002 Device 007: ID 2717:ff48 Xiaomi Inc. Mi/Redmi series (MTP + ADB)
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 0bda:b812 Realtek Semiconductor Corp. RTL88x2bu [AC1200 Techkey]
Bus 003 Device 002: ID 046d:c53f Logitech, Inc. USB Receiver
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 138a:003c Validity Sensors, Inc. VFS471 Fingerprint Reader
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
