Hello, I tried to upgrade packages and I get this message:
error: systemd-oomd-defaults: signature from "Eduard Tolosa (Chaotic AUR Signing Key) <[email protected]>" is unknown trust
:: File /var/cache/pacman/pkg/systemd-oomd-defaults-249.7-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
Also before that I already added Eduard Tolosa's key....
So, if I say "yes" it gives another error:
error: failed to commit transaction (invalid or corrupted package)
I'm not sure what to do exactly. Thanks
System Info:
Kernel: 5.16.3-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ce118470-4f53-49b9-b500-9ddd71f75162 rw [email protected]
Desktop: i3 4.20.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Desktop Mobo: Micro-Star model: B450-A PRO (MS-7B86) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.21
date: 09/20/2018
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3093 high: 3892 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3818 2: 3892
3: 2244 4: 2426 5: 2379 6: 2265 7: 3050 8: 3415 9: 2804 10: 3056 11: 3890
12: 3884 bogomips: 81589
STIBP: disabled, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 1c:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Device-1: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1c:00.1 chip-ID: 10de:0fb9
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1e:00.3 chip-ID: 1022:1457
Sound Server-1: ALSA v: k5.16.3-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.44 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 18:00.0
IF: enp24s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-c38dd7569bf8 state: down mac: <filter>
IF-ID-2: br-c473b5e2278b state: down mac: <filter>
IF-ID-3: br-c573e5d4dcb3 state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
Local Storage: total: 1.59 TiB used: 117.55 GiB (7.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z42105
temp: 33.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A02 scheme: GPT
ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 40.56 GiB (20.8%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
used: 604 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 254.16 GiB size: 254.16 GiB (100.00%)
used: 19.09 GiB (7.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.36 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 30 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 360 Uptime: 6h 41m wakeups: 0 Memory: 31.36 GiB
used: 6.68 GiB (21.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1572 pacman: 1560 lib: 337 flatpak: 6 snap: 6
Shell: Zsh v: 5.8 running-in: alacritty inxi: 3.3.12
Garuda:
System install date: 2021-10-07
Last full system update: 2022-01-29
Is partially upgraded: Yes
Using TLP: No
