I was updating my system but I was stuck at this :
error: wlroots-git: signature from "Pedro Henrique Lara Campos <root@pedrohlc.com>" is invalid
:: File /var/cache/pacman/pkg/wlroots-git-0.17.0.r6548.22b6581a1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: failed to commit transaction (invalid or corrupted package (PGP signature))
garuda-inxi :
╭─ankur@ankur in ~ as 🧙 took 42s
[🔴] × garuda-inxi
Kernel: 6.4.10-273-tkg-linux-tkg-pds arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc available: hpet,acpi_pm
parameters: intel_pstate=passive split_lock_detect=off
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds
root=UUID=4db91e48-f647-49c5-9e3e-ea266109ffe7 rw rootflags=subvol=@
Type: Laptop System: Dell product: Inspiron 7570 v: N/A
Mobo: Dell model: 06K08K v: A00 serial: <superuser required> UEFI: Dell
v: 1.25.0 date: 07/13/2022
ID-1: BAT0 charge: 9.5 Wh (100.0%) condition: 9.5/42.0 Wh (22.7%)
volts: 12.7 min: 11.4 model: Samsung SDI DELL CYMGM79 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1305 high: 3544 min/max: 400/4000 scaling:
driver: intel_cpufreq governor: ondemand cores: 1: 400 2: 400 3: 2400 4: 400
5: 3544 6: 400 7: 2400 8: 500 bogomips: 32026
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nvidia
v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134d
class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2
chip-ID: 1bcf:28c1 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: Hyprland driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: BOE Display 0x06b4 built: 2016 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 scale: 1 size: 344x194mm (13.54x7.64")
API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
API: ALSA v: k6.4.10-273-tkg-linux-tkg-pds status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2a
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 20.31 GiB (1.7%)
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: L003 scheme: GPT
used: 20.31 GiB (2.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
zswap: no
ID-1: swap-1 type: zram size: 7.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.0 C pch: 52.5 C mobo: N/A
Processes: 247 Uptime: 1h 4m wakeups: 23014 Memory: total: 8 GiB
available: 7.5 GiB used: 2.19 GiB (29.1%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1575 libs: 449 tools: pamac,paru Shell: fish
v: 3.6.1 running-in: foot inxi: 3.3.29
System install date: 2023-08-14
Last full system update: 2023-08-17
Is partially upgraded: Yes
╭─ankur@ankur in ~ took 1s
╰─λ
What I tried :
(obviously this works everytime, but not this time!!!)
Searched almost all threads for corrupted PGP keys but all of them had same solution which is the link pasted above .
