This started today when i attempted to install the most recent updates to the kernel.
current stable: 6.4.4-AMD-znver2
when i attempted to update to kernel 6.4.v.6-1, it breaks corectrl, and then will not allow corectrl to adjust the timings. once i restored (thanks again snapper) i'm back to where i started.
i do not see any updates to corectrl.
New to garuda, just come from pop_os! 22.04 with Xanmod or Liquorix kernels'.
what do?
Kernel: 6.4.4-AMD-znver2 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver2
root=UUID=58726e34-1cc3-481a-9542-e505a8de20c3 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 5102
date: 05/31/2023
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2220 high: 2617 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 2200 5: 2187 6: 2617 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2116 14: 2200 15: 2200 16: 2200 bogomips: 115240
protection
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: DP-2 empty: DP-1, DVI-D-1, HDMI-A-1, HDMI-A-2
bus-ID: 09:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 59.0 C
Monitor-1: DP-2 mapped: DisplayPort-1 model: Samsung C27F398
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon RX 580 Series
(polaris10 LLVM 15.0.7 DRM 3.52 6.4.4-AMD-znver2) direct-render: Yes
lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:aaf0 class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.4.4-AMD-znver2 status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 0a5c:21e8
Local Storage: total: 12.26 TiB used: 117.03 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 43.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HUS724040ALE641
tech: HDD rpm: 7200 serial: <filter> fw-rev: A5F0
ID-3: /dev/sdb maj-min: 8:16 vendor: PNY model: CS900 240GB SSD
tech: SSD serial: <filter> fw-rev: 0J13 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: PNY model: CS900 240GB SSD
tech: SSD serial: <filter> fw-rev: 0J13 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Hitachi model: HUS724040ALE641
tech: HDD rpm: 7200 serial: <filter> fw-rev: A5F0 scheme: MBR
ID-6: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD40NMZW-11GX6S1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 4005 scheme: GPT
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 117.03 GiB (52.3%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.9 C mobo: N/A gpu: amdgpu temp: 59.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1050
Processes: 371 Uptime: 1h 40m wakeups: 0 Memory: total: 32 GiB
available: 31.28 GiB used: 4.89 GiB (15.6%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1918 libs: 544
tools: gnome-software,octopi,pamac,paru,yay Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
