Corectrl startup not minimized
Hello, not sure if anyone else has that issue, but i cannot set corectrl to be minimized on startup, all the settings from other linux distro aren’t working on garuda, wasn’t checking on other arch distros
in corectrl settings i have option checked for start minimized
Any idea how to start it minimized?
  Kernel: 6.7.3-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=6f7982fa-f801-4a9f-a47e-a2cd8f08ee86 rw rootflags=subvol=@
    resume=UUID=4fb2a623-f3ae-4757-9e65-4eb2471f1194 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
  Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE
    serial: <superuser required> UEFI: American Megatrends LLC. v: F65a
    date: 02/09/2023
  Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0xA50000D
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1902 high: 3367 min/max: 400/4673 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2995 2: 400 3: 400
    4: 2994 5: 400 6: 400 7: 3000 8: 3314 9: 400 10: 2993 11: 2994 12: 3367
    13: 400 14: 2994 15: 2994 16: 400 bogomips: 121379
    vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0
    chip-ID: 1002:73df class-ID: 0300
    s-diag: 777mm (30.58")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung LC27G5xT
    serial: <filter> built: 2021 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
    max: 2560x1440 min: 720x400
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.5-arch1.1
    navi22 LLVM 16.0.6 DRM 3.57 6.7.3-zen1-2-zen) device-ID: 1002:73df
    memory: 11.72 GiB unified: no
  API: Vulkan v: 1.3.276 layers: 13 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.3.5-arch1.1
    device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
  Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
    link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.6 chip-ID: 1022:15e3
  API: ALSA v: k6.7.3-zen1-2-zen status: kernel-api with: aoss
    lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4
  Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
    rfk-block: hardware: no software: yes address: see --recommends
  Local Storage: total: 1.56 TiB used: 487.68 GiB (30.4%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 28.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: GOODRAM model: SSDPR-CL100-480-G2
    tech: SSD serial: <filter> fw-rev: V4.9 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: PNY model: CS900 240GB SSD
    tech: SSD serial: <filter> fw-rev: 0615 scheme: GPT
  ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 24.09 GiB (24.1%)
  ID-2: /boot/efi raw-size: 4 GiB size: 3.99 GiB (99.80%)
    used: 296 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 811.51 GiB size: 811.51 GiB (100.00%)
    used: 463.6 GiB (57.1%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
    used: 24.09 GiB (24.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
  ID-2: swap-2 type: zram size: 31.21 GiB used: 21.8 MiB (0.1%)
  System Temperatures: cpu: 32.4 C mobo: N/A gpu: amdgpu temp: 32.0 C
    mem: 28.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 894
  Processes: 408 Uptime: 1m wakeups: 0 Memory: total: 32 GiB
  available: 31.21 GiB used: 4.21 GiB (13.5%) Init: systemd v: 255
  pm: pacman pkgs: 1866 libs: 553 tools: octopi,paru,yay Shell: fish v: 3.7.0
Garuda (2.6.23-1):
  System install date:     2023-06-03
  Last full system update: 2024-02-05
recheck that option within corectrl to be sure. System (on the bottom)>settings (upper right)> checkbox for it.
if that is not working still, might be a bug? :man_shrugging:
Option seems to work for me.
Yes i was checking it before posting, and still checked
Bit of a long shot, but do you have any window rules set in KDE? I would recheck those.
Well i havent set any, but will check maybe some default ones are
Not sure exactly how these window options works in kde
Well, if you haven’t set any I don’t think it is that. Like I said, it was a bit of a long shot.
The reasoning why I suggested that you look them over just in case is because I’ve noticed with the setting on, that it starts minimized for a while before only being a system tray icon. In that time, I was guessing it could have a chance to be effected by KDE’s window rules.
ok i have found a solution
~/.config/autostart/org.corectrl.corectrl.desktop
in line Exec=corectrl --minimize systray i have changed to
Exec=corectrl --minimized
