Copy and Paste (from Browsers) into Libreoffice-fresh
Hi there,
I startet using garuda on my Main-Device a few weeks ago. I contrast to my other, more play-thing-device, I’ll do some more serious stuff on this :wink:
One of these serious stuff is “keeping record” (don’t know if this is the correct translation for “Protokoll führen”) on meetings of a local political party using libreoffice writer. Often I just want to copy and paste some text from the communitys webseite and want to paste it into my document.
When I just use Ctrl-V to paste, everything works, except that I have to formatting of the source in my document. Using Ctrl-Shift-V shows a window asking if I want to past HTML-formatted or plain. But no matter which option I choose, nothing gets pasted.
The same when I use the menu-bar “edit → paste special” (which is greyed out / inactive). Right-click → Paste works, Right-click → Paste special not.
Using other software as libreoffice (for example onlyoffice) → No problem so far, using Ctrl-Alt-Shift-V in libreoffice → No problem. The problem only seems to appear in pasting using or having UI-Elements.
I mean, I have some options to get around this problem (OK Ctrl-Alt-Shift-V I learned while writing this post :rofl: ) but maybe someone knows a solution for this.
**`[󰟾]`**` `**`󰛓`** `garuda-inxi`
**`System:`**` `
**`Kernel:`**`6.17.7-zen1-1-zen`**`arch:`**`x86_64`**`bits:`**`64`**`compiler:`**`gcc`**`v:`**`15.2.1`
**`clocksource:`**`tsc`**`avail:`**`hpet,acpi_pm`
**`parameters:`**`BOOT_IMAGE=/@/boot/vmlinuz-linux-zen`
`root=UUID=3c503cde-becb-4433-863f-0c7209efcd9b rw rootflags=subvol=@ `
`vt.default_red=30,243,166,249,137,245,148,186,88,243,166,249,137,245,148,166 `
`vt.default_grn=30,139,227,226,180,194,226,194,91,139,227,226,180,194,226,173 `
`vt.default_blu=46,168,161,175,250,231,213,222,112,168,161,175,250,231,213,200 `
`quiet rd.luks.uuid=58a7b4d3-23dd-40b6-8874-2ddc68f51f81 `
`rd.luks.uuid=493519a0-72d4-4d9d-bc0b-6672249bfe88 `
`resume=/dev/mapper/luks-493519a0-72d4-4d9d-bc0b-6672249bfe88 loglevel=3 `
**`Desktop:`**`KDE Plasma`**`v:`**`6.5.2`**`tk:`**`Qt`**`v:`**`N/A`**`info:`**`frameworks`**`v:`**`6.19.0`
**`wm:`**`kwin_wayland`**`vt:`**`2`**`dm:`**`SDDM`**`Distro:`**`Garuda`**`base:`**`Arch Linux`
**`Machine:`**` `
**`Type:`**`Laptop`**`System:`**`Framework`**`product:`**`Laptop 16 (AMD Ryzen 7040 Series)`
**`v:`**`AJ`**`serial:`**`<superuser required>`**`Chassis:`**` `**`type:`**`10`**`v:`**`AJ`
**`Mobo:`**`Framework`**`model:`**`FRANMZCP09`**`v:`**`A9`**`serial:`**`<superuser required>`
**`part-nu:`**`FRAGACCP0J`**`uuid:`**`<superuser required>`**`UEFI:`**`INSYDE`**`v:`**`03.07`
**`date:`**`08/27/2025`
**`Battery:`**` `
**`ID-1:`**`BAT1`**`charge:`**`19.6 Wh (24.6%)`**`condition:`**`79.8/85 Wh (93.9%)`
**`volts:`**`14.12`**`min:`**`15.48`**`model:`**`NVT FRANDBA`**`type:`**`Li-ion`**`serial:`**`<filter>`
**`charging:`**` `**`status:`**`discharging`**`cycles:`**`101`
**`CPU:`**` `
**`Info:`**` `**`model:`**`AMD Ryzen 9 7940HS w/ Radeon 780M Graphics`**`bits:`**`64`
**`type:`**`MT MCP`**`arch:`**`Zen 4`**`gen:`**`4`**`level:`**`v4`**`note:`**`check`**`built:`**`2022+`
**`process:`**`TSMC n5 (5nm)`**`family:`**`0x19 (25)`**`model-id:`**`0x74 (116)`**`stepping:`**`1`
**`microcode:`**`0xA70410A`
**`Topology:`**` `**`cpus:`**`1x`**`dies:`**`1`**`clusters:`**`1`**`cores:`**`8`**`threads:`**`16`**`tpc:`**`2`
**`smt:`**`enabled`**`cache:`**` `**`L1:`**`512 KiB`**`desc:`**`d-8x32 KiB; i-8x32 KiB`**`L2:`**`8 MiB`
**`desc:`**`8x1024 KiB`**`L3:`**`16 MiB`**`desc:`**`1x16 MiB`
**`Speed (MHz):`**` `**`avg:`**`403`**`min/max:`**`403/4001`**`boost:`**`enabled`**`scaling:`**` `
**`driver:`**`amd-pstate-epp`**`governor:`**`powersave`**`cores:`**` `**`1:`**`403`**`2:`**`403`**`3:`**`403`
**`4:`**`403`**`5:`**`403`**`6:`**`403`**`7:`**`403`**`8:`**`403`**`9:`**`403`**`10:`**`403`**`11:`**`403`**`12:`**`403`**`13:`**`403`
**`14:`**`403`**`15:`**`403`**`16:`**`403`**`bogomips:`**`127759`
**`Flags-basic:`**`avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a`
`ssse3 svm `
**`Vulnerabilities:`**`<filter>`
**`Graphics:`**` `
**`Device-1:`**`Advanced Micro Devices [AMD/ATI] Navi 33 [Radeon RX 7600/7600`
`XT/7600M XT/7600S/7700S / PRO W7600] `**`vendor:`**`Framework`**`driver:`**`amdgpu`
**`v:`**`kernel`**`arch:`**`RDNA-3`**`code:`**`Navi-3x`**`process:`**`TSMC n6 (6nm)`**`built:`**`2023+`
**`pcie:`**` `**`gen:`**`4`**`speed:`**`16 GT/s`**`lanes:`**`8`**`ports:`**` `**`active:`**`none`
**`empty:`**`DP-1,Writeback-1,eDP-1`**`bus-ID:`**`03:00.0`**`chip-ID:`**`1002:7480`
**`class-ID:`**`0300`
**`Device-2:`**`Advanced Micro Devices [AMD/ATI] Phoenix1`**`vendor:`**`Framework`
**`driver:`**`amdgpu`**`v:`**`kernel`**`arch:`**`RDNA-3`**`code:`**`Phoenix`**`process:`**`TSMC n4 (4nm)`
**`built:`**`2023+`**`pcie:`**` `**`gen:`**`4`**`speed:`**`16 GT/s`**`lanes:`**`16`**`ports:`**` `**`active:`**`eDP-2`
**`empty:`**`DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, DP-9, Writeback-2`
**`bus-ID:`**`c5:00.0`**`chip-ID:`**`1002:15bf`**`class-ID:`**`0300`**`temp:`**`54.0 C`
**`Device-3:`**`Realtek Laptop Camera`**`driver:`**`uvcvideo`**`type:`**`USB`**`rev:`**`2.0`
**`speed:`**`480 Mb/s`**`lanes:`**`1`**`mode:`**`2.0`**`bus-ID:`**`3-1:2`**`chip-ID:`**`0bda:5634`
**`class-ID:`**`0e02`**`serial:`**`<filter>`
**`Display:`**`wayland`**`server:`**``` ``X.org`` ```**`v:`**`1.21.1.20`**`with:`**`Xwayland`**`v:`**`24.1.9`
**`compositor:`**`kwin_wayland`**`driver:`**` `**`gpu:`**`amdgpu`**`display-ID:`**`0`
**`Monitor-1:`**`eDP-2`**`model:`**`BOE Display 0x0bc9`**`built:`**`2022`**`res:`**` `
**`mode:`**`2560x1600`**`hz:`**`165`**`scale:`**`100% (1)`**`dpi:`**`188`**`gamma:`**`1.2`
**`size:`**`345x215mm (13.58x8.46")`**`diag:`**`407mm (16")`**`ratio:`**`16:10`**`modes:`**` `
**`max:`**`2560x1600`**`min:`**`640x480`
**`API:`**`EGL`**`v:`**`1.5`**`hw:`**` `**`drv:`**`amd radeonsi`**`platforms:`**` `**`device:`**`0`**`drv:`**`radeonsi`
**`device:`**`1`**`drv:`**`radeonsi`**`device:`**`2`**`drv:`**`swrast`**`gbm:`**` `**`drv:`**`kms_swrast`
**`surfaceless:`**` `**`drv:`**`radeonsi`**`wayland:`**` `**`drv:`**`radeonsi`**`x11:`**` `**`drv:`**`radeonsi`
**`API:`**`OpenGL`**`v:`**`4.6`**`compat-v:`**`4.5`**`vendor:`**`amd mesa`**`v:`**`25.2.6-arch1.1`
**`glx-v:`**`1.4`**`direct-render:`**`yes`**`renderer:`**`AMD Radeon 780M Graphics (radeonsi`
`phoenix LLVM 21.1.4 DRM 3.64 6.17.7-zen1-1-zen) `**`device-ID:`**`1002:15bf`
**`memory:`**`1.95 GiB`**`unified:`**`no`**`display-ID:`**`:0.0`
**`API:`**`Vulkan`**`v:`**`1.4.328`**`layers:`**`12`**`device:`**`0`**`type:`**`integrated-gpu`**`name:`**`AMD`
`Radeon 780M Graphics (RADV PHOENIX) `**`driver:`**`mesa radv`**`v:`**`25.2.6-arch1.1`
**`device-ID:`**`1002:15bf`**`surfaces:`**`N/A`**`device:`**`1`**`type:`**`discrete-gpu`**`name:`**`AMD`
`Radeon RX 7700S (RADV NAVI33) `**`driver:`**`mesa radv`**`v:`**`25.2.6-arch1.1`
**`device-ID:`**`1002:7480`**`surfaces:`**`N/A`**`device:`**`2`**`type:`**`cpu`**`name:`**`llvmpipe`
`(LLVM 21.1.4 256 bits) `**`driver:`**`mesa llvmpipe`**`v:`**`25.2.6-arch1.1 (LLVM`
`21.1.4) `**`device-ID:`**`10005:0000`**`surfaces:`**`N/A`
**`Info:`**` `**`Tools:`**` `**`api:`**`clinfo, eglinfo, glxinfo, vulkaninfo`
**`de:`**`kscreen-console,kscreen-doctor`**`gpu:`**`lact`**`wl:`**`wayland-info`
**`x11:`**`xdpyinfo, xprop, xrandr`
**`Audio:`**` `
**`Device-1:`**`Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio`
**`vendor:`**`Framework`**`driver:`**`snd_hda_intel`**`v:`**`kernel`**`pcie:`**` `**`gen:`**`4`
**`speed:`**`16 GT/s`**`lanes:`**`8`**`bus-ID:`**`03:00.1`**`chip-ID:`**`1002:ab30`**`class-ID:`**`0403`
**`Device-2:`**`Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio`
`[Rembrandt/Strix] `**`vendor:`**`Framework`**`driver:`**`snd_hda_intel`**`v:`**`kernel`**`pcie:`**` `
**`gen:`**`4`**`speed:`**`16 GT/s`**`lanes:`**`16`**`bus-ID:`**`c5:00.1`**`chip-ID:`**`1002:1640`
**`Device-3:`**`Advanced Micro Devices [AMD] Audio Coprocessor`**`vendor:`**`Framework`
**`driver:`**`snd_pci_ps`**`v:`**`kernel`**`alternate:`**`snd_pci_acp3x, snd_rn_pci_acp3x,`
`snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, `
`snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh, `
`snd_sof_amd_acp63, snd_sof_amd_acp70 `**`pcie:`**` `**`gen:`**`4`**`speed:`**`16 GT/s`**`lanes:`**`16`
**`bus-ID:`**`c5:00.5`**`chip-ID:`**`1022:15e2`**`class-ID:`**`0480`
**`Device-4:`**`Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio`
**`speed:`**`16 GT/s`**`lanes:`**`16`**`bus-ID:`**`c5:00.6`**`chip-ID:`**`1022:15e3`**`class-ID:`**`0403`
**`API:`**`ALSA`**`v:`**`k6.17.7-zen1-1-zen`**`status:`**`kernel-api`**`tools:`**`N/A`
**`Server-1:`**`PipeWire`**`v:`**`1.4.9`**`status:`**`active`**`with:`**` `**`1:`**`pipewire-pulse`
**`status:`**`active`**`2:`**`wireplumber`**`status:`**`active`**`3:`**`pipewire-alsa`**`type:`**`plugin`
**`4:`**`pw-jack`**`type:`**`plugin`**`tools:`**`pactl,pw-cat,pw-cli,wpctl`
**`Network:`**` `
**`Device-1:`**`MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter`
**`driver:`**`mt7921e`**`v:`**`kernel`**`pcie:`**` `**`gen:`**`2`**`speed:`**`5 GT/s`**`lanes:`**`1`
**`bus-ID:`**`05:00.0`**`chip-ID:`**`14c3:0616`**`class-ID:`**`0280`
**`IF:`**`wlp5s0`**`state:`**`up`**`mac:`**`<filter>`
**`Info:`**` `**`services:`**`NetworkManager, smbd, systemd-timesyncd, wpa_supplicant`
**`Bluetooth:`**` `
**`Device-1:`**`MediaTek Wireless_Device`**`driver:`**`btusb`**`v:`**`0.8`**`type:`**`USB`**`rev:`**`2.1`
**`speed:`**`480 Mb/s`**`lanes:`**`1`**`mode:`**`2.0`**`bus-ID:`**`1-5:7`**`chip-ID:`**`0e8d:e616`
**`class-ID:`**`e001`**`serial:`**`<filter>`
**`Report:`**`btmgmt`**`ID:`**`hci0`**`rfk-id:`**`0`**`state:`**`up`**`address:`**`<filter>`**`bt-v:`**`5.3`
**`lmp-v:`**`12`**`status:`**` `**`discoverable:`**`no`**`pairing:`**`no`**`class-ID:`**`6c010c`
**`Drives:`**` `
**`Local Storage:`**` `**`total:`**`5.5 TiB`**`used:`**`372.45 GiB (6.6%)`
**`SMART Message:`**`Unable to run smartctl. Root privileges required.`
**`ID-1:`**`/dev/nvme0n1`**`maj-min:`**`259:4`**`vendor:`**`Crucial`**`model:`**`CT4000P3PSSD8`
**`size:`**`3.64 TiB`**`block-size:`**` `**`physical:`**`512 B`**`logical:`**`512 B`**`speed:`**`63.2 Gb/s`
**`lanes:`**`4`**`tech:`**`SSD`**`serial:`**`<filter>`**`fw-rev:`**`P9CR40A`**`temp:`**`41.9 C`
**`scheme:`**`GPT`
**`ID-2:`**`/dev/nvme1n1`**`maj-min:`**`259:0`**`vendor:`**`Western Digital`**`model:`**`WD PC`
`SN740 SDDPTQE-2T00 `**`size:`**`1.86 TiB`**`block-size:`**` `**`physical:`**`512 B`
**`logical:`**`512 B`**`speed:`**`63.2 Gb/s`**`lanes:`**`4`**`tech:`**`SSD`**`serial:`**`<filter>`
**`fw-rev:`**`73116000`**`temp:`**`40.9 C`**`scheme:`**`GPT`
**`Partition:`**` `
**`ID-1:`**`/`**`raw-size:`**`1.8 TiB`**`size:`**`1.8 TiB (100.00%)`**`used:`**`372.45 GiB (20.2%)`
**`fs:`**`btrfs`**`dev:`**`/dev/dm-0`**`maj-min:`**`253:0`
**`mapped:`**`luks-58a7b4d3-23dd-40b6-8874-2ddc68f51f81`
**`ID-2:`**`/boot/efi`**`raw-size:`**`300 MiB`**`size:`**`299.4 MiB (99.80%)`
**`used:`**`984 KiB (0.3%)`**`fs:`**`vfat`**`dev:`**`/dev/nvme1n1p1`**`maj-min:`**`259:1`
**`ID-3:`**`/home`**`raw-size:`**`1.8 TiB`**`size:`**`1.8 TiB (100.00%)`
**`used:`**`372.45 GiB (20.2%)`**`fs:`**`btrfs`**`dev:`**`/dev/dm-0`**`maj-min:`**`253:0`
**`ID-4:`**`/var/log`**`raw-size:`**`1.8 TiB`**`size:`**`1.8 TiB (100.00%)`
**`ID-5:`**`/var/tmp`**`raw-size:`**`1.8 TiB`**`size:`**`1.8 TiB (100.00%)`
**`Swap:`**` `
**`Kernel:`**` `**`swappiness:`**`133 (default 60)`**`cache-pressure:`**`100 (default)`**`zswap:`**`no`
**`ID-1:`**`swap-1`**`type:`**`partition`**`size:`**`66.69 GiB`**`used:`**`0 KiB (0.0%)`
**`priority:`**`-2`**`dev:`**`/dev/dm-1`**`maj-min:`**`253:1`
**`mapped:`**`luks-493519a0-72d4-4d9d-bc0b-6672249bfe88`
**`ID-2:`**`swap-2`**`type:`**`zram`**`size:`**`60.63 GiB`**`used:`**`0 KiB (0.0%)`**`priority:`**`100`
**`comp:`**`zstd`**`avail:`**`lzo-rle,lzo,lz4,lz4hc,deflate,842`**`dev:`**`/dev/zram0`
**`Sensors:`**` `
**`System Temperatures:`**` `**`cpu:`**`54.9 C`**`mobo:`**`N/A`
**`Fan Speeds (rpm):`**`N/A`
**`GPU:`**` `**`device:`**`amdgpu`**`temp:`**`35.0 C`**`mem:`**`43.0 C`**`fan:`**`0`**`watts:`**`3.00`
**`device:`**`amdgpu`**`temp:`**`54.0 C`**`watts:`**`15.08`
**`Info:`**` `
**`Memory:`**` `**`total:`**`64 GiB`**`available:`**`60.63 GiB`**`used:`**`9.36 GiB (15.4%)`
**`Processes:`**`513`**`Power:`**` `**`uptime:`**`2h 10m`**`states:`**`freeze,mem,disk`
**`suspend:`**`s2idle`**`wakeups:`**`0`**`hibernate:`**`platform`**`avail:`**`shutdown, reboot,`
`suspend, test_resume `**`image:`**`24.24 GiB`**`services:`**`org_kde_powerdevil,`
`power-profiles-daemon, upowerd `**`Init:`**`systemd`**`v:`**`258`**`default:`**`graphical`
**`tool:`**`systemctl`
**`Packages:`**` `**`pm:`**`pacman`**`pkgs:`**`1918`**`libs:`**`522`**`tools:`**`octopi,paru`**`Compilers:`**` `
**`clang:`**`21.1.5`**`gcc:`**`15.2.1`**`Shell:`**`Bash`**`v:`**`5.3.3`**`default:`**`fish`**`v:`**`4.2.0`
**`running-in:`**`yakuake`**`inxi:`**`3.3.39`
**`Garuda (2.11.1-1):`**` `
**`System install date:`**`    2025-10-19`
**`Garuda release:`**`         251002`
**`Last full system update:`**`2025-11-11`
**`Is partially upgraded:`**  `No`
**`Relevant software:`**      `snapper NetworkManager dracut garuda-hardware-profile-standard`
**`Windows dual boot:`**      `Probably (Run as root to verify)`
**`Failed units:`**` `
`--- System Health Check Report --- `
`24/25 checks run in 2.65 seconds ⌛  `
`Powered by garuda-health 🦅e `
`✅ System health check passed. No issues found.`
It should be this bug:
(try Ctrl+Shift+Alt+V, maybe it’s not really a bug)
Yeah, thanks. Going to check if I can provide helpful Information to this bugreport when home again.
But I think, besides that Ctrl+Shift+Alt+V works, that it is still ab bug because Libreoffice is offering the other ways to paste unformated text and when offered it should work :wink:
Switch to an x11 session, then it should work w/o any issues (tested in a VM with Mokka and LO fresh).
If you don’t have x11 installed:
sudo pacman -S plasma-x11-session
Then reboot and select “Plasma (x11)” as your desktop session on the login screen.
