Controls on Secondary Screen
Fresh install of garuda. I have 2 Monitors[{Samsung(Primary)}, {BenQ}].
Plasma Controls etc. is drawn on BenQ(Secondary display). When I set BenQ(Primary), controls etc are beeing drawn on Samsung(secondary)
How can i fix this?
root=UUID=bba46c1c-567f-43bb-8c92-6fbf398cd3fc rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: B760 GAMING X AX v: x.x
Megatrends LLC. v: F4 date: 06/06/2023
Info: model: 13th Gen Intel Core i5-13600KF bits: 64 type: MST AMCP
microcode: 0x12C
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 800 min/max: 800/5100:3900 scaling: driver: intel_pstate
17: 800 18: 800 19: 800 20: 800 bogomips: 139776
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] driver: nvidia
v: 570.133.07 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2489
d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-1 pos: primary,left model: Samsung Odyssey G40B
serial: <filter> built: 2023 res: mode: 1920x1080 hz: 240 scale: 100% (1)
dpi: 82 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
Monitor-2: HDMI-A-1 pos: right model: BenQ XL2411Z serial: <filter>
built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: N/A device-ID: 10de:2489
Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api tools: N/A
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0032
Local Storage: total: 2.06 TiB used: 52.91 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
ID-4: /dev/sdc maj-min: 8:32 model: General size: 14.65 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: N/A fw-rev: 5.00 scheme: MBR
used: 52.91 GiB (5.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.17 GiB used: 61.2 MiB (0.2%)
max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 42.0 C mobo: 36.2 C
Memory: total: 32 GiB available: 31.17 GiB used: 5.6 GiB (18.0%)
Processes: 460 Power: uptime: 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.4 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1435 libs: 435 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1 running-in: konsole
inxi: 3.3.37
System install date:     2025-03-26
Last full system update: 2025-03-26
I see so many BIOSe that are not up to date
Connect to dp-2 or dp-3 and then ?
Think on the hdmi specification (bandwith)
or start a x11 session, use nvsettings and then ? (eachtime reboot if you change resolution/refresh-rate)
Bios Updated from F4 to F13.
switch to dp-2->restart->BenQ as Primary → restart Samsung as Primary Restart. Same Issue.
switch to dp-3->restart->BenQ as Primary → restart Samsung as Primary Restart. Same Issue.
Disconnected HDMI BenQ Screen → restart left only Samsung connected.
Even though Samsung was only display left, Plasma controls completely gone.
Will try starting x11 session now and nvsettings.
Megatrends LLC. v: F13 date: 02/26/2025
microcode: 0x12C
lanes: 16 ports: active: none off: DP-3,HDMI-A-1 empty: DP-1,DP-2
bus-ID: 01:00.0 chip-ID: 10de:2489 class-ID: 0300
Monitor-1: DP-3 pos: primary,left model: Samsung Odyssey G40B
Device-3: SteelSeries ApS Arctis Nova Pro Wireless
lanes: 1 mode: 1.1 bus-ID: 1-6.1:5 chip-ID: 1038:12e0 class-ID: 0300
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0032
Local Storage: total: 2.06 TiB used: 105.73 GiB (5.0%)
temp: 38.9 C scheme: GPT
used: 105.73 GiB (11.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 612 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 20
System Temperatures: cpu: 40.0 C mobo: 34.5 C
Memory: total: 32 GiB available: 31.16 GiB used: 2.22 GiB (7.1%)
Processes: 438 Power: uptime: 0m states: freeze,mem,disk suspend: deep
Packages: pm: pacman pkgs: 1437 libs: 436 tools: octopi,paru Compilers:
inxi: 3.3.37
Switched to x11 did check that in nvsetting Samsung is also primary screen and synced to Samsung display.
  Kernel: 6.13.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    root=UUID=bba46c1c-567f-43bb-8c92-6fbf398cd3fc rw rootflags=subvol=@ quiet loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0 wm: kwin_x11 vt: 2
  Type: Desktop Mobo: Gigabyte model: B760 GAMING X AX v: x.x serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: F13 date: 02/26/2025
  Info: model: 13th Gen Intel Core i5-13600KF bits: 64 type: MST AMCP arch: Raptor Lake
    gen: core 13 level: v3 note: check built: 2022+ process: Intel 7 (10nm) family: 6
    model-id: 0xB7 (183) stepping: 1 microcode: 0x12C
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2 st: 8 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB L2: 20 MiB
  Speed (MHz): avg: 1100 min/max: 800/5100:3900 scaling: driver: intel_pstate governor: powersave
    cores: 1: 1100 2: 1100 3: 1100 4: 1100 5: 1100 6: 1100 7: 1100 8: 1100 9: 1100 10: 1100 11: 1100
    12: 1100 13: 1100 14: 1100 15: 1100 16: 1100 17: 1100 18: 1100 19: 1100 20: 1100
    bogomips: 139776
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] driver: nvidia v: 570.133.07
    alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as of 2025-01;
    EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: none off: DP-3,HDMI-A-1 empty: DP-1,DP-2
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_x11 driver: X:
    loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch
  Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
    s-diag: 1252mm (49.29")
  Monitor-1: DP-3 mapped: DP-4 note: disabled pos: primary,left model: Samsung Odyssey G40B
    serial: <filter> built: 2023 res: mode: 1920x1080 hz: 240 scale: 100% (1) dpi: 82 gamma: 1.2
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right model: BenQ XL2411Z
    serial: <filter> built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
    size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm: drv: nvidia surfaceless:
    drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4 direct-render: yes renderer: NVIDIA
    GeForce RTX 3060 Ti/PCIe/SSE2 memory: 7.81 GiB
  API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 3060 Ti
    driver: N/A device-ID: 10de:2489 surfaces: xcb,xlib
    gpu: nvidia-settings,nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
  Device-2: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-3: SteelSeries ApS Arctis Nova Pro Wireless driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.1:5 chip-ID: 1038:12e0
  Server-1: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2725 class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8125 class-ID: 0200
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0032 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3 lmp-v: 12 status:
  Local Storage: total: 2.06 TiB used: 105.76 GiB (5.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with Heatsink 1TB
    serial: <filter> fw-rev: 5B2QGXA7 temp: 39.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB size: 931.51 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 04RL
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
    fw-rev: 1B6Q scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 model: General size: 14.65 GiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: N/A
  ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 105.76 GiB (11.4%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 612 KiB (0.2%) fs: vfat
  ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 105.76 GiB (11.4%) fs: btrfs
  ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 105.76 GiB (11.4%)
  ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 105.76 GiB (11.4%)
  ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 20 dev: /dev/zram0
  System Temperatures: cpu: 42.0 C mobo: 35.5 C gpu: nvidia temp: 52 C
  Memory: total: 32 GiB available: 31.16 GiB used: 2.62 GiB (8.4%)
  Processes: 450 Power: uptime: 0m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.4 GiB
  Packages: pm: pacman pkgs: 1437 libs: 436 tools: octopi,paru Compilers: gcc: 14.2.1
    Client: Unknown Client: garuda-rani inxi: 3.3.37
edited this:
/usr/share/sddm/scripts/Xsetup
xrandr --output DP-3 --auto --primary
xrandr --output DP-3 --left-of HDMI-A-1 --rotate left --noprimary
→ restart → issure still there.
Maybe the Dock and Panel are not bound to the primary screen? Where is this defined?
Have you actually checked the “Screen Layout” settings (top panel → button “Show hidden icons” → “Display Configuration”)?
running the following command in terminal at the main screen solved the issue for me.
lookandfeeltool --resetLayout --apply Dr460nized
It was working out of the box with my second screen but amd not nvidia =)
