Hello, thank you in advance for any help. I have a strange issue and I dont really understand whats happening.
I have a fightstick that uses a board from Brooke (Snackbox Micro) that connects through USB C > USB. When connected normally through USB, it will not show up in controllers or in game. I have a USB C - USB C port on my motherboard, and when i connect using that port alone the stick appears as normal and works perfectly. I am at a total loss.
The stick appears under lsusb when connected from USBC to USBC, when connected normally, the stick glows showing it is connected but nothing appears. I am seriously stumped on this one and any help would be appreciated. I can use this stick on my machine, but its no fun if i cant take it anywhere haha.
INXI:
Kernel: 6.0.6-zen1-1-zen arch: x86_64 bits: 64
compiler: gcc v: 12.2.0
root=UUID=855a40ff-2fe4-4d97-a9f3-4e5d5c058c2c rw
rootflags=subvol=@ intel_iommu=on iommu=pt quiet
quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7
info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: STRIX Z270E GAMING
v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 1302 date: 03/15/2018
Info: model: Intel Core i7-7700K bits: 64 type: MT MCP
arch: Kaby Lake gen: core 7 level: v3 note: check
built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB;
i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 4600 high: 4601 min/max: 800/4600
scaling: driver: intel_pstate governor: performance
cores: 1: 4600 2: 4601 3: 4600 4: 4600 5: 4600
6: 4600 7: 4600 8: 4600 bogomips: 67200
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1
sse4_2 ssse3
Type: mds mitigation: Clear CPU buffers; SMT
vulnerable
Type: mmio_stale_data mitigation: Clear CPU buffers;
SMT vulnerable
Type: spec_store_bypass mitigation: Speculative Store
Bypass disabled via prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers
and __user pointer sanitization
Type: spectre_v2 mitigation: IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106 [GeForce RTX 3060]
vendor: Micro-Star MSI driver: nvidia v: 520.56.06
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Ampere
code: GAxxx process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2503
Display: x11 server: X.Org v: 21.1.4 with: Xwayland
v: 22.1.5 compositor: kwin_x11 driver: X:
loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia
Screen-1: 0 s-res: 4080x1920 s-dpi: 91
s-size: 1139x536mm (44.84x21.10")
s-diag: 1259mm (49.56")
Monitor-1: DP-0 pos: primary,bottom-c res: 1920x1080
dpi: 82 size: 598x336mm (23.54x13.23")
diag: 686mm (27.01") modes: N/A
Monitor-2: DP-3 pos: top-right res: 1080x1920 dpi: 82
size: 336x598mm (13.23x23.54") diag: 686mm (27.01")
modes: N/A
Monitor-3: DP-4 pos: primary,top-left res: 1080x1920
hz: 60 dpi: 93 size: 296x527mm (11.65x20.75")
diag: 604mm (23.8") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
v: 4.6.0 NVIDIA 520.56.06 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 1-5:4
chip-ID: 041e:3264 bus-ID: 00:1f.3 class-ID: 0102
chip-ID: 8086:a2f0 serial: <filter> class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Device-3: Creative Sound Blaster X3 type: USB
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid
Device-4: Blue Microphones Yeti Stereo Microphone
type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-6:5 chip-ID: b58e:9e84 class-ID: 0300
Sound API: ALSA v: k6.0.6-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK
driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6
chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full
mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless
Network Adapter vendor: ASUSTeK driver: ath10k_pci
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 168c:003e class-ID: 0280
IF-ID-1: tun0 state: unknown speed: 10 Mbps
duplex: full mac: N/A
Device-1: ASUSTek Qualcomm Bluetooth 4.1 type: USB
driver: btusb v: 0.8 bus-ID: 1-7:6 chip-ID: 0b05:1825
Report: bt-adapter ID: hci0 rfk-id: 0 state: up
address: <filter>
Hardware-1: Intel SATA Controller [RAID mode]
driver: ahci v: 3.0 port: f020 bus-ID: 00:17.0
chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 2.05 TiB used: 1.3 TiB (63.3%)
SMART Message: Unable to run smartctl. Root
privileges required.
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate
model: ST2000DM001-1ER164 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC26
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD
850 EVO 250GB size: 232.89 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
used: 35.99 GiB (15.5%) fs: btrfs dev: /dev/sdb2
maj-min: 8:18
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB
(99.80%) used: 608 KiB (0.2%) fs: vfat dev: /dev/sdb1
maj-min: 8:17
ID-3: /home raw-size: 232.59 GiB size: 232.59 GiB
(100.00%) used: 35.99 GiB (15.5%) fs: btrfs
dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 232.59 GiB size: 232.59 GiB
ID-5: /var/tmp raw-size: 232.59 GiB size: 232.59 GiB
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB
(0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 60.0 C mobo: N/A gpu: nvidia
temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 327 Uptime: 53m wakeups: 0 Memory: 31.28 GiB
used: 8.62 GiB (27.6%) Init: systemd v: 251
default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 2029 libs: 630 tools: octopi,pamac,paru
pm: flatpak pkgs: 0 Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-10-23
Last full system update: 2022-11-03
Failed units: shadow.service
I have also tested this stick with a known good working cable and tested on 2 machines in the house running garuda. Only my main PC with the USBC to USBC will work.
I know its a weird issue, but I appreciate any help, and i hope this is the right place to ask. Thank you again.
