Controller Not working in xinput
This controller is detected by lsusb but apps cant detect it
Dinput mode works fine my controller has both modes.
I made sure to install all 4 drivers as well from garuda gamer.
https://i.imgur.com/Br0t6o5.jpg
This is the first time this has happened to me in any distro this is a freshly installed garuda dragonised edition setup.
Bus 003 Device 009: ID 046d:c21f Logitech, Inc. F710 Wireless Gamepad [XInput Mode]
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Kernel: 6.6.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=eabffc00-3f85-4006-a9f0-53cc220d6c59 rw rootflags=subvol=@
quiet resume=UUID=8aaaa62b-3f17-4d14-9cd3-ebcd13e58454 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 20VE v: TB 15 G2 ITL
serial: <superuser required> Chassis: type: 10 v: TB 15 G2 ITL
Mobo: LENOVO model: LNVNB161216 v: 31900002 WIN
serial: <superuser required> UEFI: LENOVO v: F8CN55WW(V2.18)
date: 06/01/2023
ID-1: BAT1 charge: 31.5 Wh (70.6%) condition: 44.6/45.0 Wh (99.1%)
volts: 12.2 min: 11.6 model: LGC L19L3PDA type: Li-ion serial: <filter>
status: charging cycles: 357
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xB4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1703 high: 3801 min/max: 400/4200 scaling:
driver: intel_pstate governor: performance cores: 1: 1932 2: 3801 3: 1837
4: 400 5: 1056 6: 400 7: 3801 8: 400 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: DP-2 off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 5986:212b
class-ID: 0e02
Monitor-1: DP-2 res: 1920x1080 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 15.05 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: integrated-gpu
name: Intel Xe Graphics (TGL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.6.4-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
IF: wlp0s20f3 state: down mac: <filter>
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 0000:2b:00.0
IF: enp43s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:8 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.39 TiB used: 66.87 GiB (4.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX900 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: U0708A0 temp: 66.8 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
tech: HDD rpm: 7200 serial: <filter> fw-rev: LXM6 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Ultra USB 3.0
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: GPT
ID-1: / raw-size: 448.51 GiB size: 448.51 GiB (100.00%)
used: 25.97 GiB (5.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 16.6 MiB (5.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 448.51 GiB size: 448.51 GiB (100.00%)
ID-4: /var/log raw-size: 448.51 GiB size: 448.51 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.51 GiB size: 448.51 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 273.5 MiB (1.7%)
ID-2: swap-2 type: partition size: 16.95 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 74.0 C mobo: N/A
Processes: 290 Uptime: 1h 3m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.41 GiB used: 4.94 GiB (32.0%) Init: systemd v: 254
Packages: 1977 pm: pacman pkgs: 1963 libs: 565 tools: octopi,paru
pm: flatpak pkgs: 14 Shell: fish v: 3.6.2 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-12-05
Last full system update: 2023-12-06
I’m not sure installing all four drivers at the same time is that good, maybe try them one by one (reboot on each attempt). Or even none, in theory it should be handled by the xbox kernel module without additional drivers.
See also Gamepad - ArchWiki.
More info about the 046d:c21f here Logitech F710 Wireless Gamepad [XInput Mode].
It should Just Work :tm: but let us know.
Looks like removing all the drivers was the correct call and now this works . Im guessing this issue occured because this controller tries to mimic an xbox360 controller in xinput mode which caused this issue .
think this solution would work with a steel series controller(xinput)? experienced this too in certain games
