Kernel: 5.19.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d84d1289-1918-4cb8-b260-dc86d66875da rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1
Type: Desktop System: Micro-Star product: MS-7A38 v: 2.0
Mobo: Micro-Star model: B350M PRO-VDH (MS-7A38) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.E0
date: 09/21/2018
Info: model: AMD Ryzen 5 1400 bits: 64 type: MT MCP arch: Zen level: v3
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
microcode: 0x8001137
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3165 high: 3400 min/max: N/A cores: 1: 3224 2: 2731
3: 3399 4: 3398 5: 3400 6: 3398 7: 3074 8: 2698 bogomips: 54399
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: eVga.com.
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 1f:00.0 chip-ID: 10de:1c02 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 92
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 3-3.3:10 chip-ID: 1532:0521 pcie:
gen: 3 class-ID: 0300 serial: <filter> speed: 8 GT/s lanes: 16
bus-ID: 1f:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 21:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Razer USA Kraken Kitty Edition type: USB
Sound Server-1: ALSA v: k5.19.12-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 1d:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp29s0 state: up mac: <filter>
Local Storage: total: 1.02 TiB used: 851.64 GiB (81.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power model: SPCC Solid State
Disk size: 111.79 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 21.1 scheme: GPT
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 76.91 GiB
(69.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 76.91
GiB (69.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 76.91
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 76.91
ID-1: swap-1 type: zram size: 15.57 GiB used: 403 MiB (2.5%)
System Temperatures: cpu: 47.0 C mobo: 44.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1965 fan-3: 1221 fan-4: 863 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.25
Processes: 337 Uptime: 45m wakeups: 0 Memory: 15.57 GiB used: 8.63 GiB
(55.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2203
libs: 649 tools: pacaur,pamac,paru,yay Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-08-05
Last full system update: 2022-10-02
Hello, I recently got a new controller since my old xbox one was on its last legs. I went ahead with getting an xbox controller from PowerA. It reads it as an xbox controller and the normal buttons work perfect out of the box. However, this controller comes with a few extra buttons on the back and I can't seem to get them working. There's nothing that I saw or tried on AntiMicroX that worked nor the regular gamepad settings. There are extra button slots on AntiMicroX as if extra buttons could be used but it does not detect the input at all. It also doesn't detect the big Xbox button either. I was wondering if anyone knew how I could get them to work? This is a shot in the dark but hopefully someone else has had this problem and found a solution before me. Thank you!
