During Gaming, Wine or Native and not during desktop work, some times moving the mouse doesn’t turn the game camera. It’s a stuttery input problem that doesn’t effect the graphics or fps. I don’t remember the exact update the caused this. Downgrading the kernel or changing usb slots didn’t help.
root=UUID=64c5885f-f1e8-4d9b-b0a0-db6572565fe0 rw rootflags=subvol=@
Type: Desktop Mobo: ASRock model: B450 Gaming-ITX/ac
UEFI: American Megatrends v: P8.01 date: 03/13/2023
Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 3
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA500011
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2790 min/max: 480/4980 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2790 2: 2790 3: 2790
4: 2790 5: 2790 6: 2790 7: 2790 8: 2790 9: 2790 10: 2790 11: 2790 12: 2790
bogomips: 100801
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
XT/6600M] vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1,
Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Dell S2719DGF serial: <filter> built: 2019 res:
mode: 2560x1440 hz: 155 scale: 175% (1.75) to: 1463x823 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 20.1.6 DRM 3.63 6.15.3-zen1-1-zen) device-ID: 1002:73ff
API: Vulkan v: 1.4.313 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 25.1.4-arch1.1
device-ID: 1002:73ff surfaces: N/A device: 1 type: cpu name: llvmpipe
de: kscreen-console,kscreen-doctor gpu: amdgpu_top wl: wayland-info
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0d:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 0d:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Telink VR P10 Dongle driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2
chip-ID: 291a:385d class-ID: 0300
API: ALSA v: k6.15.3-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 0a:00.0
IF: wlp10s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 0b:00.0
IF: enp11s0 state: down mac: <filter>
IF-ID-1: enp13s0f4u2 state: unknown speed: -1 duplex: half mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:2 chip-ID: 8087:0aa7
Device-2: Xiaomi Mi/Redmi series (RNDIS) driver: rndis_host v: kernel
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:4
chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
Local Storage: total: 931.51 GiB used: 406.17 GiB (43.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 800
lanes: 4 tech: SSD serial: <filter> fw-rev: V1122B0 temp: 48.9 C
used: 406.17 GiB (43.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.21 GiB used: 8 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.5 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 58.0 C
Memory: total: 32 GiB available: 31.21 GiB used: 6.45 GiB (20.7%)
Processes: 334 Power: uptime: 45m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1666 libs: 522
tools: pacaur,paru,pikaur,trizen,yay Compilers: gcc: 15.1.1
Shell: garuda-inxi default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
System install date: 2024-10-21
Last full system update: 2025-06-27
Bios update is a option
Supports AMD AM4 Socket Ryzen™ 2000, 3000, 4000 G-Series, 5000 and 5000 G-Series Desktop Processors; Supports DDR4 3466+ (OC); 1 PCIe 3.0 x16; Graphics Output: DisplayPort 1.2, HDMI 2.0; 7.1 CH HD Audio (Realtek ALC1220 Audio Codec), Supports...
Think on the right settings,after. (s-boot,f-boot,resize-bar)
Downgrade the kernel is not the option. (my mind) If install another kernel + headers (znver3 or lts)
Did the update. Nothing changed.
Kernel: 6.15.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
UEFI: American Megatrends v: P10.41 date: 04/15/2025
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA500014
bogomips: 100806
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.2
LLVM 20.1.6 DRM 3.63 6.15.4-zen2-1-zen) device-ID: 1002:73ff
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 25.1.4-arch1.2
(LLVM 20.1.6 256 bits) driver: mesa llvmpipe v: 25.1.4-arch1.2 (LLVM
API: ALSA v: k6.15.4-zen2-1-zen status: kernel-api with: aoss
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:5
Local Storage: total: 931.51 GiB used: 469.46 GiB (50.4%)
lanes: 4 tech: SSD serial: <filter> fw-rev: V1122B0 temp: 42.9 C
used: 469.46 GiB (50.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.21 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.1 C mobo: N/A gpu: amdgpu temp: 42.0 C
mem: 42.0 C
Memory: total: 32 GiB available: 31.21 GiB used: 3.35 GiB (10.7%)
Processes: 327 Power: uptime: 55m states: freeze,mem,disk suspend: deep
Garuda (2.7.3-1):
Last full system update: 2025-07-02
Tested with other kernels ?
As info:
we had 2 updates since last week (proton db)
the info from Arch linux news over proton from Mon, 16 Jun 2025 * Transition to the new WoW64 wine and wine-staging
(to read over example octopi if you click on Tab file “news from your distrubition”
mesa update, perhaps that`s the reason, why.
Any way to debug the problem without downgrade packages?
You should read the log from journal and special for the games.
You didn’t explicitly say which games it’s happening with. So start the affected game and look at the game’s Steam log, e.g.
No, no downgrade → you don’t know exactly why. (my mind)
Mouses loses motion for a second, happens every few seconds to the entire OS now. Tried Bios update and Cachy Kernel, removing any other device from the PC. Again nothing.
Do you have enough snapper image retention to roll your system back to just before these problems began?
Another thing you might want to test is creating a new user account to find out if this issue is present on a new account.
Are you using USB phone tethering as a full time internet connection?
You did not state the make or type of mouse in use. Is this a wired or wireless mouse? Your inxi output would seem to indicate you are using a wired USB mouse, is this correct?
Have you tested this mouse on other computers (Linux, not Windows) or in a live environment to find out if the mouse itself is problematic?
Have you tested other mice on this computer to see if the same problem exists using a replacement mouse?
Please answer all questions in full.
Not enough packages to go back. My system does professional stuff, not allowed to go back. Not remembering when started.
User account won’t help, didn’t change any setting at all.
USB phone tethering is my full time internet connection in this place. But i did try without it to.
Cooler Master MM720 usb. I’m a technician myself, this is not an electrical level damage, tested with polymeter. Are you ok driver wise?
It happens on every usb, once a minute on desktop, 2x on video, 4x on gaming. SVP4 does weird stuff with freesync to, till it hangs. During the mouse event i get DEVICE_REMOVED followed by instant DEVICE_ADDED. There is no power loss on any of the usbs on any of their pins. No power loss moving the mouse cable. No power loss during the event on mouse’s leds.
Take a look in your bios, is there a option for the usb ports ?
Test it with the kernels lts, znver3
sudo pacman -S linux-znver3 linux-znver3-headers
What kind of usb options should i look in my bios? The above kernels are not compatible with my needs.
I have no asrock board, it`s “only” a info that you perhaps find in the bios relevant usb settings.
example: options for legacy usb / xhci hand off support (if, both enabled)
Znver3 is optimized special and “only” for this cpu, with all the settings equal then linux-zen kernel (my knowledge)
First the issue “only” during game but now you have the issue always.
tbg:
Do you have tested ?
An update solved my problem. Can you mark it as no more?
system
Closed
12 July 2025 08:21
15
