Constant Crashes and freezes
I have a problem with system freezing and then crashing out of nowhere
and I also have to manually restart the system.
Also tried using w10 and worked fine so the issue is hidden somewhere in Garuda
I tried garuda-update or even updating my drivers but nothing helped.
root=UUID=ebed6cff-30a0-4478-a55d-e7ed3e8c1b70 rw rootflags=subvol=@
quiet resume=UUID=3651864e-f610-4353-8d3c-d132bc390596 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B360-G GAMING v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 1703 date: 09/02/2019
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF6
desc: 1x9 MiB
Speed (MHz): avg: 3495 high: 4085 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4080 2: 4003 3: 800
4: 4085 5: 4002 6: 4002 bogomips: 34798
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 555.58.02
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none off: DP-2,HDMI-A-1 empty: DP-1,DP-3
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: Sonix Foscam Webcam W41 Audio driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3
chip-ID: 2c45:6366 class-ID: 0102 serial: <filter>
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 4480x1440 s-dpi: 108 s-size: 1054x342mm (41.50x13.46")
s-diag: 1108mm (43.63")
Monitor-1: DP-2 note: disabled pos: primary,top-left model: VG27AQL1A
serial: <filter> built: 2023 res: 2560x1440 dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: bottom-r
model: Acer EK240Y serial: <filter> built: 2020 res: 1920x1080 dpi: 94
gamma: 1.2 size: 520x320mm (20.47x12.6") diag: 611mm (24.1") ratio: 16:10
inactive: wayland,device-1
memory: 11.72 GiB
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 555.58.02
device-ID: 10de:2504 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM
v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Device-3: Sonix Foscam Webcam W41 Audio driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 2.05 TiB used: 632.22 GiB (30.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S11 Pro size: 238.47 GiB block-size: physical: 512 B
fw-rev: 42A4SANA temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
ID-1: / raw-size: 51.6 GiB size: 51.6 GiB (100.00%) used: 35.67 GiB (69.1%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 512.6 MiB size: 511.6 MiB (99.80%)
used: 588 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 935.28 GiB size: 935.28 GiB (100.00%)
used: 596.55 GiB (63.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 51.6 GiB size: 51.6 GiB (100.00%)
used: 35.67 GiB (69.1%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-5: /var/tmp raw-size: 51.6 GiB size: 51.6 GiB (100.00%)
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 39.0 C mobo: N/A gpu: nvidia temp: 46 C
Memory: total: 32 GiB available: 31.26 GiB used: 4.19 GiB (13.4%)
Processes: 337 Power: uptime: 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2026 libs: 560 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date:     2024-03-30
Last full system update: 2024-07-08 ↻
If you are experiencing system instability, I would suggest you first update your BIOS to the latest version. There has been a few releases since the version you have listed, and a few of them state they “Improve system stability”.
Also, since you have this:
The BIOS update would also provide:
“Add Resizable BAR support for Nvidia RTX 30 series cards to potentially deliver more performance to gamers in select titles.”
The ↻ at the end means you need to restart your pc to finalize the updates, depending on your hybernation/sleep settings you might need to restart instead of shut down for that to happen.
Did you triy with another RAM and continues?
I have a brand new ram, bought it like 2 weeks ago 2x 16GB
Ram can still be part of the issue even when it’s brand new. Remove one stick and use that single stick until the systen crashes, (or not). If it still crashes, shut down and switch Ram sticks again. If it doesn’t crash with the remaining stick, RMA the faulty stick.
Are you running at your MOBO manufaturer’s recommended timings for your new ram, or have you elevated them trying to squeeze more performance out of your system. Overclocking is often a cause of system instability, you should not be overclocking or undervolting until this issue is resolved.
As you’ve already been told, you should update your bios so that you can eliminate that as a potential cause. Most people won’t waste time attempting to help someone who refuses to update their bios, as that is an obligatory primary troubleshooting step.
