I have installed Garuda Dr46nised 2 days ago .I have a Cannon G2000 series printer and I use it by connecting it to a usb It worked well on Windows 10. I have installed system-config-printer but I don't know where to find its PPD file and I have tried searching it but I didn't find any drivers for this .Please help me. Setting up this Printer.
Perhaps spell the manufacturers name correctly when searching:
This was the first hit in my search results. ^^^
Here’s more:
Or, a more refined search using “Arch Linux” in the search terms:
This was the first hit in my search results on the above search terms:
https://aur.archlinux.org/packages/cnijfilter2/?O=10&PP=10
Lots of hits there.
More refined yet:
These search results must include “G2000” with Google as they are given first priority because of the quotation marks:
Download Cannon “G2000” printer ppd file Arch Linux
Perhaps you simply need to spend some time learning how to fine tune your search results.
After the last AUR link above, the next hit on the list in the above search term was:
https://bbs.archlinux.org/viewtopic.php?id=259310
That hit was returned because the G2000 was listed in the Gutenrprint output of supported printers posted on that page.
If you can’t readily find the G2000 listed on a lengthy output on any given webpage the use the “Find in this page” feature (Firefox) to locate your model quickly if you can’t find it listed on a lengthy webpage.
To refine your web search even further you can limit to results from only the last year. With Google you can do this from the tools submenu:
Learning how to refine your search terms is 95% of the battle when looking for an answer to any issue in Linux. I do not own your hardware, so obviously I can’t troubleshoot your issue for you. The only one who can do that is someone with your printer model. So until someone responds to your thread that actually has the same printer, I’d suggest refining your search and following the information from Arch Linux related distros first. The best forums to include your search terms are, Arch, Garuda, EndeavourOS, and Manjaro forums.
try to build canon capt driver or cnjfilter or cnjifilter2
maybe it helps
cnijfilter2 link above ^^^
As listed in my search results gutenprint and cnijfilter2 seem the most likely candidates.
