Hi Folks,
One thing I noticed about the conkys provided by Garuda is they have a black background. This may be fine for the default wallpaper, but I change wallpaper via a script.
I also installed the picom compositor (as I like translucent inactive windows) and when that is running, the conkys are transparent. But I know on my Debian machines I have conkys transparent without picom (the Debian conky configs don't work on Garuda- likely a different version or default settings).
I did check the configs and stack overflow, and it looks like the Garuda settings are right for transparent conkys. Not sure why mine are not. Its no biggie as I do run picom and that fixes the issue, but curious nonetheless. Thanks.
Kernel: 5.19.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=91f29d57-8423-442e-a227-98363728a986 rw rootflags=subvol=@
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Mini-pc System: Fanless Mini PC product: Quieter 3 v: N/A
serial: <superuser required> Chassis: type: 35 serial: <superuser required>
Mobo: Fanless Mini PC model: Rev JSL1 1.10 serial: <superuser required>
UEFI: American Megatrends LLC. v: ML_JPL1V3.2 date: 06/16/2022
Device-1: hidpp_battery_7 model: Logitech MX Vertical Advanced Ergonomic
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: Intel Celeron N5105 bits: 64 type: MCP arch: Tremont
built: 2019 process: Intel 10nm family: 6 model-id: 0x9C (156) stepping: 0
microcode: 0x24000023
desc: d-4x32 KiB; i-4x32 KiB L2: 1.5 MiB desc: 1x1.5 MiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 770 high: 792 min/max: 800/2900 scaling:
driver: intel_pstate governor: powersave cores: 1: 787 2: 792 3: 718 4: 786
bogomips: 15974
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
filling, PBRSB-eIBRS: Not affected
Device-1: Intel JasperLake [UHD Graphics] driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: HDMI-A-2
empty: DP-1,HDMI-A-1,HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:4e61
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: modesetting
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: LG (GoldStar) ULTRAWIDE
serial: <filter> built: 2016 res: 3440x1440 hz: 60 dpi: 109 gamma: 1.2
size: 800x335mm (31.5x13.19") diag: 867mm (34.1") modes: max: 3440x1440
min: 640x480
Device-1: Intel Jasper Lake HD Audio vendor: Realtek driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:4dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.19.6-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 160MHz driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:4df0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
bus-ID: 1-8:5 chip-ID: 8087:0026 class-ID: e001
address: <filter>
Local Storage: total: 230.47 GiB used: 35.67 GiB (15.5%)
ID-1: /dev/mmcblk1 maj-min: 179:0 model: A3A444 size: 230.47 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
rev: 0x8 scheme: GPT
ID-1: / raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 14.32 GiB
(9.1%) fs: btrfs dev: /dev/mmcblk1p4 maj-min: 179:4
(0.2%) fs: vfat dev: /dev/mmcblk1p1 maj-min: 179:1
ID-3: /home raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 14.32
GiB (9.1%) fs: btrfs dev: /dev/mmcblk1p4 maj-min: 179:4
ID-4: /var/log raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 14.32
ID-5: /var/tmp raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 14.32
ID-1: swap-1 type: zram size: 7.52 GiB used: 857.5 MiB (11.1%)
priority: -2 dev: /dev/mmcblk1p3 maj-min: 179:3
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 286 Uptime: 2d 3h 21m wakeups: 5294 Memory: 7.52 GiB used: 3.7
GiB (49.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1282 lib: 326 Shell: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-27
Last full system update: 2022-09-03
