Trying to get a conky to work that requires lua bindings
When I install from Add/Remove software I get conky v1.20.2 and conky-manager v2.4.
but neither install with lua-bindings, looks like Cairo, Imlib2, and RSVG needs to be installed. Note: on another PC this conky works the conky version is 1.19.6,
on this one it is 1.19.7 not sure if that is the case, how can I fix this?
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f05fdfe0-830a-4af8-ae75-692329a3c995 rw rootflags=subvol=@
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Dell product: Inspiron 3670 v: N/A
Mobo: Dell model: 0H4VK7 v: A01 serial: <superuser required> part-nu: 0868
uuid: <superuser required> UEFI: Dell v: 2.21.0 date: 12/03/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Info: model: Intel Core i5-9600K bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF6
desc: 1x9 MiB
Speed (MHz): avg: 2040 high: 4584 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 4584 2: 800 3: 4456
4: 800 5: 800 6: 800 bogomips: 44398
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
ports: active: none empty: DP-1,DP-2,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e98 class-ID: 0380
Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
v: 550.76 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-04; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
ports: active: none off: HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:1d01 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa
dri: iris gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x331mm (23.70x13.03")
s-diag: 687mm (27.05")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Acer KB272HL H
serial: <filter> built: 2022 res: 1920x1080 hz: 75 dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.76
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce GT 1030 driver: nvidia v: 550.76 device-ID: 10de:1d01
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD
Graphics 630 (CFL GT2) driver: mesa intel v: 24.0.6-arch1.2
device-ID: 8086:3e98 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.6-arch1.2 (LLVM
Device-2: NVIDIA GP108 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api tools: N/A
Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3
IF: enp3s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Local Storage: total: 2.27 TiB used: 692.59 GiB (29.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 25.9 C
model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
scheme: MBR
ID-1: / raw-size: 232.52 GiB size: 232.52 GiB (100.00%)
used: 25.09 GiB (10.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 35.7 MiB (37.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 232.52 GiB size: 232.52 GiB (100.00%)
ID-4: /var/log raw-size: 232.52 GiB size: 232.52 GiB (100.00%)
ID-5: /var/tmp raw-size: 232.52 GiB size: 232.52 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.14 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
System Temperatures: cpu: 32.0 C pch: 37.0 C mobo: 28.0 C gpu: nvidia
temp: 38 C
Fan Speeds (rpm): fan-1: 980 gpu: nvidia fan: 34%
Memory: total: 32 GiB available: 31.14 GiB used: 2.32 GiB (7.4%)
Processes: 285 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.41 GiB services: csd-power,upowerd
Packages: pm: pacman pkgs: 1691 libs: 506 tools: pamac,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: gnome-terminal inxi: 3.3.34
error: could not register 'chaotic-aur' database (database already registered)
System install date: 2024-04-23
Last full system update: 2024-04-29
Windows dual boot: Yes
