Hi All,
I am running Garuda, and have put a custom conky.conf in my home folder.
I have added conky -c /path/to/conky.conf to Autostart and it starts no problems. However the original conky and conf is also loading.
What i can’t figure out is where in Garuda would have the original conky autostart as only the instance i added to autostart shows.
╰─λ garuda-inxi
Kernel: 6.12.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=df6fd518-165d-4867-86ef-ab006d0682aa rw rootflags=subvol=@
quiet resume=UUID=ada50c83-c90d-40c2-8c48-3f65a2a2a2d8 loglevel=3 ibt=off
Type: Laptop System: Acer product: Aspire A315-23 v: V1.21
Mobo: DL model: Lotus_DA v: V1.21 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.21
date: 09/08/2022
ID-1: BAT1 charge: 33.1 Wh (100.0%) condition: 33.1/37.0 Wh (89.3%)
volts: 8.6 min: 7.7 model: PANASONIC AP16M5J type: Li-ion serial: <filter>
status: full
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1564 min/max: 1400/2100 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 1564 2: 1564 3: 1564
4: 1564 5: 1564 6: 1564 7: 1564 8: 1564 bogomips: 33598
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Acer Incorporated ALI
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
temp: 63.0 C
Device-2: Quanta VGA WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0408:a031
Monitor-1: eDP-1 model: AU Optronics 0xe997 built: 2021 res:
mode: 1920x1080 hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 142 gamma: 1.2
max: 1920x1080 min: 640x480
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven LLVM 19.1.7 DRM 3.59 6.12.10-zen1-1-zen)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: N/A device-ID: 1002:15d8
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de
vendor: Acer Incorporated ALI driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.10-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 8087:0aa7
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 476.94 GiB used: 39.19 GiB (8.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1114 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21113000 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 46.12 GiB size: 46.12 GiB (100.00%)
used: 15.02 GiB (32.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 1.88 GiB size: 1.87 GiB (99.80%)
used: 584 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 426.96 GiB size: 426.96 GiB (100.00%)
used: 24.17 GiB (5.7%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 46.12 GiB size: 46.12 GiB (100.00%)
ID-5: /var/tmp raw-size: 46.12 GiB size: 46.12 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.72 GiB used: 284.5 MiB (4.9%)
max-streams: 8 dev: /dev/zram0
ID-2: swap-2 type: partition size: 1.98 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 62.0 C mobo: N/A gpu: amdgpu temp: 62.0 C
Memory: total: 6 GiB available: 5.72 GiB used: 3.25 GiB (56.8%)
Processes: 326 Power: uptime: 36m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.28 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1847 libs: 567 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date: 2025-01-27
Last full system update: 2025-01-28
Thanks in advance
