Hello all,
So I'm running into an issue. Conky is missing module 'cairo' and it appears to not have lua supported. I'm using the version of conky that is installed by default with Garuda - i3.
This appears to be the exact same issue as this. [Cairo module not found]
conky: llua_load: $HOME/.conky/scifi/lua/battery.lua:1: module 'cairo' not found:
no field package.preload['cairo']
no file '/usr/share/lua/5.4/cairo.lua'
no file '/usr/share/lua/5.4/cairo/init.lua'
no file '/usr/lib/lua/5.4/cairo.lua'
no file '/usr/lib/lua/5.4/cairo/init.lua'
no file './cairo.lua'
no file './cairo/init.lua'
no file '/usr/lib/conky/libcairo.so'
no file '/usr/lib/lua/5.4/cairo.so'
no file '/usr/lib/lua/5.4/loadall.so'
no file './cairo.so'
I've tried installing conky-lua-nv: (Target not found)
I've tried installing conky-lua: (Target not found)
I'm using all repos installed by default. (This is a new build)
I'm up to date on all default repos. (Including chaotic)
[[email protected] ~]$ sudo pacman -Syu conky-lua-nv
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
error: target not found: conky-lua-nv
[[email protected] ~]$ sudo pacman -Qi conky-lua-nv
error: package 'conky-lua-nv' was not found
error: package 'conky-lua' was not found
[[email protected] ~]$ cat /etc/*release*
DISTRIB_ID=Garuda
DISTRIB_RELEASE=Soaring
DISTRIB_DESCRIPTION="Garuda Linux"
DISTRIB_CODENAME="Talon"
NAME="Garuda Linux"
PRETTY_NAME="Garuda Linux"
ID=garuda
ID_LIKE=arch
BUILD_ID=rolling
ANSI_COLOR="38;2;23;147;209"
HOME_URL="https://garudalinux.org/"
DOCUMENTATION_URL="https://wiki.garudalinux.org/"
SUPPORT_URL="https://forum.garudalinux.org/"
BUG_REPORT_URL="https://gitlab.com/groups/garuda-linux/"
PRIVACY_POLICY_URL="https://terms.archlinux.org/docs/privacy-policy/"
LOGO=garudalinux
[[email protected] etc]$ conky -v
conky 1.15.0_pre compiled 2022-11-05 for Linux x86_64
Compiled in features:
System config file: /etc/conky/conky.conf
Package library path: /usr/lib/conky
General:
* math
* hddtemp
* portmon
* IPv6
* Curl
* RSS
* wireless
* support for IBM/Lenovo notebooks
* nvidia
* builtin default configuration
* old configuration syntax
* Imlib2
* OSS mixer support
* apcupsd
* iostats
* ncurses
* Internationalization support
* PulseAudio
X11:
* Xdamage extension
* Xinerama extension (virtual display)
* Xshape extension (click through)
* XDBE (double buffer extension)
* Xft
* ARGB visual
* Own window
Music detection:
* CMUS
* MPD
* MOC
Default values:
* Netdevice: eno1
* Local configfile: $HOME/.conkyrc
* Localedir: /usr/share/locale
* Maximum netdevices: 256
* Maximum text size: 16384
* Size text buffer: 256
Thank you very much for any assistance.
