I am new to Gurada, I am coming from old linux (1.2.13 slakware 3.0), BDS, SunOS, Solaris, debian based linux.
I have install Gurada dragonized LXQT, I want to configure a static IP. NetworkManager does not run.
I have looked for the files to manually configure the network, I can not locate them.
I have also tried to run nmcli, it shows the device:
nmcli con show
NAME UUID TYPE DEVICE
Wired connection 1 39f2a027-c38b-36de-9dfa-763838653701 ethernet enp2s0
when I try to use nmcli to set the static ip it shows:
sudo nmcli con mod enp2s0 ipv4.addresses 10.0.0.199/24
Error: unknown connection 'enp2s0'.
I have another gurada running, but it is installed with the dragonized KDE, and everything works, was able to configure the network, using the Network Manager
help me please ( my skill level is above novice )
gurada.inxi
Kernel: 6.2.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=8a31b41c-2103-41cc-a76d-314bf4e0d78c rw [email protected]
loglevel=3 ibt=off
Desktop: LXQt v: 1.2.1 tk: Qt v: 5.15.8 info: cairo-dock, lxqt-panel
Type: Desktop Mobo: AZW model: GTR v: V02 serial: <filter> UEFI: American
Megatrends LLC. v: GTR6_P5C4V16 date: 11/08/2022
Info: model: AMD Ryzen 9 6900HX with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1700 high: 1800 min/max: 1600/4934 boost: enabled
base/boost: 3300/4925 scaling: driver: acpi-cpufreq governor: ondemand
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1800 2: 1600 3: 1600 4: 1600
5: 1800 6: 1600 7: 1600 8: 1600 9: 1800 10: 1600 11: 1800 12: 1800
13: 1800 14: 1600 15: 1800 16: 1800 bogomips: 105398
Device-1: AMD Rembrandt [Radeon 680M] driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,
DP-2, DP-3, DP-4, HDMI-A-3, HDMI-A-4 bus-ID: 05:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 43.0 C
Screen-1: 0 s-res: 2880x1200 s-dpi: 96 s-size: 762x317mm (30.00x12.48")
s-diag: 825mm (32.49")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: Dell 2007FP
serial: <filter> built: 2006 res: 1600x1200 hz: 60 dpi: 111 gamma: 1.2
size: 367x275mm (14.45x10.83") diag: 514mm (20.2") ratio: 4:3, 5:4 modes:
max: 1600x1200 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: right model: Dell 1901FP
serial: <filter> built: 2004 res: 1280x1024 hz: 60 dpi: 86 gamma: 1.2
size: 376x301mm (14.8x11.85") diag: 490mm (19.3") ratio: 5:4 modes:
max: 1280x1024 min: 720x400
missing.
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp6x
v: kernel
alternate: snd_pci_acp3x,snd_rn_pci_acp3x,snd_pci_acp5x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Realtek
Sound API: ALSA v: k6.2.1-zen1-1-zen running: yes
Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 8086:15f3
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
Local Storage: total: 476.94 GiB used: 114.56 GiB (24.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000S512G
lanes: 4 type: SSD serial: <filter> rev: EIFK31.6 temp: 26.9 C scheme: GPT
SMART: yes health: PASSED on: 92 hrs cycles: 21
read-units: 4,705,803 [2.40 TB] written-units: 4,911,094 [2.51 TB]
used: 114.55 GiB (24.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.38 GiB used: 77.8 MiB (0.5%)
System Temperatures: cpu: 47.9 C mobo: N/A gpu: amdgpu temp: 44.0 C
Processes: 351 Uptime: 1d 18h 56m wakeups: 0 Memory: 15.38 GiB
used: 4.93 GiB (32.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1177
libs: 317 tools: octopi,paru Shell: Bash v: 5.1.16 running-in: qterminal
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-02
Last full system update: 2023-03-02
