Hi there,
Since i installed Garuda, i can't shutdown my computer properly. It shuts down, the PSU goes into standby mode (visible because my case LEDs and fans turn off), then immadiately turns back on.
Then, i can't even shut down the machine by pushing the power button, it always turns back on until i allow it to get to the login screen.
Then, shutting down from the login screen actually does work.
I have wake by PCI-e enabled in UEFI, and disabling it solves the issue.
However, and i need it enabled as i often use wake-on-lan to remotely boot my machine.
I tried logging off and then shutting down from the login screen, it doesn't work either.
The only way to shut down my machine properly appears to be doing it from the login screen, without ever opening a session.
=> It looks like something in my user session initialization is messing up with my hardware (possibly wake-on-lan ?) but i don't know how to dig deeper in this issue.
Kernel: 6.2.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=9524c41d-7c0a-4cf5-8fb0-d3ae1cafffe9 rw [email protected]
resume=UUID=b2ca9daf-41fe-4f98-b519-e2dd36230aa8 loglevel=3
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG STRIX B550-A GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2803
date: 04/27/2022
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3524 high: 3601 min/max: 2200/4467 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3601 2: 3500
3: 3500 4: 3500 5: 3500 6: 3500 7: 3500 8: 3500 9: 3500 10: 3500 11: 3600
12: 3589 bogomips: 84004
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
empty: DP-1,DP-3,HDMI-A-1 bus-ID: 0d:00.0 chip-ID: 1002:73df
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-2.1:4 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
s-diag: 777mm (30.58")
Monitor-1: DP-2 mapped: DisplayPort-1 model: AOC Q3279WG5B
serial: <filter> built: 2017 res: 2560x1440 hz: 60 dpi: 90 gamma: 1.2
size: 725x428mm (28.54x16.85") diag: 842mm (33.1") ratio: 15:9 modes:
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.49 6.2.6-zen1-1-zen) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 2-2.1:4 pcie: chip-ID: 046d:0825 gen: 4 speed: 16 GT/s
class-ID: 0102 serial: <filter> lanes: 16 bus-ID: 0d:00.1
chip-ID: 1002:ab28 class-ID: 0403
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Device-4: ASUSTek STRIX SOUND CARD type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 0b05:180d
Sound API: ALSA v: k6.2.6-zen1-1-zen running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 07:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-7.2:4
chip-ID: 13d3:3501 class-ID: e001
Local Storage: total: 3.09 TiB used: 330.53 GiB (10.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 950 PRO 256GB
lanes: 4 type: SSD serial: <filter> rev: 2B0QBXX7 temp: 32.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Kingston model: SNV2S500G
lanes: 4 type: SSD serial: <filter> rev: ELFK0S.6 temp: 31.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1CH164
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT256MX100SSD1
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: MU02
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 PRO Series
type: SSD serial: <filter> rev: 6B0Q
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Generic
model: MassStorageClass size: 119.08 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1536 scheme: MBR
ID-1: / raw-size: 457.65 GiB size: 457.65 GiB (100.00%)
used: 17.52 GiB (3.8%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:8
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-3: /home raw-size: 457.65 GiB size: 457.65 GiB (100.00%)
ID-4: /var/log raw-size: 457.65 GiB size: 457.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 457.65 GiB size: 457.65 GiB (100.00%)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:7
ID-2: swap-2 type: zram size: 31.23 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
mem: 40.0 C
Processes: 360 Uptime: 2m wakeups: 0 Memory: 31.23 GiB
used: 3.51 GiB (11.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1403
libs: 414 tools: octopi,pamac,paru pm: rpm pkgs: 0 Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-15
Last full system update: 2023-03-16
