Computer locked to Read Only File System
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Kernel: 6.5.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6979cba8-2da6-4305-857e-53a090d535f5 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: PRIME X670-P WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0823
date: 11/21/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 819 high: 5438 min/max: 400/5453 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 400 2: 400 3: 400
4: 5438 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 112586
Device-1: AMD Navi 33 [Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0
chip-ID: 1002:7480 class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4,HDMI-A-2
bus-ID: 12:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 41.0 C
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: D40fM-K09 built: 2022
res: 1920x1080 hz: 60 dpi: 69 gamma: 1.2 size: 708x398mm (27.87x15.67")
diag: 1016mm (40") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.8-arch1.1 renderer: AMD Radeon Graphics
(gfx1102 LLVM 16.0.6 DRM 3.54 6.5.4-zen2-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 12:00.1 chip-ID: 1002:1640 class-ID: 0403
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.4-zen2-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-2: Realtek vendor: AzureWave driver: rtw89_8852be v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 0b:00.0
chip-ID: 10ec:b852 class-ID: 0280
IF: wlp11s0 state: down mac: <filter>
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 13d3:3571
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.82 TiB used: 82.06 GiB (4.4%)
fw-rev: 2B2QEXM7 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 82.06 GiB (4.4%)
used: 82.06 GiB (4.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.4 C mobo: N/A
GPU: device: amdgpu temp: 41.0 C device: amdgpu temp: 36.0 C mem: 53.0 C
fan: 0 watts: 6.00
Processes: 361 Uptime: 19m wakeups: 4 Memory: total: 32 GiB note: est.
available: 30.5 GiB used: 4.04 GiB (13.3%) Init: systemd v: 254
pm: pacman pkgs: 1441 libs: 461 tools: gnome-software,octopi,pamac,paru
inxi: 3.3.29
System install date:     2023-09-15
Last full system update: 2023-09-22
Refusing to post the output of the required “garuda-inxi” on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki’s, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum’s search engine and on the web. For in depth information on how to search for answers to Linux issues effectively, read the tips on the Garuda Wiki:
Hi @Popcorn, it looks like you forgot to describe the issue you are having, and the troubleshooting efforts you have made so far.
