Compositor issue in dragonized theme
Hello Garuda users.
  Kernel: 6.6.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=72c3be24-4850-491b-b0e7-452666bb84ca rw rootflags=subvol=@
    libata.noacpi=1 nvidia_drm.modeset=1 quiet rd.udev.log_priority=3
    vt.global_cursor_default=0
    resume=UUID=306bb7f3-2d0e-4cd2-912b-fb63ee6367f5 loglevel=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
  Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
    v: 098C110000404100000610180 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 2166 v: 29.42 serial: <superuser required>
    UEFI: Insyde v: F.71 date: 03/13/2017
  ID-1: BAT0 charge: 17.0 Wh (100.0%) condition: 17.0/17.0 Wh (100.0%)
    volts: 16.7 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
    serial: N/A status: full
  Info: model: Intel Core i7-4500U bits: 64 type: MT MCP arch: Haswell
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 2694 min/max: 800/3000 scaling: driver: intel_cpufreq
    governor: performance cores: 1: 2694 2: 2694 3: 2694 4: 2694 bogomips: 19154
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
    active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0a16
  Device-2: NVIDIA GK208M [GeForce GT 740M] vendor: Hewlett-Packard
    driver: nvidia v: 470.223.02 alternate: nouveau,nvidia_drm non-free:
    series: 470.xx+ status: legacy-active (EOL~2024-09-xx) arch: Kepler
    code: GKxxx process: TSMC 28nm built: 2012-2018 pcie: gen: 2 speed: 5 GT/s
    lanes: 4 link-max: lanes: 8 bus-ID: 0a:00.0 chip-ID: 10de:1292
    class-ID: 0302
  Device-3: Cheng Uei Precision Industry (Foxlink) Webcam driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-3:2
    chip-ID: 05c8:036e class-ID: 0e02
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 mapped: eDP-1-1 model: Samsung 0x4651 built: 2012
    res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia x11:
    drv: nvidia inactive: gbm,wayland,surfaceless,device-1,device-2,device-3
  API: OpenGL v: 4.6.0 vendor: nvidia v: 470.223.02 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GT 740M/PCIe/SSE2
    memory: 1.95 GiB
  API: Vulkan v: 1.3.269 layers: 11 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GT 740M driver: nvidia v: 470.223.02
    device-ID: 10de:1292 surfaces: xcb,xlib
  Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
  Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard 8
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
  API: ALSA v: k6.6.5-zen1-1-zen status: kernel-api with: 1: aoss
    type: oss-emulator 2: apulse type: pulse-emulator
  Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard
    driver: rt2800pci v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 08:00.0 chip-ID: 1814:3290 class-ID: 0280
  IF: wlan0 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
    lanes: 1 port: 4000 bus-ID: 09:00.0 chip-ID: 10ec:8136 class-ID: 0200
  Device-1: Ralink RT3290 Bluetooth vendor: Hewlett-Packard driver: rtbt
    alternate: rtbth pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.1
    chip-ID: 1814:3298 class-ID: 0d11
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 2.1
    lmp-v: 4 status: discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 238.47 GiB used: 85.01 GiB (35.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SKC600 256G
    tech: SSD serial: <filter> fw-rev: 426H scheme: GPT
  ID-1: / raw-size: 119.14 GiB size: 119.14 GiB (100.00%)
    used: 25.29 GiB (21.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 1000.1 MiB size: 998.1 MiB (99.80%)
    used: 155.2 MiB (15.6%) fs: vfat dev: /dev/sda4 maj-min: 8:4
  ID-3: /home raw-size: 110.35 GiB size: 110.35 GiB (100.00%)
    used: 59.57 GiB (54.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-4: /var/log raw-size: 119.14 GiB size: 119.14 GiB (100.00%)
  ID-5: /var/tmp raw-size: 119.14 GiB size: 119.14 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.69 GiB used: 923.8 MiB (11.7%)
  ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 70.0 C mobo: N/A gpu: nvidia temp: 67 C
  Processes: 267 Uptime: 11m wakeups: 0 Memory: total: 8 GiB
  available: 7.69 GiB used: 4.24 GiB (55.2%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 17.0.6
  Packages: pm: pacman pkgs: 1813 libs: 510 tools: octopi,paru Shell: fish
  v: 3.6.2 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-10-29
  Last full system update: 2023-12-09
  Is partially upgraded:   Yes
ok so the problem is that the animation stopped on the theme also i have black background in the topbar and apps menuon the botton using dragonized theme and kde plasma i also tried to reinstall the theme didnt fix it and i reset to default settings in the garuda assistant which didnt help too but i notice that when i use the intel gpu this problem occures while if i use only nvidia gpu the only thing missing is the logo in the fish terminal garuda logo output as numbers and letters or symbols not like the logo i tried restart kwin_x11 didnt fix it change compositor settings nothing happened also i got window called plasma renderer which doing nothing at all
system logs:
Dec 11 10:27:16 unkown-hp systemd-vconsole-setup[139]: /usr/bin/setfont failed with exit status 71.
Dec 11 10:27:17 unkown-hp kernel:
Dec 11 10:27:17 unkown-hp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.223.02  Sat Oct  7 15:39:11 UTC 2023
Dec 11 10:27:18 unkown-hp kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20230628/psargs-330)
Dec 11 10:27:18 unkown-hp kernel: ACPI Error: Aborting method \_SB.PCI0.RP05.PEGP.DD02._BCL due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Dec 11 10:27:21 unkown-hp systemd-udevd[449]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring.
Dec 11 10:27:22 unkown-hp systemd-tmpfiles[624]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
Dec 11 10:27:23 unkown-hp kernel: rtbt_hps_iface_attach ok
Dec 11 10:27:24 unkown-hp kernel: RTBTH_IOCDMAC: dmac.dmac_op=0
Dec 11 10:27:24 unkown-hp kernel: RTBTH_IOCDMAC: dmac.dmac_op=1
Dec 11 10:27:24 unkown-hp wpa_supplicant[928]: nl80211: kernel reports: Match already configured
Dec 11 10:27:24 unkown-hp libvirtd[893]: internal error: Unknown PCI header type '127' for device '0000:0a:00.0'
Dec 11 10:28:39 unkown-hp sudo[9311]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:28:47 unkown-hp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.223.02  Sat Oct  7 15:39:11 UTC 2023
Dec 11 10:28:59 unkown-hp sudo[11577]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:29:45 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2
Dec 11 10:29:45 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 2
Dec 11 10:29:45 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Dec 11 10:29:45 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Dec 11 10:29:45 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Dec 11 10:29:45 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Dec 11 10:29:45 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Dec 11 10:29:45 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Dec 11 10:29:45 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Dec 11 10:29:45 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Dec 11 10:29:51 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2
Dec 11 10:29:51 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 2
Dec 11 10:29:51 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Dec 11 10:29:51 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Dec 11 10:29:51 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Dec 11 10:29:51 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Dec 11 10:29:51 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Dec 11 10:29:51 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Dec 11 10:29:51 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Dec 11 10:29:51 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Dec 11 10:29:58 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 2
Dec 11 10:29:58 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 2
Dec 11 10:29:58 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Dec 11 10:29:58 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Dec 11 10:29:58 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Dec 11 10:29:58 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Dec 11 10:29:58 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Dec 11 10:29:58 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Dec 11 10:29:58 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Dec 11 10:29:58 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Dec 11 10:30:03 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
Dec 11 10:30:03 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:03 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Dec 11 10:30:03 unkown-hp kernel: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:03 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Dec 11 10:30:03 unkown-hp kernel: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:03 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Dec 11 10:30:03 unkown-hp kernel: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:03 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Dec 11 10:30:03 unkown-hp kernel: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:03 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Dec 11 10:30:03 unkown-hp kernel: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:03 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Dec 11 10:30:03 unkown-hp kernel: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:03 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Dec 11 10:30:03 unkown-hp kernel: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:03 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Dec 11 10:30:09 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2
Dec 11 10:30:09 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:09 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Dec 11 10:30:09 unkown-hp kernel: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 7 prio class 2
Dec 11 10:30:09 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Dec 11 10:30:09 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Dec 11 10:30:09 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Dec 11 10:30:09 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Dec 11 10:30:09 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Dec 11 10:30:09 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Dec 11 10:30:09 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Dec 11 10:30:16 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2
Dec 11 10:30:16 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 8 prio class 2
Dec 11 10:30:16 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Dec 11 10:30:16 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Dec 11 10:30:16 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Dec 11 10:30:16 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Dec 11 10:30:16 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Dec 11 10:30:16 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Dec 11 10:30:16 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Dec 11 10:30:16 unkown-hp kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Dec 11 10:30:16 unkown-hp kernel: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:16 unkown-hp kernel: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:16 unkown-hp kernel: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:16 unkown-hp kernel: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:16 unkown-hp kernel: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:16 unkown-hp kernel: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:30:16 unkown-hp kernel: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 11 10:32:25 unkown-hp kernel: sched: RT throttling activated
Dec 11 10:37:01 unkown-hp sudo[14321]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:37:12 unkown-hp sudo[14491]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:37:14 unkown-hp sudo[14513]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:39:12 unkown-hp sudo[14717]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:39:22 unkown-hp sudo[14750]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:39:31 unkown-hp sudo[14792]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:39:49 unkown-hp sudo[14846]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:40:03 unkown-hp sudo[14901]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:43:34 unkown-hp sudo[14988]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:44:43 unkown-hp sudo[15056]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:44:55 unkown-hp sudo[15121]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:44:57 unkown-hp sudo[15160]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:45:29 unkown-hp sudo[15195]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
Dec 11 10:45:41 unkown-hp sudo[15226]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
What “animation”?
Do you have an optical drive in your laptop?
Looks like a defect ISO, hardware error or the kernel has an error communicating with the disk controller:
etc...
the window animation like minimizing , maximizing and moving its only static but i fix it it was problem with the mesa opengl corrupted maybe or something idk thats why in nvidia the animation was working i just needed to reinstall mesa with its packages like opengl and that stuff
yes i have but i dont use it plus wdym hardware error??? bro dont scare the shit out of me XD
my hardware issue is a bit confusing its just when i hold the laptop from the corner it crashes because i mistakenly bend the gpu since the laptop heavy and kinda me stupid so if there is hardware error yes there is but only crash when the gpu get hit or something idk if its because not placed well in place or something bruh i think i will disassmeble it again to clean and i will check that, also my speakers not working i maybe forget to plugin or something maybe because of that.
but now my main problem is this which happened after updating linux-zen to 6.6.4 and after that its not leaving even after updating to 6.6.6 now and as i read its related to bios or something
Dec 12 10:32:38 unkown-hp kernel:
Dec 12 10:32:38 unkown-hp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.223.02  Sat Oct  7 15:39:11 UTC 2023
Dec 12 10:32:39 unkown-hp kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20230628/psargs-330)
Dec 12 10:32:39 unkown-hp kernel: ACPI Error: Aborting method \_SB.PCI0.RP05.PEGP.DD02._BCL due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
Dec 12 10:32:42 unkown-hp systemd-udevd[440]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring.
Dec 12 10:32:43 unkown-hp systemd-tmpfiles[604]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
Dec 12 10:32:44 unkown-hp kernel: rtbt_hps_iface_attach ok
Dec 12 10:32:45 unkown-hp kernel: RTBTH_IOCDMAC: dmac.dmac_op=0
Dec 12 10:32:45 unkown-hp kernel: RTBTH_IOCDMAC: dmac.dmac_op=1
here is the error whenever i boot what i want to fix now but this error popup with journalctl too
Dec 12 10:32:45 unkown-hp wpa_supplicant[873]: nl80211: kernel reports: Match already configured
Dec 12 10:32:45 unkown-hp libvirtd[880]: internal error: Unknown PCI header type '127' for device '0000:0a:00.0'
Dec 12 11:05:59 unkown-hp systemd-sleep[108434]: Failed to lock home directories: Unknown object '/org/freedesktop/home1'.
Dec 12 11:16:25 unkown-hp kernel: done.
Dec 12 11:16:27 unkown-hp kernel: Bluetooth: hci0: command 0x0c1a tx timeout
Dec 12 11:16:27 unkown-hp kernel: Bluetooth: hci0: Opcode 0x0c1a failed: -110
Dec 12 11:16:28 unkown-hp wpa_supplicant[873]: nl80211: kernel reports: Match already configured
Dec 12 12:12:44 unkown-hp pipewire[5649]: spa.alsa: front:2p: snd_pcm_status error: No such device
Dec 12 12:12:44 unkown-hp pipewire[5649]: spa.alsa: front:2p: snd_pcm_drop: No such device
Dec 12 12:12:44 unkown-hp pipewire[5649]: spa.alsa: sw_params: No such device
Dec 12 12:12:44 unkown-hp pipewire[5649]: spa.alsa: swparams: No such device
Dec 12 13:12:08 unkown-hp sudo[247170]:   unkown : a password is required ; TTY=pts/0 ; PWD=/home/unkown ; USER=root ; COMMAND=/usr/bin/true
some looks normal which can be ignored but there is bunch is wierd like pipewire oh is that because no speaker and popup when i plugin my headphones on or off maybe
thanks in advanced for help
also in dkms here
/var/lib/dkms
drwxr-xr-x    - root 11 Dec 12:08  bbswitch
drwxr-xr-x    - root 11 Dec 12:08  nvidia
drwxr-xr-x    - root 11 Dec 12:08  rtbth
drwxr-xr-x    - root  7 Dec 11:06  rtbth.ko
.rw------- 1.7k root 31 Oct 14:24  mok.key
.rw-r--r--  811 root 31 Oct 14:24 󰷖 mok.pub
as u see there is 2 rtbth and rtbth.ko ofc the rtbth is the one i want to keep it but the second one i want to remove it i got alot of errors because of it which annoying everyime i need to build initframs i tried dkms -remove command but it recreated it over and over is there any way to fix it?
The errors from the optical drive have nothing to do with your graphics issues, I just noticed them. So don’t panic, bro :slightly_smiling_face:
If I understood correctly, you have these problems with the iGPU AND the nVidia GPU?
And the condition of your hardware doesn’t sound good…
It is possible that the whole thing is actually a hardware defect and the kernel update is just a coincidence.
Have you ever tested whether a snapshot from before the update works?
Do you also have this issues with a live-iso?
ok i will try to test a live-bot now i forget if i have the iso still but i will try when i boot what error should i search and try to find or just give u the whole error logs i dont want to use snapshots and lose updates or needed packages i thus i will try live boot safer and more efficient if the errors visible or not
Note:i also booted to the linux kernel not zen the same error shows
 Dec 12 10:32:38 unkown-hp kernel: Dec 12 10:32:38 unkown-hp kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.223.02 Sat Oct 7 15:39:11 UTC 2023 Dec 12 10:32:39 unkown-hp kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20230628/psargs-330) Dec 12 10:32:39 unkown-hp kernel: ACPI Error: Aborting method \_SB.PCI0.RP05.PEGP.DD02._BCL due to previous error (AE_NOT_FOUND) (20230628/psparse-529) Dec 12 10:32:42 unkown-hp systemd-udevd[440]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring. Dec 12 10:32:43 unkown-hp systemd-tmpfiles[604]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted Dec 12 10:32:44 unkown-hp kernel: rtbt_hps_iface_attach ok Dec 12 10:32:45 unkown-hp kernel: RTBTH_IOCDMAC: dmac.dmac_op=0 Dec 12 10:32:45 unkown-hp kernel: RTBTH_IOCDMAC: dmac.dmac_op=1
the buffer errors also dont show right after i boot even afte i change with optimus manager to nvidia doesnt show i think it after heavy usage or time it shows idk
ok this doesn’t feel good umm…
Dec 12 14:15:05 garuda-dr460nized-gaming kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0.DD02._BCL], AE_NOT_FOUND (20221020/psargs-330)
Dec 12 14:15:05 garuda-dr460nized-gaming kernel: ACPI Error: Aborting method \_SB.PCI0.RP05.PEGP.DD02._BCL due to previous error (AE_NOT_FOUND) (20221020/psparse-529)
Dec 12 14:15:06 garuda-dr460nized-gaming systemd-udevd[568]: /usr/lib/udev/rules.d/55-Argyll.rules:157 Unknown group 'colord', ignoring
Dec 12 14:15:07 garuda-dr460nized-gaming (udev-worker)[570]: host4: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/host4/scsi_host/host4/link_power_management_policy}, ignoring: No such file or directory
Dec 12 14:15:08 garuda-dr460nized-gaming systemd-tmpfiles[645]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
Dec 12 14:15:16 garuda-dr460nized-gaming libvirtd[852]: internal error: Unknown PCI header type '127' for device '0000:09:00.0'
Dec 12 14:15:36 garuda-dr460nized-gaming systemd[1066]: /run/user/1000/systemd/generator.late/app-setup\x2danbox@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
Dec 12 14:15:46 garuda-dr460nized-gaming systemd[1066]: /run/user/1000/systemd/generator.late/app-setup\x2danbox@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
Dec 12 14:16:37 garuda-dr460nized-gaming konsole[2113]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Dec 12 14:16:37 garuda-dr460nized-gaming konsole[2113]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
i got the error using garuda live boot so yea i am gonna ignore it from now on
also i booted it with nvidia to make sure if there is anyerrors related will show
Slowly slowly, bro :slight_smile:
I think this is going in the wrong direction.
In addition, the topic becomes completely confusing. Please, follow the template and format your text corectly. Put the output from terminal between the ~~~.
And i personally don’t have time to copy your output in my editor and reformat this for better reading :upside_down_face:
Summary:
You have a problem with the dragonized theme and a ghost window called “Plasma Renderer”.
Resetting to default settings and reinstalling the theme didn’t work. You restarted kwin_x11 and changed the compositor settings. You had a problem with Mesa-OpenGL and fixed it.
You only have these issues with the Intel iGPU.
Everything works with the nVidia GPU except that the ASCII logo is displayed in the terminal.
Is that right?
Display server and compositor are working correctly according to your garuda-inxi.
You can ignore the ACPI BIOS Error and the other error messages.
The GPU Passthrough Error
i have that in the back of my mind.
We should first take a look at the intel-iGPU (if it is not defective):
post the output from
pacman -Qs intel
Second look go’s to x11:
  1. Go to /var/log/ and open the Xorg.0.log with an editor. Copy the entire content to https://bin.garudalinux.org/ and post the generated link here.
  2. On your desktop, close all open windows and press ctrl+alt+backspace to reset and restart the xserver. After that, is the ‘intel-iGPU’ and ‘plasma’ working correctly?
  3. Switch to wayland. Are the ‘intel-iGPU’ and ‘plasma’ working correctly?
  4. Create a new user account and log in. Are the ‘intel-iGPU’ and ‘plasma’ working correctly?
After these steps it is plasma’s turn.
EDIT: Have you tested another theme, like breeze or sweet ?
EDIT 2: Typo and additions.
EDIT 3: I think you don’t need to do steps 2, 3 and 4 under Second look go's to x11:, that doesn’t help. The problem is the intel IGPU.
ok haha thats because i was thinking and wiriting investigate think and right(edit:write* :melting_face:) :sweat_smile: :sweat_smile:
anyway i fixed it as i said the issue was with opengl i tried restart plasma and compositor reinstalling the dragonized theme and using the breeze and sweet nothing work untill i reinstall the mesa-opengl so i dont actually know the bug around it i think related to optimus manager sometimes its bugging when i change to integrated gpu but doesnt change and stuck in black screen so i think its the problem causing it anyway i know how to fix it now and its good so no need to open a conversation its fixed i will mark solution in a new replay.
i just noticed the gpu passthrough error related to the virtual machine hmm wierd since i wasnt using it before the post i just yesterday started to try and run the virtual machine and i tried to make gpu passthrough but its not detecting the gpu so i give up
anyway the ACPI BIOS ERROR do i ignore it or open new thread and ask about it or what i can do
