Hello.
today I had to format my pc and in the new installation the compositor effects are laggy.
In the live environment this does not happen.
I point out that I had also encountered this problem in the previous installation but I do not remember how I had managed to solve it.
Here is a video of the problem. The weird effect of the top bar is only in the video.
The place where it is most visible is on the latte bar.
https://drive.google.com/file/d/1ioBxYVc3c_9OJcRrUDU2ed6ww8qvNlwx/view
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=995b984e-0171-4ed2-adff-0bc76cdf57e5 rw [email protected]
resume=UUID=3aa21218-c4c0-4f6c-b01d-a03bd160addb loglevel=3
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Mobo: ASUSTeK model: ROG MAXIMUS XII FORMULA v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2301
date: 07/13/2021
ID-1: hidpp_battery_0 charge: 86% condition: N/A volts: 4.0 min: N/A
serial: <filter> status: Charging
Info: model: Intel Core i9-10900K bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xEE
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 5118 high: 5321 min/max: 800/5300 scaling:
driver: intel_pstate governor: performance cores: 1: 4992 2: 5009 3: 5153
4: 5134 5: 5311 6: 5175 7: 5116 8: 5216 9: 5157 10: 5078 11: 5000
12: 4941 13: 4996 14: 5013 15: 4994 16: 5150 17: 5304 18: 5300 19: 5321
20: 5012 bogomips: 147994
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1b81 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2.2:10 chip-ID: 046d:082d
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 7280x1440 s-dpi: 109 s-size: 1696x333mm (66.8x13.1")
s-diag: 1728mm (68")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 92
size: 530x300mm (20.9x11.8") diag: 609mm (24")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-3: DP-4 res: 3440x1440 hz: 50 dpi: 110
size: 797x334mm (31.4x13.1") diag: 864mm (34")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
Device-3: Logitech HD Pro Webcam C920 type: USB
Device-4: Generalplus USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:7 chip-ID: 1b3f:2008
Device-5: RODE Microphones RODE NT-USB type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 19f7:0003
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Device-2: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel port: N/A bus-ID: 04:00.0
chip-ID: 1d6a:07b1 class-ID: 0200
Device-3: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3 class-ID: 0200
bus-ID: 1-14:15 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Comet Lake PCH-H RAID driver: ahci v: 3.0 port: 4020
bus-ID: 00:17.0 chip-ID: 8086:06d6 rev: class-ID: 0104
Local Storage: total: 1.62 TiB used: 16.19 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT343.4
temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
type: SSD serial: <filter> rev: 2B6Q
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
type: SSD serial: <filter> rev: 1B6Q
ID-5: /dev/sdd maj-min: 8:48 type: USB model: NC Gameband size: 7.36 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 0200 scheme: MBR
ID-1: / raw-size: 919.29 GiB size: 919.29 GiB (100.00%)
used: 16.19 GiB (1.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 919.29 GiB size: 919.29 GiB (100.00%)
ID-4: /var/log raw-size: 919.29 GiB size: 919.29 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.29 GiB size: 919.29 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.28 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.16 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 32 C
Processes: 485 Uptime: 5m wakeups: 9 Memory: 31.16 GiB
used: 3.93 GiB (12.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1418 lib: 324 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-02-13
Last full system update: 2022-02-13
