Hello Garuda users.
I want to combine usr and home disk. I've tried everything and searched but I can't find any information about how to keep your data and combine the disk
Kernel: 5.19.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=942e0410-8851-489e-bbf4-992e2d631b1c rw rootflags=subvol=@
Type: Laptop System: Google product: Blooglet v: rev4
Mobo: HP model: Blooglet v: rev4 serial: <superuser required>
UEFI: coreboot v: MrChromebox-4.17.2 date: 07/18/2022
ID-1: BAT0 charge: 23.0 Wh (57.2%) condition: 40.2/47.4 Wh (84.9%)
volts: 7.5 min: 7.7 model: 333-1D- GH02047 type: Li-ion serial: <filter>
status: discharging cycles: 43
Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122) stepping: 8
microcode: 0x20
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1363 high: 1434 min/max: 800/2800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1434 2: 1293
bogomips: 4377
filling, PBRSB-eIBRS: Not affected
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0380
Device-2: Luxvisions Innotech HP Wide Vision HD Camera type: USB
driver: uvcvideo bus-ID: 1-7:3 chip-ID: 30c9:0016 class-ID: 0e02
compositor: kwin_x11 driver: gpu: i915 note: X driver n/a display-ID: :0
Monitor-1: eDP-1 model: LG Display 0x060f built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl
alternate: snd_hda_intel,snd_soc_skl,snd_soc_avs,snd_sof_pci_intel_apl
bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0401
Sound Server-1: ALSA v: k5.19.6-zen1-1-zen running: yes
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-3:2 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 26 state: up address: <filter>
Local Storage: total: 58.31 GiB used: 11.94 GiB (20.5%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: Kingston model: TA2964
size: 58.31 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x8 scheme: MBR
ID-1: / raw-size: 9.77 GiB size: 9.77 GiB (100.00%) used: 2.54 GiB (26.1%)
fs: btrfs dev: /dev/mmcblk0p3 maj-min: 179:3
ID-2: /boot/efi raw-size: 9.77 GiB size: 9.76 GiB (99.90%) used: 624 KiB
(0.0%) fs: vfat dev: /dev/mmcblk0p2 maj-min: 179:2
ID-3: /home raw-size: 29.01 GiB size: 29.01 GiB (100.00%) used: 2.35 GiB
(8.1%) fs: btrfs dev: /dev/mmcblk0p4 maj-min: 179:4
ID-4: /usr raw-size: 9.77 GiB size: 9.77 GiB (100.00%) used: 7.05 GiB
(72.2%) fs: btrfs dev: /dev/mmcblk0p1 maj-min: 179:1
ID-5: /var/log raw-size: 9.77 GiB size: 9.77 GiB (100.00%) used: 2.54 GiB
(26.1%) fs: btrfs dev: /dev/mmcblk0p3 maj-min: 179:3
ID-6: /var/tmp raw-size: 9.77 GiB size: 9.77 GiB (100.00%) used: 2.54 GiB
ID-1: swap-1 type: zram size: 3.7 GiB used: 1.05 GiB (28.5%)
System Temperatures: cpu: 84.0 C mobo: N/A
Processes: 221 Uptime: 1d 4h 32m wakeups: 43104 Memory: 3.7 GiB used: 2.41
GiB (65.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1473 lib: 440 Shell: fish v: 3.5.1
Garuda (2.6.6-1):
System install date: 2022-09-04
Last full system update: 2022-09-04 ↻
Failed units: logrotate.service systemd-vconsole-setup.service
