Color scheme
Kde doesn't change color scheme all the way I installed papirus colors icons and the color scheme on the folder icons won't change neither is there a fix?
Welcome to the Forum!
Are they supposed to change?
Every Color Scheme has their own implementation of which colors they choose to change.
This does not sound like a Color Scheme, but like an Icon Set, which is different.
Not all Color Schemes will affect the Icon Set, due to what I mentioned above.
So did you change the Color Scheme from the KDE System Setting (there is a section called Color Scheme) or you changed Icons from the KDE System Settings (there is a section called Icons)?
What is your exact expected result?
Some icon packages do change with color schemes, the Simple-Circles Icons change with scheme colors.
For the OP, it may depend on the icon set and what choices you have checked under System settings > Appearance > Colors > 'Use Accent Colors Section'.
Yup, precisely why I asked about this particular set. :slight_smile:
No garuda-inxi, no help.
KDE = Restart required, often, mostly, like F5 in Dolphin to refresh the content.
