Kernel: 5.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f10a4dac-1424-4f66-8ebc-827719049bb5 rw rootflags=subvol=@
resume=UUID=948b90c5-1b57-49fc-ae78-44be168d490d loglevel=3 nowatchdog
nvme_load=YES nvidia-drm.modeset=1
Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: Dell product: XPS 17 9700 v: N/A
Mobo: Dell model: 0P1CHN v: A00 serial: <superuser required> UEFI: Dell
v: 1.16.0 date: 05/12/2022
ID-1: BAT0 charge: 68.1 Wh (100.0%) condition: 68.1/95.1 Wh (71.7%)
volts: 12.6 min: 11.4 model: BYD DELL F8CPG07 type: Li-poly
serial: <filter> status: full
Info: model: Intel Core i7-10875H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 2 microcode: 0xF0
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2266 high: 2301 min/max: 800/2300 scaling:
driver: intel_pstate governor: powersave cores: 1: 2169 2: 2301 3: 2300
4: 2044 5: 2255 6: 2300 7: 2300 8: 2300 9: 2292 10: 2279 11: 2301
12: 2301 13: 2296 14: 2300 15: 2300 16: 2220 bogomips: 73598
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2060 Max-Q] vendor: Dell
driver: nvidia v: 515.48.07 non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: none empty: DP-4, DP-5, DP-6, DP-7 bus-ID: 01:00.0
chip-ID: 10de:1f12 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0c45:6a0c class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: intel,nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 2560x1600 s-dpi: 144 s-size: 451x282mm (17.76x11.10")
s-diag: 532mm (20.94")
Monitor-1: eDP-1 mapped: eDP1 model: Sharp 0x14d6 built: 2020
res: 2560x1600 hz: 60 dpi: 176 gamma: 1.2 size: 370x230mm (14.57x9.06")
diag: 432mm (17") ratio: 16:10 modes: 3840x2400
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8
class-ID: 0401
Sound Server-1: ALSA v: k5.18.6-zen1-1-zen running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
IF: wlan0 state: up mac: <filter>
bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 1.86 TiB used: 969.96 GiB (50.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA
model: KXG60PNV2T04 NVMe 2048GB size: 1.86 TiB block-size: physical: 512 B
rev: 10704104 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 1.34 TiB size: 1.34 TiB (100.00%)
used: 967.63 GiB (70.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 592 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 1.34 TiB size: 1.34 TiB (100.00%)
ID-4: /var/log raw-size: 1.34 TiB size: 1.34 TiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 20 GiB used: 2.33 GiB (11.7%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 46.0 C pch: 54.0 C mobo: 40.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 395 Uptime: 1h 58m wakeups: 7110 Memory: 15.37 GiB
used: 6.2 GiB (40.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 2029
lib: 525 flatpak: 0 Shell: fish v: 3.4.1 running-in: konsole inxi: 3.3.19
After Task Switching the Close/Minimize/Maximize buttons Disappear
❯ firedragon
ATTENTION: default value of option mesa_glthread overridden by environment.
JavaScript error: resource://gre/modules/XULStore.jsm, line 66: Error: Can't find profile directory.
Missing chrome or resource URL: resource://gre/modules/UpdateListener.jsm
[Parent 80734, Main Thread] WARNING: dbusmenu_menuitem_property_set_shortcut: assertion 'gtk_accelerator_valid(key, modifier)' failed: 'glib warning', file /home/main-builder/pkgwork/src/firefox-101.0.1/toolkit/xre/nsSigHandlers.cpp:167
(firedragon:80734): LIBDBUSMENU-GTK-CRITICAL **: 09:01:23.770: dbusmenu_menuitem_property_set_shortcut: assertion 'gtk_accelerator_valid(key, modifier)' failed
