Clicking sound instead of notification sound when discord plays audio
Hello!
I searched for an answer on this admittedly very quickly, because I vaguely remember another user having the same issue…
I’ve recently migrated my installation off of one of my hard drives onto a new hard drive because I was giving that hard drive to my partner. With my new installation, i’m experiencing a clicking sound in place of a notification sound when discord notifies me. It’s relatively intermittent, happens sometimes when discord has gone a while without playing a sound, but sometimes plays the sound no problem. I’m really bad with sound troubleshooting and I don’t know where to start. This wasn’t an issue in my prior installation.
Any help appreciated!
  Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=47e881e9-7adb-48dc-8263-4f88266918af rw rootflags=subvol=@
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
  Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <superuser required>
    BIOS: American Megatrends LLC. v: F34 date: 06/10/2021
  ID-1: hidpp_battery_8 charge: 89% condition: N/A volts: 4.1 min: N/A
  Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 3
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
    L3: 64 MiB desc: 4x16 MiB
  Speed (MHz): avg: 3769 high: 4441 min/max: 2200/4761 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3500 2: 3500
    3: 3505 4: 3500 5: 4441 6: 4266 7: 4251 8: 4276 9: 3500 10: 3813 11: 3500
    12: 4267 13: 3500 14: 3500 15: 3500 16: 3500 17: 3593 18: 3500 19: 3500
    20: 3500 21: 4419 22: 4313 23: 4415 24: 4279 25: 3500 26: 3500 27: 4213
    28: 3564 29: 3500 30: 3500 31: 3500 32: 3500 bogomips: 223581
  Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI
    status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
    lanes: 16 ports: active: none off: DP-1,DP-2 empty: DP-3,HDMI-A-1
    bus-ID: 0a:00.0 chip-ID: 10de:1e84 class-ID: 0300
  Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-3.4:10
    chip-ID: 046d:085c class-ID: 0102 serial: <filter>
  Screen-1: 0 s-res: 5120x1440 s-dpi: 108 s-size: 1204x342mm (47.40x13.46")
    s-diag: 1252mm (49.28")
  Monitor-1: DP-1 mapped: DP-0 note: disabled pos: left model: Dell S2716DG
    serial: <filter> built: 2016 res: 2560x1440 dpi: 109 gamma: 1.2
    max: 2560x1440 min: 640x480
  Monitor-2: DP-2 note: disabled pos: primary,right model: VG27A
    serial: <filter> built: 2020 res: 2560x1440 dpi: 109 gamma: 1.2
    inactive: wayland,device-1
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070
    SUPER/PCIe/SSE2 memory: 7.81 GiB
  API: Vulkan v: 1.3.269 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 2070 SUPER driver: nvidia v: 545.29.06 device-ID: 10de:1e84
    surfaces: xcb,xlib
  Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1
  Device-3: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1:2
    chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
  Device-4: Texas Instruments ATH-G1WL
    lanes: 1 mode: 1.1 bus-ID: 7-3.3:9 chip-ID: 0451:16ba class-ID: 0300
  Device-5: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api with: aoss
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
  Device-2: Intel 82575EB Gigabit Network driver: igb v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 link-max: lanes: 4 port: d020 bus-ID: 06:00.0
    chip-ID: 8086:10a7 class-ID: 0200
  IF: enp6s0f0 state: down mac: <filter>
  Device-3: Intel 82575EB Gigabit Network driver: igb v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 link-max: lanes: 4 port: d000 bus-ID: 06:00.1
  IF: enp6s0f1 state: down mac: <filter>
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2:3 chip-ID: 2357:0604
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
  Local Storage: total: 3.66 TiB used: 632.39 GiB (16.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SanDisk model: ADATA SX6000PNP
    lanes: 4 tech: SSD serial: <filter> fw-rev: V9002s85 temp: 35.9 C
    model: WDS100T1XHE-00AFY0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 614600WD temp: 38.9 C scheme: MBR
    model: WD20EARX-00ZUDB0 size: 1.82 TiB block-size: physical: 4096 B
    fw-rev: 0A80 scheme: GPT
    used: 132.4 GiB (14.2%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:1
  ID-1: swap-1 type: zram size: 31.28 GiB used: 43.5 MiB (0.1%)
    priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32
  System Temperatures: cpu: 50.0 C mobo: 27.0 C gpu: nvidia temp: 44 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 23%
  Processes: 614 Uptime: 29m wakeups: 0 Memory: total: 32 GiB
  available: 31.28 GiB used: 9.22 GiB (29.5%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1917 libs: 558 tools: octopi,paru Shell: fish
  v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-11-12
  Last full system update: 2023-12-01
