I use xdg-ninja and antidot to cleanup dotfiles. Then add the environment variables given by xdg-ninja in ./local/share/antidot/env.sh and then add the command given by antidot (antidot init) in .profile.
I could not remove .xsession-errors from $HOME. The xdg-ninja asked to add ERRFILE="$XDG_CACHE_HOME/X11/xsession-errors" to .xinitrc. But it has not worked. How do I remove .xsession-errors too?
Edit: do try both xdg-ninja and antidot. Although I warn something might break. I could not login before because of some mess with .Xauthority file having env variable.
Kernel: 5.15.40-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=bef56164-5782-4129-94fa-5969dc499b60 rw rootflags=subvol=@
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 dm: LightDM v: 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: N/A
Mobo: HP model: 81EC v: 61.59 serial: <filter> UEFI: Insyde v: F.46
date: 11/16/2018
ID-1: BAT1 charge: 2.5 Wh (100.0%) condition: 2.5/32.1 Wh (7.8%)
volts: 16.4 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-6200U socket: U3E1 bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2300 min/max: 400/2800 base/boost: 2200/8300 scaling:
driver: intel_pstate governor: performance volts: 0.8 V ext-clock: 100 MHz
cores: 1: 2300 2: 2300 3: 2300 4: 2300 bogomips: 19200
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu pcie:
gen: 3 speed: 8 GT/s lanes: 4 link-max: lanes: 8 bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Chicony HP TrueVision HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04f2:b56c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: intel,radeon unloaded: modesetting alternate: fbdev,vesa
Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x0687 built: 2015
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
Sound Server-1: ALSA v: k5.15.40-1-lts running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard
bus-ID: 03:00.0 chip-ID: 14e4:4365 class-ID: 0280
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-4:2 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 931.51 GiB used: 39.64 GiB (4.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100M
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1U scheme: GPT
ID-1: / raw-size: 96.68 GiB size: 96.68 GiB (100.00%)
used: 39.6 GiB (41.0%) fs: btrfs block-size: 4096 B dev: /dev/sda7
maj-min: 8:7
ID-2: /boot/efi raw-size: 102 MiB size: 96 MiB (94.12%)
used: 42.7 MiB (44.5%) fs: vfat block-size: 512 B dev: /dev/sda2
maj-min: 8:2
ID-3: /home raw-size: 96.68 GiB size: 96.68 GiB (100.00%)
maj-min: 8:7
ID-4: /var/log raw-size: 96.68 GiB size: 96.68 GiB (100.00%)
maj-min: 8:7
ID-5: /var/tmp raw-size: 96.68 GiB size: 96.68 GiB (100.00%)
maj-min: 8:7
ID-1: swap-1 type: zram size: 3.6 GiB used: 1.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C pch: 35.5 C mobo: 27.8 C gpu: radeon
temp: 35.0 C
Processes: 220 Uptime: 36m wakeups: 2 Memory: 3.6 GiB used: 2.1 GiB (58.3%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 12.1.0 Packages:
pacman: 1219 lib: 328 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.15
Garuda (2.6.3-2):
System install date: 2022-04-04
Last full system update: 2022-05-18
Windows dual boot: Yes
Why you want it to remove?
Itās always being recreated anyway.
Fine, they changed it to Xfce, but where is their garuda-inxi?
I want to change the location to XDG_CACHE_HOME. To reduce files in home as far as possible.
ls | grep .xsession-errors
.rw------- 932k sgs 18 Mai 19:49 ļ
.xsession-errors
Really?
So we need your garuda-inxi
Remember.
Refusing to post the output of the required āgaruda-inxiā on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Uninstall your desktop environment, remove all user profiles from the system, and just run your machine as a headless box. That will help you achieve the desired result.
If you want to use a desktop environment with a user profile, you are going to have to let the system have a few dotfiles.
Dude if you understood English youād know āas far as possibleā != ānoneā. I never said I donāt want any.
date: 11/16/2018
volts: 16.3 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
Speed (MHz): avg: 2299 high: 2300 min/max: 400/2800 base/boost: 2200/8300
scaling: driver: intel_pstate governor: performance volts: 0.8 V
ext-clock: 100 MHz cores: 1: 2300 2: 2297 3: 2300 4: 2300 bogomips: 19200
Type: l1tf
520 Mobile]
gpu: i915 display-ID: :0.0 screens: 1
address: <filter>
Local Storage: total: 931.51 GiB used: 40.41 GiB (4.3%)
used: 40.37 GiB (41.8%) fs: btrfs block-size: 4096 B dev: /dev/sda7
maj-min: 8:7
maj-min: 8:2
maj-min: 8:7
maj-min: 8:7
maj-min: 8:7
ID-1: swap-1 type: zram size: 3.6 GiB used: 454.8 MiB (12.3%)
System Temperatures: cpu: 29.8 C pch: 33.0 C mobo: 27.8 C gpu: radeon
temp: 33.0 C
Processes: 227 Uptime: 12h 43m wakeups: 3 Memory: 3.6 GiB
used: 1.52 GiB (42.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1224 lib: 328 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.15
Garuda (2.6.3-2):
Last full system update: 2022-05-19 ā»
Perhaps you are right; judging by this sentence, English appears to have changed a bit since I have been in school.
Try adding this line to the config file at /etc/X11/Xsession instead of .xinitrc. Alternatively, if you want to disable logging you can make the line ERRFILE=/dev/null.
system
Closed
2 June 2022 11:55
10
