Hello everyone!
Before typing this message and starting this new thread I tried to use the search function for the request I am willing to do.
I've changed the 90% of the hardware from the past desktop. New moba, cpu and ram.. So happy At the moment I am using the integrated graphic of the 12900K while waiting for the new AMD Radeon card. Before I had a NVIDIA 3080.
Now the question is: how can I perfectly clean and remove the nvidia driver that triggers at each kernel/nvidia driver update ? If i just try to remove it from pacman it says that many dependencies will break.
To be clear: now the pc is useable and is a beast, I want to do this just to remove unneeded nvidia packages and have everything clean.
Additional question: is worth to enable Wayland now that I dont use Nvidia Graphic?
Thanks a lot,
G.
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=14d91570-f762-4106-889d-9a851d6dc02c rw rootflags=subvol=@
resume=UUID=f1d4967a-02c4-4be4-be76-96ec8d6adaf1 loglevel=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1003
date: 01/19/2022
status: Discharging
Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x18
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 4655 high: 5210 min/max: 800/5200:3900 scaling:
driver: intel_pstate governor: performance cores: 1: 5074 2: 5100 3: 5107
4: 4993 5: 5110 6: 5110 7: 5109 8: 5210 9: 5109 10: 5100 11: 5102
12: 5108 13: 4751 14: 4406 15: 5037 16: 5100 17: 3899 18: 3905 19: 3904
20: 3881 21: 3887 22: 3899 23: 3911 24: 3915 bogomips: 152985
Device-1: Intel AlderLake-S GT1 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,intel,vesa display-ID: :1 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DP-1 res: 2560x1440 hz: 165 dpi: 109
size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: Mesa Intel Graphics (ADL-S GT1) v: 4.6 Mesa 21.3.5
direct render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
Device-2: Sennheiser Sennheiser USB-ED 01 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.1:4 chip-ID: 1395:003c
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3 class-ID: 0200
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 4.56 TiB used: 215.36 GiB (4.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P3CR013
temp: 28.9 C scheme: GPT
model: WD40EFAX-68JH4N0 size: 3.64 TiB block-size: physical: 4096 B
rev: 0A82 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Edge
size: 14.66 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.27 scheme: GPT
ID-1: / raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
used: 215.32 GiB (24.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-4: /var/log raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.09 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 27.8 C mobo: N/A
Processes: 483 Uptime: 4m wakeups: 2 Memory: 31.09 GiB
used: 4.47 GiB (14.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1374 lib: 433 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2021-11-03
Last full system update: 2022-02-12
