hey guys, does someone know why isn't it working? it does the same as firedragon did... doesn't start at all.
i want to report the issue on its github but i have no idea what's wrong
Kernel: 5.17.3-256-tkg-pds arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds
root=UUID=0b8ec9ff-9af6-4372-8dcd-3a81b90a7b8b rw rootflags=subvol=@
Type: Desktop System: Micro-Star product: MS-7B79 v: 3.0
Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.C0
date: 05/18/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4274 high: 4275 min/max: N/A cores: 1: 4275 2: 4275
3: 4275 4: 4275 5: 4275 6: 4273 7: 4275 8: 4275 9: 4275 10: 4275 11: 4275
12: 4275 13: 4275 14: 4275 15: 4275 16: 4275 bogomips: 136931
STIBP: always-on, RSB filling
Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: ASUSTeK
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 27:00.0
chip-ID: 10de:1e87 class-ID: 0300
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 533x302mm (20.98x11.89")
s-diag: 613mm (24.12")
Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2080/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 27:00.1
bus-ID: 29:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.3-256-tkg-pds running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
Local Storage: total: 1.56 TiB used: 647.96 GiB (40.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC49
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
type: SSD serial: <filter> rev: 1103 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SUV400S37240G
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 37R5 scheme: GPT
used: 37.18 GiB (16.7%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: zram size: 15.61 GiB used: 1.18 GiB (7.6%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): cpu: 0 gpu: nvidia fan: 0%
Processes: 387 Uptime: 9m wakeups: 1 Memory: 15.61 GiB
used: 4.61 GiB (29.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1773 lib: 504 flatpak: 0
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-03-27
Last full system update: 2022-04-19 ↻
