I recently shifted from Garuda gnome to cinnamon. Cinnamon is great but there is an issue of theme in some apps. Whatever theme I select, apps like garuda assistant, garuda settings manager, etc. aren't themed. When command sudo cinnamon-settings is entered and in themes, by defualt Sweet Dark is selected and even if I change, changes are not reflected.
Edit : Output of sudo cinnamon-settings when I try to change any theme option it shows error like this in terminal
> [sudo] password for yash:
> Using pam module (python3-pampy)
> Loading Themes module
> Could not establish proxy for org.Cinnamon: Error spawning command line “dbus-launch --autolaunch=e5e429e88a9049acade6448fc6f5eac3 --binary-syntax --close-stderr”: Child process exited with code 1
Please help me regarding this.
sudo garuda-inxi
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=8736464e-32e6-464b-aa69-5aa97de64cf4 rw rootflags=subvol=@
resume=UUID=4425a162-e3ad-42f1-bc0d-aa3b380435b8 loglevel=3
Desktop: Cinnamon v: 5.2.7 tk: GTK v: 3.24.33 wm: Muffin dm: LightDM
v: 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec2xxx v: N/A
serial: Chassis: type: 10 serial:
Mobo: HP model: 88DE v: 96.31 serial: UEFI: AMI v: F.15
date: 08/18/2021
ID-1: BAT0 charge: 50.6 Wh (99.8%) condition: 50.7/50.7 Wh (100.0%)
volts: 12.9 min: 11.6 model: HP Primary type: Li-ion serial:
status: N/A
Info: model: AMD Ryzen 5 5600H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1725 high: 3300 min/max: 1200/4280 boost: enabled
base/boost: 3300/4250 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1200 2: 1200 3: 1200 4: 1200
5: 3300 6: 1200 7: 1200 8: 3300 9: 1200 10: 1200 11: 3300 12: 1200
bogomips: 79048
STIBP: always-on, RSB filling
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 510.68.02 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:25a2
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1638
Device-3: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 3-3:2 chip-ID: 30c9:0035 class-ID: fe01
serial:
Display: x11 server: [X.Org](http://X.Org) v: 21.1.3 driver: X:
loaded: modesetting,nvidia gpu: amdgpu display-ID: :0 screens: 1
Monitor-1: eDP-1 model: AU Optronics 0x2992 built: 2020 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.5-zen1-1-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
snd_pci_acp6x, snd_sof_amd_renoir
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
IF: eno1 state: down mac:
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_pci v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8852
IF: wlo1 state: up mac:
bus-ID: 1-4:3 chip-ID: 0bda:2852 class-ID: e001 serial:
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address:
Local Storage: total: 476.94 GiB used: 39.55 GiB (8.3%)
model: MTFDHBA512TDV-1AZ1AABHA size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: HPS0032 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 17.01 GiB (28.4%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 615 MiB size: 613.8 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p8
maj-min: 259:8
ID-3: /home raw-size: 95.4 GiB size: 95.4 GiB (100.00%)
used: 22.53 GiB (23.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
used: 17.01 GiB (28.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
maj-min: 259:6
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p10 maj-min: 259:10
ID-2: swap-2 type: zram size: 7.18 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 350 Uptime: 7m wakeups: 1 Memory: 7.18 GiB
used: 2.22 GiB (30.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1358 lib: 319 Shell: garuda-inxi (sudo)
default: fish v: 3.4.1 running-in: gnome-terminal inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-08
Last full system update: 2022-05-08
Windows dual boot: Yes
