Chsh and zsh dash ksh ... seems not functional
I am experiencing issues with invoking and changing the default shell to Zsh, Dash, and Ksh in Garuda Linux. While Bash and Fish work without any issues, shells like Zsh, Dash, and Ksh either do not invoke correctly or behave unexpectedly, not providing the usual interactive shell environment. However, these shells are not stuck and can be exited using Ctrl-D. The problem persists both when changing the default shell using chsh and when invoking these shells manually.
                   .%;888:8898898:                ????
                 x;XxXB%89b8:b8%b88:              --------------
              .8Xxd                8X:.           OS: Garuda Linux x86_64
            .8Xx;                    8x:.         Host: HN-WX9X (M1060)
          .tt8x          .d            x88;       Kernel: 6.12.8-zen1-1-zen
       .@8x8;          .db:              xx@;     Uptime: 24 mins
     ,tSXX°          .bbbbbbbbbbbbbbbbbbbB8x@;    Packages: 1569 (pacman)[stable]
   .SXxx            bBBBBBBBBBBBBBBBBBBBbSBX8;    Shell: fish 3.7.1
 ,888S                                     pd!    Resolution: 2160x1440
8X88/                                       q     WM: Hyprland (Wayland)
8X88/                                             Theme: Sweet [Qt], BeautyLine [GTK2], Sweet-D]
GBB.                                              Icons: BeautyLine [Qt], BeautyLine [GTK2/3/4]
 x%88        d888@8@X@X@X88X@@XX@@X@8@X.          Terminal: foot 1.20.1
   dxXd    dB8b8b8B8B08bB88b998888b88x.           Terminal Font: JetbrainsMonoNL 14
    dxx8o                      .@@;.              CPU: AMD Ryzen 7 3700U with Radeon Vega Mobilz
      dx88                   .t@x.                GPU: AMD Radeon Vega 10 Graphics [Integrated]
        d:SS@8ba89aa67a853Sxxad.                  Memory: 3618 MiB / 14919 MiB
          .d988999889889899dd.
I suspected it as chsh issue but I’ve problem invoking any shell rather than fish and bash. But even zsh do not give any interaction at all.
Following output taken into alacritty emulator. Foot only can able to change bash btw.
╭─user@host in ~ took 24m6s
╰─λ zsh
                                                   user@host
                     .%;888:8898898:               --------------
                   x;XxXB%89b8:b8%b88:             OS: Garuda Linux Bird of Prey x86_64
                .8Xxd                8X:.          Host: HUAWEI HN-WX9X-PCB
              .8Xx;                    8x:.        Kernel: 6.12.8-zen1-1-zen
            .tt8x          .d            x88;      Uptime: 46 mins
         .@8x8;          .db:              xx@;    Packages: 1569 (pacman)
       ,tSXX°          .bbbbbbbbbbbbbbbbbbbB8x@;   Shell: fish 3.7.1
     .SXxx            bBBBBBBBBBBBBBBBBBBBbSBX8;   Resolution: 2160x1440
   ,888S                                     pd!   WM: Hyprland
  8X88/                                       q    Theme: BeautyLine [GTK2], Sweet-Dark [GTK3]
  GBB.                                             Icons: BeautyLine [GTK2/3]
   x%88        d888@8@X@X@X88X@@XX@@X@8@X.         Terminal: alacritty
     dxXd    dB8b8b8B8B08bB88b998888b88x.          CPU: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx (8) @ 2.300GHz
      dxx8o                      .@@;.             GPU: AMD ATI Radeon Vega Series / Radeon Vega Mobile Series
        dx88                   .t@x.               Memory: 3686MiB / 14918MiB
╭─user@host in ~
╰─λ dash
$ echo $SHELL
/usr/bin/fish
$ zsh
                                                   user@host
            .tt8x          .d            x88;      Uptime: 47 mins
        dx88                   .t@x.               Memory: 3700MiB / 14918MiB
╭─user@host in ~
╰─λ ksh
$ echo $SHELL
/usr/bin/fish
$ bash
bash: zmodload: command not found
bash: eval: line 14: unexpected argument `(' to conditional binary operator
bash: eval: line 14: syntax error near `(['
bash: eval: line 14: `if [[ $ZSH_VERSION == ([1-4]*) ]]; then'
bash: \e[1;5C:: command not found
bash: \e[1;5D:: command not found
╭─user@host in ~ took 0s
╰─λ echo $SHELL
/usr/bin/fish
╰─λ bash
bash: eval: line 14: `if [[ $ZSH_VERSION == ([1-4*) ]]; then'
╰─λ echo $SHELL
/usr/bin/fish
I’m using the latest version of Garuda and this is not occurred recent times. I can not remember using Zsh ever.
  Kernel: 6.12.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e____b668a72f rw rootflags=subvol=@
    quiet resume=UUID=838d____e0e0c loglevel=3 ibt=off
  Desktop: Hyprland v: 0.46.2 with: waybar tools: avail: swayidle,swaylock
    vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Laptop System: HUAWEI product: HN-WX9X v: M1060
  Mobo: HUAWEI model: HN-WX9X-PCB v: M1060 serial: <superuser required>
    part-nu: C331 uuid: <superuser required> UEFI: HUAWEI v: 1.17
    date: 03/10/2022
  ID-1: BAT0 charge: 36.4 Wh (100.0%) condition: 36.4/41.2 Wh (88.6%)
    volts: 12.3 min: 11.4 model: DYNAPACK HB4593J6ECW type: Li-ion
    serial: <filter> status: not charging cycles: 482
  Info: model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx bits: 64
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
    desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1177 min/max: 1400/2300 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1177 2: 1177 3: 1177
    4: 1177 5: 1177 6: 1177 7: 1177 8: 1177 bogomips: 36727
  Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
    Series / Radeon Mobile Series] vendor: Huawei driver: amdgpu v: kernel
    speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1 bus-ID: 03:00.0
    chip-ID: 1002:15d8 class-ID: 0300 temp: 60.0 C
  Device-2: IMC Networks HD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3 chip-ID: 13d3:5482
    compositor: Hyprland v: 0.46.2 driver: X: loaded: amdgpu
    unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
    display-ID: 1
  Monitor-1: eDP-1 model: ChiMei InnoLux P130ZFA-BA1 built: 2018
    res: 2160x1440 hz: 60 dpi: 200 gamma: 1.2 scale: 1
    size: 275x183mm (10.83x7.2") diag: 330mm (13") ratio: 3:2 modes:
    max: 2160x1440 min: 640x480
  API: Vulkan v: 1.4.303 layers: 9 device: 0 type: integrated-gpu name: AMD
    Radeon Vega 10 Graphics (RADV RAVEN) driver: N/A device-ID: 1002:15d8
  Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
    Audio vendor: Huawei driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
    vendor: Huawei driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,
    vendor: Huawei driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.8-zen1-1-zen status: kernel-api tools: N/A
    vendor: & Tele RSH driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 1358:c123
  Local Storage: total: 942.7 GiB used: 62.82 GiB (6.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
    SDBPNPZ-512G-1027 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 21117000 temp: 40.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 500G
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
    fw-rev: 0409 scheme: GPT
  ID-1: / raw-size: 460.61 GiB size: 460.61 GiB (100.00%)
    used: 62.82 GiB (13.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 460.61 GiB size: 460.61 GiB (100.00%)
  ID-4: /var/log raw-size: 460.61 GiB size: 460.61 GiB (100.00%)
  ID-5: /var/tmp raw-size: 460.61 GiB size: 460.61 GiB (100.00%)
  ID-1: swap-1 type: zram size: 14.57 GiB used: 35.8 MiB (0.2%)
    max-streams: 8 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 16.03 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 59.5 C mobo: N/A gpu: amdgpu temp: 59.0 C
  Memory: total: 16 GiB note: est. available: 14.57 GiB used: 7.8 GiB (53.5%)
  Processes: 335 Power: uptime: 14h 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.82 GiB services: upowerd Init: systemd
    v: 257 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1569 libs: 433 tools: pacseek,paru Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37 running-in: alacritty
    inxi: 3.3.36
  System install date:     2024-12-27
  Last full system update: 2025-01-07 ↻
Please post your garuda-inxi as requested by the template.
Have you tried setting the shell in the Terminals config file? I dont use foot or alacritty, but at least on kitty I set shell fish or shell zsh in the config an all is well. There is also in the garuda assistant a tab that will let you change the shell to zsh though it more for setting the default system shell.
Yes, I set for alacritty and has its conf~/.config/alacritty/alacritty.toml
[terminal.shell]
args = ["--login"]
program = "/usr/bin/zsh"
[window]
opacity = 0.8
#"colors.draw_bold_text_with_bright_colors" = true
#[".confiscroll"]
#confiscroll_display = 500
#confiscroll_history = 50000
[colors.bright]
black = "#575b70"
blue = "#caa9fa"
cyan = "#9aedfe"
green = "#5af78e"
magenta = "#ff92d0"
red = "#ff6e67"
white = "#e6e6e6"
yellow = "#f4f99d"
[colors.normal]
black = "#000000"
blue = "#caa9fa"
cyan = "#8be9fd"
green = "#50fa7b"
magenta = "#ff79c6"
red = "#ff5555"
white = "#bfbfbf"
yellow = "#f1fa8c"
[colors.primary]
background = "#282a36"
foreground = "#f8f8f2"
