Is there a way to uninstall software from the live environment?
I’ve deleted a lot of files so far.
Or is there maybe a command to delete stuff that isn’t necessary, to make space where it specifically needs it?
Or is there a directory I should be looking in?
If you installed an application with Pacman you should be able to remove it normally from the chroot.
To list installed programs you have explicitly installed:
pacman -Qqe
If you see any you can do without, remove them with -R:
pacman -R [package name]
To remove a package and all packages which depend on it, use -Rc instead.
Removed a lot, but the system bit doesnt change seemingly no matter what in btrfs. Is there something else I can do?
It looks like there is some difference. Are you able to run a balance now?
Wow, it’s working, it’s still fairly quick but no where like before.
Let’s try the more aggressive full balance.
btrfs balance start --full-balance /
After it finishes, let’s take a look again at this output:
btrfs filesystem usage /
Want me to stop this current one or let it continue first?
No no, if it is still going that’s good–maybe it will free up plenty of space and there won’t be a need to run it again.
I’m praying mate, this has been a headache and a half. When I originally started looking at the F.A.Q before coming here, my brain melted. I still don’t even understand what the issue is, all I get is that the update cooked it.
1%
FInished:
[root@garuda-gnome /]# btrfs filesystem usage /
Overall:
Device size: 465.46GiB
Device allocated: 396.06GiB
Device unallocated: 69.40GiB
Device missing: 0.00B
Device slack: 512.00B
Used: 391.66GiB
Free (estimated): 71.81GiB (min: 37.11GiB)
Free (statfs, df): 71.81GiB
Data ratio: 1.00
Metadata ratio: 2.00
Global reserve: 512.00MiB (used: 0.00B)
Multiple profiles: no
Data,single: Size:389.00GiB, Used:386.59GiB (99.38%)
/dev/mapper/luks-f2314da2-7bb3-4bfa-83ba-9a58d102e216 389.00GiB
Metadata,DUP: Size:3.50GiB, Used:2.53GiB (72.37%)
/dev/mapper/luks-f2314da2-7bb3-4bfa-83ba-9a58d102e216 7.00GiB
System,DUP: Size:32.00MiB, Used:80.00KiB (0.24%)
/dev/mapper/luks-f2314da2-7bb3-4bfa-83ba-9a58d102e216 64.00MiB
Unallocated:
/dev/mapper/luks-f2314da2-7bb3-4bfa-83ba-9a58d102e216 69.40GiB
Would you like me to run the deeper one? Or try to update or?
I apologize for the pain you’re about to witness, but I haven’t gone through with the update in case something will break, I’d rather your approval first.
[root@garuda-gnome /]# garuda-update
garuda is up to date
core is up to date
extra 7.3 MiB 6.14 MiB/s 00:01 [------------------------------------] 100%
multilib is up to date
chaotic-aur 753.2 KiB 709 KiB/s 00:01 [------------------------------------] 100%
--> Refreshing mirrorlists using reflector, please be patient..🍵
[2024-08-28 21:02:37] WARNING: failed to rate http(s) download (https://us.arch.niranjan.co/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
[2024-08-28 21:02:44] WARNING: failed to rate http(s) download (https://mirrors.atviras.lt/archlinux/extra/os/x86_64/extra.db): Download timed out after 5 second(s).
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
warning: itch-setup-bin: local (1.26.0-1.2) is newer than chaotic-aur (1.26.0-1)
resolving dependencies...
error: could not open file /var/lib/pacman/local/evince-46.3.1-1/desc: No such file or directory
warning: dependency cycle detected:
warning: libcamera-ipa will be installed before its libcamera dependency
warning: rubygems will be installed before its ruby dependency
Packages (376) alsa-card-profiles-1:1.2.3-1 ananicy-cpp-1.1.1-1.1 audit-4.0.2-1 bind-9.20.1-1
bitwarden-2024.8.1-1 bleachbit-4.6.1-1 breeze-icons-6.5.0-1 btrfs-progs-6.10.1-1
bubblewrap-0.10.0-1 c-ares-1.33.1-1 cachyos-ananicy-rules-git-20240826.r414.ga78b765-1
chafa-1.14.2-1 cifs-utils-7.0-5 ckbcomp-1.230-1 cpio-2.15-2 cracklib-2.10.2-1
cups-filters-2.0.1-1 cython-3.0.11-1 dart-3.5.1-1 device-mapper-2.03.26-1 dosfstools-4.2-5
dvd+rw-tools-7.1-11 egl-wayland-4:1.1.16-1 electron-1:32-1 electron29-1:29.4.6-1
electron30-30.4.0-1 electron31-31.4.0-1 electron32-32.0.1-1 element-desktop-1.11.75-1
element-web-1.11.75-1 evolution-data-server-3.52.4-1 exfatprogs-1.2.5-1 eza-0.19.1-1
f2fs-tools-1.16.0-3 fakeroot-1.36-1 fastfetch-2.22.0-1 ffmpeg-2:7.0.2-1
firedragon-1:11.17.8_1-1 firewalld-2.2.1-1 flake8-1:7.1.1-1 flashrom-1.4.0-1
fluidsynth-2.3.6-1 freetype2-2.13.3-1 fwupd-1.9.24-1 fzf-0.54.3-1 git-2.46.0-1
glib2-2.80.5-1 glibmm-2.68-2.80.1-1 gnome-bluetooth-3.0-46.1-1 gnome-control-center-46.4-1
gnome-desktop-1:44.1-1 gnome-desktop-4-1:44.1-1 gnome-desktop-common-1:44.1-1
gnome-keybindings-46.4-1 gnome-online-accounts-3.50.4-1 gnome-shell-1:46.4-1
gnome-shell-extension-appindicator-1:59-1 gnutls-3.8.7-1 gom-0.5.3-1
gpm-1.20.7.r38.ge82d1a6-6 gst-libav-1.24.7-1 gst-plugin-gtk-1.24.7-1
gst-plugin-pipewire-1:1.2.3-1 gst-plugins-bad-1.24.7-1 gst-plugins-bad-libs-1.24.7-1
gst-plugins-base-1.24.7-1 gst-plugins-base-libs-1.24.7-1 gst-plugins-good-1.24.7-1
gst-plugins-ugly-1.24.7-1 gst-python-1.24.7-1 gstreamer-1.24.7-1 gstreamer-vaapi-1.24.7-1
gtk-update-icon-cache-1:4.14.5-1 gtk4-1:4.14.5-1 gtksourceview3-1:3.24.11+r28+g73e57b57-2
gzip-1.13-4 hidapi-0.14.0-3 hostapd-2.11-4 hplip-1:3.24.4-2 hwinfo-23.2-2 hwloc-2.11.1-1
iana-etc-20240814-1 imagemagick-7.1.1.37-1 intel-ucode-20240813-2 ipp-usb-0.9.27-1
iproute2-6.10.0-2 irqbalance-1.9.4-2 karchive-6.5.0-1 kauth-6.5.0-1 kbookmarks-6.5.0-1
kcmutils-6.5.0-1 kcodecs-6.5.0-1 kcolorscheme-6.5.0-1 kcompletion-6.5.0-1 kconfig-6.5.0-1
kconfigwidgets-6.5.0-1 kcoreaddons-6.5.0-1 kcrash-6.5.0-1 kdbusaddons-6.5.0-1
kglobalaccel-6.5.0-1 kguiaddons-6.5.0-1 ki18n-6.5.0-1 kiconthemes-6.5.0-1 kio-6.5.0-1
kirigami-6.5.0-1 kitemmodels-6.5.0-1 kitemviews-6.5.0-1 kjobwidgets-6.5.0-1 kmod-33-3
knotifications-6.5.0-1 kservice-6.5.0-1 kstatusnotifieritem-6.5.0-1 kwallet-6.5.0-1
kwidgetsaddons-6.5.0-1 kwindowsystem-6.5.0-1 kxmlgui-6.5.0-1 ldb-2:2.9.1-2
lib32-curl-8.9.1-1 lib32-fluidsynth-2.3.6-1 lib32-freetype2-2.13.3-1
lib32-gcc-libs-14.2.1+r32+geccf707e5ce-1 lib32-glib2-2.80.5-1
lib32-glibc-2.40+r16+gaa533d58ff-2 lib32-gnutls-3.8.7-1 lib32-gst-plugins-base-libs-1.24.7-1
lib32-gstreamer-1.24.7-1 lib32-libcurl-compat-8.9.1-1 lib32-libcurl-gnutls-8.9.1-1
lib32-libltdl-2.5.1-2 lib32-libnghttp3-1.5.0-1 lib32-libnl-3.10.0-1 lib32-libnm-1.48.10-1
lib32-libpipewire-1:1.2.3-1 lib32-librsvg-2:2.58.3-1 lib32-libtiff-4.6.0-3
lib32-libtirpc-1.3.5-1 lib32-libva-2.22.0-1 lib32-libx11-1.8.10-1 lib32-libxcrypt-4.4.36-2
lib32-libxcrypt-compat-4.4.36-2 lib32-libxml2-2.13.3-1 lib32-libxtst-1.2.5-1
lib32-mesa-1:24.1.6-1 lib32-mpg123-1.32.7-1 lib32-nss-3.103-1
lib32-nvidia-utils-560.35.03-1 lib32-opencl-nvidia-560.35.03-1 lib32-orc-0.4.39-1
lib32-pipewire-1:1.2.3-1 lib32-pipewire-jack-1:1.2.3-1 lib32-readline-8.2.013-1
lib32-sdl2-2.30.6-1 lib32-sqlite-3.46.1-1 lib32-systemd-256.5-1 lib32-tdb-1.4.12-1
lib32-vulkan-radeon-1:24.1.6-1 lib32-wayland-1.23.0-1 libadwaita-1:1.5.3-1 libavif-1.1.1-1
libbluray-1.3.4-2 libcamera-0.3.1-2 libcamera-ipa-0.3.1-2 libcurl-compat-8.9.1-2
libcurl-gnutls-8.9.1-2 libdatachannel-0.21.2-2 libdeflate-1.21-1 libdovi-3.3.1-1
libei-1.3.0-1 libfabric-1.22.0-1 libgme-0.6.3-5 libgoa-3.50.4-1 libheif-1.18.2-1
libimagequant-4.3.3-1 libimobiledevice-1.3.0-14 libinput-1.26.2-1 libjuice-1.5.2-1
libkcddb-24.08.0-1 libkcddb5-24.08.0-1 libmaxminddb-1.11.0-1 libmusicbrainz5-5.1.0-7
libnghttp3-1.5.0-1 libngtcp2-1.7.0-1 libnl-3.10.0-1 libnm-1.48.10-1 libopenmpt-0.7.9-1
libpamac-aur-11.6.4-1.1 libpcap-1.10.4-2 libphonenumber-1:8.13.42-1 libpipewire-1:1.2.3-1
librsvg-2:2.58.3-1 libsasl-2.1.28-5 libssh-0.11.0-2 libtool-2.5.1-2
libtraceevent-1:1.8.3-1 libtracefs-1.8.1-1 liburing-2.7-1 libva-2.22.0-1
libva-mesa-driver-1:24.1.6-1 libvpx-1.14.1-1 libwbclient-4.20.4-1 libwebp-1.4.0-2
libxcrypt-compat-4.4.36-2 libxfont2-2.0.7-1 libxnvctrl-560.35.03-1 licenses-20240728-1
linux-firmware-20240809.59460076-1 linux-firmware-whence-20240809.59460076-1
linux-headers-6.10.6.arch1-1 linux-zen-6.10.6.zen1-1 linux-zen-headers-6.10.6.zen1-1
lmdb-0.9.33-1 lollypop-1.4.40-1 luajit-2.1.1723675123-1 lvm2-2.03.26-1
media-player-info-26-1 mercurial-6.8.1-1 mesa-1:24.1.6-1 meson-1.5.1-1 metasploit-6.4.23-1
mhwd-nvidia-560.35.03.2-1 micro-2.0.14-1 mutter-46.4-1 nautilus-image-converter-0.4.0-2
nautilus-share-0.7.5-5 networkmanager-1.48.10-1 nfs-utils-2.7.1-1 nfsidmap-2.7.1-1
nlohmann-json-3.11.3-1 nm-cloud-setup-1.48.10-1 nodejs-22.7.0-1 noto-fonts-1:24.8.1-1
nvidia-dkms-560.35.03-2 nvidia-settings-560.35.03-1 nvidia-utils-560.35.03-2
opencl-nvidia-560.35.03-2 openfortivpn-1.22.1-1 openmpi-5.0.5-1 openrgb-0.9-4
pambase-20230918-2 pangomm-2.48-2.54.0-1 pcsclite-2.3.0-1 perl-path-tiny-0.146-1
pipewire-1:1.2.3-1 pipewire-alsa-1:1.2.3-1 pipewire-audio-1:1.2.3-1 pipewire-jack-1:1.2.3-1
pipewire-pulse-1:1.2.3-1 pipewire-v4l2-1:1.2.3-1 pipewire-x11-bell-1:1.2.3-1
pipewire-zeroconf-1:1.2.3-1 pkgfile-22-1 plymouth-git-24.004.60.r84.gea83580a-1
polkit-125-1 poppler-qt5-24.08.0-1 postgresql-16.3-3 postgresql-libs-16.3-3
protobuf-27.3-2 protobuf-c-1.5.0-4 psutils-3.3.5-1 python-3.12.5-1 python-babel-2.15.0-1
python-contourpy-1.3.0-1 python-cryptography-42.0.7-1 python-gobject-3.48.2-2
python-hypothesis-6.111.2-1 python-importlib-metadata-7.2.1-1 python-jaraco.context-5.3.0-1
python-jaraco.functools-4.0.2-1 python-jaraco.text-4.0.0-1 python-jsonschema-4.23.0-1
python-lxml-5.3.0-1 python-markdown-3.7-1 python-matplotlib-3.9.2-1 python-numpy-2.0.1-1
python-phonenumbers-8.13.43-1 python-pip-24.2-1 python-puremagic-1.27-2
python-pyopenssl-24.2.1-1 python-pypdf-4.3.1-1 python-pyperclip-1.9.0-1
python-pytest-1:8.3.2-1 python-pytest-asyncio-0.23.8-1 python-reportlab-4.2.2-1
python-rich-13.8.0-1 python-rpds-py-0.19.0-1 python-soupsieve-2.6-1 python-sphinx-8.0.2-1
python-sphinx-alabaster-theme-1.0.0-1 python-sphinx_rtd_theme-2.0.0-1
python-sphinxcontrib-applehelp-2.0.0-1 python-sphinxcontrib-devhelp-2.0.0-2
python-sphinxcontrib-htmlhelp-2.1.0-1 python-sphinxcontrib-qthelp-2.0.0-1
python-sphinxcontrib-serializinghtml-2.0.0-1 python-tomlkit-0.13.2-1 python-tqdm-4.66.5-1
python-trio-0.26.2-1 python-trove-classifiers-2024.7.2-1 python-uvloop-0.19.0-5
python-validate-pyproject-0.19-1 python-wheel-0.44.0-1 python-yaml-6.0.2-1
python-zipp-3.19.2-1 qbittorrent-4.6.6-1 qt5-wayland-5.15.14+kde+r59-1 qt6-base-6.7.2-2
re2-1:20240702-2 rpcbind-1.2.7-1 ruby-3.2.4-1 ruby-bundled-gems-3.2.4-1
ruby-bundler-2.5.11-2 ruby-debug-1.7.1-1 ruby-default-gems-3.2.4-1 ruby-erb-4.0.4-4
ruby-irb-1.6.2-2 ruby-matrix-0.4.2-1 ruby-minitest-5.22.3-1 ruby-net-ftp-0.3.5-2
ruby-net-imap-0.4.12-1 ruby-net-pop-0.1.2-1 ruby-net-smtp-0.5.0-2 ruby-power_assert-2.0.3-3
ruby-prime-0.1.2-1 ruby-racc-1.6.2-1 ruby-rake-13.0.6-3 ruby-rbs-3.4.4-2
ruby-rdoc-6.5.1.1-2 ruby-rexml-3.2.6-2 ruby-rss-0.3.0-2 ruby-stdlib-3.2.4-1
ruby-test-unit-3.6.1-3 ruby-typeprof-0.21.8-1 rubygems-3.4.19-1 sakura-3.8.7-2
samba-4.20.4-1 sdl2-2.30.6-1 smbclient-4.20.4-1 sndio-1.10.0-1 solid-6.5.0-1
spotube-bin-3.8.0-3 sqlite-3.46.1-1 starship-1.20.1-1 steam-1.0.0.81-2 subversion-1.14.3-1
svt-av1-2.1.2-1 systemd-256.5-1 systemd-libs-256.5-1 systemd-oomd-defaults-253.5-1.1
systemd-sysvcompat-256.5-1 taglib-2.0.2-1 tdb-1.4.12-1 thin-provisioning-tools-1.1.0-1
thunderbird-115.14.0-1 ttf-fantasque-sans-mono-1.8.0-3 ugrep-6.5.0-1 uvicorn-0.30.5-1
v4l-utils-1.28.1-1 valgrind-3.23.0-5 vim-9.1.0697-1 vim-runtime-9.1.0697-1 vlc-3.0.21-2
vte-common-0.76.4-1 vte3-0.76.4-1 vulkan-radeon-1:24.1.6-1 webkit2gtk-2.44.3-3
webkit2gtk-4.1-2.44.3-3 webkitgtk-6.0-2.44.3-3 wine-9.16-1 wineasio-1.2.0-8
wpa_supplicant-2:2.11-2 xapp-2.8.5-1 xdg-dbus-proxy-0.1.6-1 xfsprogs-6.9.0-1
xl2tpd-1.3.18-2 xmlsec-1.3.5-1 xorg-xwayland-24.1.2-1
Total Download Size: 2183.66 MiB
Total Installed Size: 7474.02 MiB
Net Upgrade Size: 324.21 MiB
:: Proceed with installation? [Y/n] n
Yes, let’s give it a shot.
All that anguish to bring in a whopping 324 MiB.
Haha indeed ! But will this allow me to actually boot in to the system now? Before it was giving me the kernel issue the other chap had and I had to snapshot to access my files.
This is going to reinstall the kernel as part of the upgrade.
We should check the output of the update to confirm it succeeds, then after that reboot and test if you can boot to the installation normally.
Quite a few errors in there, I have no idea what some of them mean. Like Ruby? No idea. Apologies for the pain you are about to endure. Unfortunately I can’t paste it all but I’ll try pin point the errors.
Post transaction hooks:
( 1/37) Restoring Linux kernel modules...
++ uname -r
+ KVER=6.8.7-zen1-2-zen
+ test -e /usr/lib/modules/backup/6.8.7-zen1-2-zen
+ rm -rf /usr/lib/modules/backup
( 2/37) Creating system user accounts...
( 3/37) Registering binary formats...
Skipped: Running in chroot.
( 4/37) Updating journal message catalog...
( 5/37) Reloading system manager configuration...
( 6/37) Reloading user manager configuration...
( 7/37) Updating udev hardware database...
( 8/37) Applying kernel sysctl settings...
( 9/37) Creating temporary files...
Failed to open file "/sys/devices/system/cpu/cpu11/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu9/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu7/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu5/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu3/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu14/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu12/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu10/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu8/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu6/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu4/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu15/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu2/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu13/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/module/zswap/parameters/enabled": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy11/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy8/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy6/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy4/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy2/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy14/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy0/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy12/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy9/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy10/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy7/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy5/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy3/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy15/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy1/energy_performance_preference": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpufreq/policy13/energy_performance_preference": Read-only file system
Failed to open file "/sys/module/pcie_aspm/parameters/policy": Read-only file system
Failed to open file "/sys/class/drm/card0/device/power_dpm_state": Read-only file system
Failed to open file "/sys/class/rtc/rtc0/max_user_freq": Read-only file system
(10/37) Reloading device manager configuration...
This was after packages
error: failed retrieving file 'mutter-46.4-1-x86_64.pkg.tar.zst' from mirror.osbeck.com : HTTP/2 stream 261 was not closed cleanly: INTERNAL_ERROR (err 2)
(376/376) checking keys in keyring [------------------------------------] 100%
(376/376) checking package integrity [------------------------------------] 100%
(376/376) loading package files [------------------------------------] 100%
(376/376) checking for file conflicts [------------------------------------] 100%
(376/376) checking available disk space [------------------------------------] 100%
warning: could not get file information for usr/lib/thunderbird/distribution/distribution.ini
The end Snapshots:
Please check and merge
(20/37) GRUB update after transactions...
Found theme: /usr/share/grub/themes/garuda/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Detecting snapshots ...
Found snapshot: 2024-08-19 14:56:46 | @_backup_20241908145646908 | N/A | N/A |
Found snapshot: 2024-08-11 14:06:47 | @_backup_20241108140647380 | N/A | N/A |
Found snapshot: 2024-08-11 14:01:07 | @/.snapshots/417/snapshot | pre | pacman -Su |
Found snapshot: 2024-07-21 16:52:36 | @/.snapshots/416/snapshot | post | adobe-source-code-pro-fonts alsa-card-profiles alsa-firmware alsa-oss al |
Found snapshot: 2024-07-21 16:49:50 | @/.snapshots/415/snapshot | pre | pacman -Su |
Found snapshot: 2024-06-28 10:11:22 | @/.snapshots/414/snapshot | post | alsa-lib alsa-plugins android-tools android-udev bibata-cursor-theme bit |
Found snapshot: 2024-06-28 10:09:14 | @/.snapshots/413/snapshot | pre | pacman -Su |
Found 7 snapshot(s)
Unmount /tmp/grub-btrfs.O3SRGHa0bj .. Success
done
(21/37) Reloading system bus configuration...
(22/37) Warn about old perl modules
(23/37) Copy FireDragon Distribution Settings
(24/37) Updating fontconfig cache...
(25/37) Updating 32-bit fontconfig cache...
(26/37) Probing GDK-Pixbuf loader modules...
(27/37) Probing 32-bit GDK-Pixbuf loader modules...
(28/37) Compiling GSettings XML schema files...
(29/37) Updating icon theme caches...
(30/37) Updating GTK4 module cache...
(31/37) Updating the info directory file...
(32/37) Copy Thunderbird Distribution Settings
(33/37) Updating the desktop file MIME type cache...
(34/37) Updating the vlc plugin cache...
(35/37) Updating Vim help tags...
(36/37) Performing snapper post snapshots for the following configurations...
fatal library error, lookup self
==> root: 435
(37/37) Syncing all file systems...
Running in chroot, ignoring command 'start'
Failed to connect to bus: No such file or directory
Failed to start transient service unit: Transport endpoint is not connected
That looks good actually. I’m pretty sure the errors you have are normal when running in a chroot.
Next, exit out of the chroot, reboot, and see if you can get to your normal system now.
Bro, I could kiss you right now. It worked. I’m on it, but I have this in the top right. Is there anything I should do now that I’m back on it?
I will donate to the forum or whatever for the help you guys have given, top tier
I’m not sure what that is actually. Try running garuda-update again now that you are in the normal system and see if it has any additional actions to complete.
Just as you typed this, I have an issue. Terminal will not open no matter what, how would I resolve this?
I checked this and this is also stuck
Try switching to a TTY by pressing Ctrl+Alt+F3 (or try the other F keys). Log in to the TTY and try running garuda-update from there instead to see what it says.
