Chromium gpu accelerated setup
I am trying to setup ungoogled-chromium to use my nvidia gpu. I have been using the arch wiki and searching through their forum, but can't figure out what needs to be done. There are a few things disabled or only using software instead of hardware. Things I am trying to change is the Raw Draw and Compositing.
The command that I am using is:
prime-run chromium --ignore-gpu-blocklist --use-gl=egl --enable-unsafe-webgpu --enable-features=CanvasOopRasterization,VaapiVideoDecoder,VaapiVideoEncoder --disable-features=UseChromeOSDirectVideoDecoder --disable-gpu-driver-bug-workarounds --enable-raw-draw --enable-native-gpu-memory-buffers --enable-gpu-rasterization --enable-accelerated-2d-canvas --enable-zero-copy
Accourding to chrome://gpu
### Graphics Feature Status
* Canvas: Hardware accelerated
* Canvas out-of-process rasterization: Enabled
* Direct Rendering Display Compositor: Disabled
* Compositing: Software only. Hardware acceleration disabled
* Multiple Raster Threads: Enabled
* OpenGL: Enabled
* Rasterization: Hardware accelerated on all pages
* Raw Draw: Disabled
* Video Decode: Hardware accelerated
* Video Encode: Hardware accelerated
* Vulkan: Disabled
* WebGL: Hardware accelerated but at reduced performance
* WebGL2: Hardware accelerated but at reduced performance
* WebGPU: Hardware accelerated but at reduced performance
### Problems Detected
* Gpu compositing has been disabled, either via blocklist, about:flags or the command line. The browser will fall back to software compositing and hardware acceleration will be unavailable.
  Kernel: 6.0.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=fee12699-5d85-4ddb-bae0-daf333cf53d5 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 info: latte-dock
  Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
  Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
  ID-1: BAT1 charge: 34.4 Wh (80.2%) condition: 42.9/51.6 Wh (83.3%)
    volts: 11.6 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
    status: not charging
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 4058 high: 4204 min/max: 800/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4200 2: 4200 3: 4200
    4: 4200 5: 4194 6: 4167 7: 4200 8: 4204 9: 2600 10: 4197 11: 4184
    12: 4155 bogomips: 62399
    vulnerable
    PBRSB-eIBRS: Not affected
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
  Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
    driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
    process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:1f11 class-ID: 0300
  Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:3
    chip-ID: 04f2:b695 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
  Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
    hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
    22.2.1 direct render: Yes
  Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Sound API: ALSA v: k6.0.5-zen1-1-zen running: yes
    vendor: Micro-Star MSI driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
    driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
  Local Storage: total: 1.38 TiB used: 641.28 GiB (45.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
    SDAPNUW-512G-1032 size: 476.94 GiB block-size: physical: 512 B
    rev: 20140000 temp: 46.9 C scheme: GPT
    model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
    rev: 1A01 scheme: GPT
  ID-1: / raw-size: 146.44 GiB size: 146.44 GiB (100.00%) used: 62.84 GiB
    (42.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 146.44 GiB size: 146.44 GiB (100.00%) used: 62.84
    GiB (42.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-4: /var/log raw-size: 146.44 GiB size: 146.44 GiB (100.00%) used: 62.84
  ID-5: /var/tmp raw-size: 146.44 GiB size: 146.44 GiB (100.00%) used: 62.84
  ID-1: swap-1 type: zram size: 15.47 GiB used: 295.7 MiB (1.9%)
  System Temperatures: cpu: 61.0 C pch: 55.0 C mobo: N/A
  Processes: 394 Uptime: 2h 34m wakeups: 1 Memory: 15.47 GiB used: 5.44 GiB
  (35.2%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1552 libs: 427
  tools: octopi,paru Shell: fish v: 3.5.1 running-in: alacritty inxi: 3.3.22
Garuda (2.6.9-1):
  System install date:     2022-07-14
  Last full system update: 2022-10-30
When trying to start from the terminal, this is the output:
prime-run chromium --ignore-gpu-blocklist --use-gl=egl --enable-unsafe-webgpu --enable-features=CanvasOopRasterization,VaapiVideoDecoder,VaapiVideoEncoder --disable-features=UseChromeOSDirectVideoDecoder --disable-gpu-driver-bug-workarounds --enable-raw-draw --enable-native-gpu-memory-buffers --enable-gpu-rasterization --enable-accelerated-2d-canvas --enable-zero-copy --enable-gpu-compositing
Gtk-Message: 11:04:28.023: Failed to load module "appmenu-gtk-module"
[23223:23223:1031/110428.127841:ERROR:gpu_init.cc(537)] Passthrough is not supported, GL is egl, ANGLE is
[23223:23223:1031/110428.240666:ERROR:gl_display.cc(508)] EGL Driver message (Error) eglCreateWindowSurface: EGL_BAD_MATCH error: In eglCreateWindowSurface: Native and EGL formats are incompatible
[23223:23223:1031/110428.240848:ERROR:gl_surface_egl.cc(479)] eglCreateWindowSurface failed with error EGL_BAD_MATCH
[23287:7:1031/110428.255602:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[23195:23206:1031/110428.597311:ERROR:ev_root_ca_metadata.cc(290)] Failed to register OID: 0
Fontconfig error: Cannot load default config file: No such file: (null)
