I am very new to Garuda and Linux in general but I wanted to share something that I stumbled across today. Let me first say that I am not sure whether this is a bug or an appropriate behavior that I just did not expect to see...
I installed Chrome Remote Desktop (from the AUR) to my Dr4Gonized installation using the following guide How to Install chrome-remote-desktop on Arch · Victor's Blog . Everything was looking okay through this process. Well, when I rebooted and tested with a CRD session, I could not see any of my icons, panel, or dock from the guest computer. So I rebooted my computer. When it fully started, I could not see my icons, panel, or dock on my host computer. I went round and round with it and I almost reinstalled Garuda on the host but I shut off my guest computer and rebooted my host. When the host garuda machine fully rebooted, my icons, panel, and dock fired back up!
So the only thing that corrects this anomaly for me, is to kill the CRD session on the guest machine, log out of the host, and then come back in. Maybe lots of folks have the answer to this and I am just being a noob, but maybe this info can be useful to someone who reads it.
Regards,
Jeff
First, nobody uses an outdated post from 2 Apr, 2020 .
Why you use proprietary software?
It would be nice if you post your garuda-inxi, too.
SGS,
Thank you for the response. I am not completely happy with CRD but it does work between my company-provided notebook pc that I have restrictions on by our company administrators and a windows machine at my home and this is the main reason why I use it (this activity is legal with the admin dept.). If there is another program that you recommend, I would like to try it. Here is my garuda-inxi
Regards,
Jeff
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=f07ccfee-40f0-4a31-9de0-a05752169b9c rw [email protected]
Type: Desktop Mobo: Micro-Star model: MAG Z490 TOMAHAWK (MS-7C80) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.A0
date: 10/19/2021
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xEE
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 799 high: 800 min/max: 800/5100 scaling:
driver: intel_pstate governor: powersave cores: 1: 799 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 bogomips: 121596
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
Screen-1: 0 s-res: 2560x1080 s-dpi: 96 s-size: 677x285mm (26.65x11.22")
s-diag: 735mm (28.92")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Viewteck GNV29CB built: 2020
res: 2560x1080 hz: 60 dpi: 96 gamma: 1.2 size: 680x288mm (26.77x11.34")
diag: 738mm (29.1") modes: max: 2560x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 13.0.1 DRM
3.44 5.17.4-zen1-1-zen)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
Device-3: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8812 class-ID: 0280
Device-1: Realtek type: USB driver: btusb v: 0.8 bus-ID: 1-1:2
chip-ID: 0bda:a725 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 10.48 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7
temp: 40.9 C scheme: GPT
ID-1: / raw-size: 296.1 GiB size: 296.1 GiB (100.00%)
used: 10.45 GiB (3.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 29.5 MiB (30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 296.1 GiB size: 296.1 GiB (100.00%)
ID-4: /var/log raw-size: 296.1 GiB size: 296.1 GiB (100.00%)
ID-5: /var/tmp raw-size: 296.1 GiB size: 296.1 GiB (100.00%)
System Temperatures: cpu: 27.8 C pch: 40.0 C mobo: N/A gpu: amdgpu
temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 214
Processes: 352 Uptime: 16m wakeups: 0 Memory: 15.54 GiB
used: 2.73 GiB (17.6%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1137 lib: 291 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-05
Last full system update: 2022-06-06 ↻
Specimen:
Specimen:
Something is odd about the timeline here. You have mentioned you have been rebooting during your troubleshooting and we can see you have pulled down an update today, but the fact that you are still on 5.17.4 makes it appear as though you have not rebooted this device in weeks.
Most of us have been running 5.18 for a couple weeks now, or nearly. A forum search for 5.17.4-zen reveals people running were running it all the way back in late April.
Are you describing troubleshooting that you did weeks ago? Or are you holding back your kernel for some reason? If you are updating and rebooting you should be on a newer kernel by now.
I am not willingly or knowingly holding back a kernel update (I admit I dont know how to do this). Is there a way I should do this manually? I did try to restore a snapper failsafe image today. Would that be why?
Yes, restoring a snapshot can bring you back to an earlier kernel. That update you pulled down today must have been large--cross your fingers when you reboot.
I take it from the fact that you restored to a snapshot that something else is wrong with your system (besides the broken CRD environment)?
The reboot went fine, thankfully...
Yes. CRD's issues were why I restored the snapshot and that was prior to the post and prior to my consideration to perform a reinstallation. And I spoke too soon also, apparently. This is what I am seeing when my host machine is logged in and my guest machine 'rings in'
Here is my Android screenshot of the Garuda host. No panel or dock:
And here is my updated garuda-inxi
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
date: 10/19/2021
family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xF0
Speed (MHz): avg: 1299 high: 4206 min/max: 800/5100 scaling:
driver: intel_pstate governor: powersave cores: 1: 2412 2: 4206 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 3767 12: 801
13: 800 14: 800 15: 800 16: 800 bogomips: 121596
3.46 5.18.1-zen1-1-zen)
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
Local Storage: total: 931.51 GiB used: 19.93 GiB (2.1%)
ID-1: / raw-size: 296.1 GiB size: 296.1 GiB (100.00%) used: 19.9 GiB (6.7%)
used: 19.9 GiB (6.7%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-1: swap-1 type: zram size: 15.54 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: 27.8 C pch: 41.0 C mobo: N/A gpu: amdgpu
temp: 55.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 474
Processes: 380 Uptime: 5m wakeups: 0 Memory: 15.54 GiB
used: 2.39 GiB (15.4%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1488 lib: 356 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-06-06
And the guest machine will timeout in CRD whenever the host garuda machine is not logged into to it's computer session.
I am sorry I did not test this thoroughly prior to my post. I thought the post would be helpful. I guess not...
Thanks Guys
Specimen:
No panel or dock:
Restore with garuda-assistant.
BTW, we trust you, no picture needed.
Specimen:
No panel or dock:
It does appear that there is something where they would normally show, so is this due to CRD not supporting the blur or other compositing feature in use by the desktop?
filo
7 June 2022 13:01
#10
Why not trying with the compositor disabled at all?
I'm sorry for the delayed response. The background is lucid and not blurred.
Thanks SGS. I will do as you suggest...
system
closed
21 June 2022 17:05
#13
