Choppy OBS recording when selecting whole screen not when selecting particular window
mak@mak-Linux in ~
󰛓 ❯ garuda-inxi
Kernel: 6.17.8-1-cachyos arch: x86_64 bits: 64 compiler: clang v: 21.1.5
root=UUID=8a225222-9a2f-4172-9dd8-e7809c5f2b49 rw rootflags=subvol=@
quiet resume=UUID=9cedf431-e133-4d3b-bedf-da3790f814aa loglevel=3
Desktop: KDE Plasma v: 6.5.2 tk: Qt v: N/A info: frameworks v: 6.20.0
wm: kwin_wayland with: krunner vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LU_FX566LU
Mobo: ASUSTeK model: FX506LU v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: FX506LU.310
date: 11/26/2021
ID-1: BAT1 charge: 0% condition: 69.2/90 Wh (76.9%) volts: 12.27 min: 15.4
model: ASUS A32-K55 type: Li-ion serial: N/A charging: status: charging
control: start: N/A end: 100% cycles: N/A
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0x100
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
8: 800 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: none off: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 580.105.08 alternate: nouveau,nvidia_drm
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2191
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 13d3:56a2
compositor: kwin_wayland driver:
gpu: i915,nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2023 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 93 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.7-arch1.1
device-ID: 8086:9bc4 memory: 15.09 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.328 layers: 15 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 25.2.7-arch1.1
device-ID: 8086:9bc4 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1660 Ti driver: nvidia v: 580.105.08
device-ID: 10de:2191 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 21.1.5 256 bits) driver: mesa llvmpipe v: 25.2.7-arch1.1 (LLVM
21.1.5) device-ID: 10005:0000 surfaces: N/A
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
API: ALSA v: k6.17.8-1-cachyos status: kernel-api with: aoss
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 1.4 TiB used: 456.14 GiB (31.9%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: A-Data model: SX6000PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: VC0S036H temp: 29.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA1T0QFD
lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA001 temp: 39.9 C
ID-1: / raw-size: 936.58 GiB size: 936.58 GiB (100.00%)
used: 456.14 GiB (48.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 936.58 GiB size: 936.58 GiB (100.00%)
ID-4: /var/log raw-size: 936.58 GiB size: 936.58 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.58 GiB size: 936.58 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.45 GiB used: 848 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.99 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3
System Temperatures: cpu: 66.0 C pch: 54.0 C mobo: N/A
Memory: total: 16 GiB available: 15.45 GiB used: 5.18 GiB (33.5%)
Processes: 316 Power: uptime: 38m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1646 libs: 461 tools: octopi,paru Compilers:
clang: 21.1.5 gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.2.1
Garuda (2.11.1-1):
System install date:     2025-11-16
Last full system update: 2025-11-18
Relevant software:       snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard
25/26 checks run in 0.68 seconds ⌛
Powered by garuda-health 🦅
  • Search the web and forums
hey i fixed it.
The choppiness occurred only when obs and the application where stacked on top. i.e: recording browser
where obs was on top. this lead to stutters and choppiness during opening the app and even lead to system crashes.
moving obs to different virtual desktop solved the issue.
