Hello I wanted to know if there is any way to play hivalry 2 in garuda, I’ve been surfing the internet for a while and trying with a thousand configurations, but I can’t make it work (I’ve tried with Steam, Epic through Lutris and with Heroic games Launcher)) Does anyone know anything specific about this Game? Thank you very much
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=d5c6173e-7f9a-4a03-b4f7-3576a8bd5c8d rw rootflags=subvol=@
quiet resume=UUID=80be3167-46a0-45e1-bace-e12bacb3ae79 loglevel=3 ibt=off
Desktop: Hyprland v: 0.44.1 with: waybar tools: avail: swayidle,swaylock
vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: HP product: Victus by HP Gaming Laptop 16-s0xxx
Mobo: HP model: 8BD4 v: 79.40 serial: <superuser required>
part-nu: 836P8EA#ABE uuid: <superuser required> UEFI: Insyde v: F.12
date: 10/05/2023
ID-1: BAT1 charge: 61.3 Wh (100.0%) condition: 61.3/70.1 Wh (87.4%)
volts: 17.3 min: 15.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
ID-2: hidpp_battery_0 charge: 69% condition: N/A volts: 3.9 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
Info: model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64
microcode: 0xA704103
Speed (MHz): avg: 3518 min/max: 400/5137 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3518 2: 3518 3: 3518
4: 3518 5: 3518 6: 3518 7: 3518 8: 3518 9: 3518 10: 3518 11: 3518 12: 3518
13: 3518 14: 3518 15: 3518 16: 3518 bogomips: 121367
Type: gather_data_sampling status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
vendor: Hewlett-Packard driver: nvidia v: 560.35.03
alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:28a0
Device-2: Advanced Micro Devices [AMD/ATI] Phoenix1
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix
process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-6,DP-7,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5,
Writeback-1 bus-ID: 05:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 42.0 C
Device-3: Quanta HP True Vision FHD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0408:548d
compositor: Hyprland v: 0.44.1 driver: X: loaded: amdgpu,nvidia
gpu: amdgpu d-rect: 5760x2160 display-ID: 1
Monitor-1: DP-6 pos: top-center model: ASUS VP28U serial: <filter>
built: 2020 res: 1920x1080 hz: 60 dpi: 79 gamma: 1.2 scale: 1
size: 160x90mm (6.3x3.54") diag: 707mm (27.8") ratio: 16:9 modes:
Monitor-2: DP-7 pos: top-right model: AOC 2460G5 serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 scale: 1
Monitor-3: eDP-1 pos: bottom-l model: BOE Display 0x0b9f built: 2022
res: 1920x1080 hz: 144 dpi: 137 gamma: 1.2 scale: 1
size: 355x200mm (13.98x7.87") diag: 407mm (16") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 1 drv: radeonsi
device: 2 drv: swrast surfaceless: drv: swrast wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm,device-0
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi
gfx1103_r1 LLVM 18.1.8 DRM 3.59 6.11.5-zen1-1-zen) device-ID: 1002:15bf
memory: 500 MiB unified: no
API: Vulkan v: 1.3.295 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon 780M (RADV GFX1103_R1) driver: mesa radv v: 24.2.6-arch1.1
device-ID: 1002:15bf surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.6-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: NVIDIA AD107 High Definition Audio vendor: Hewlett-Packard
Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:1640
vendor: Hewlett-Packard driver: snd_pci_ps v: kernel
snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Logitech G933 Wireless Headset Dongle
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 046d:0a5b class-ID: 0300
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0e8d:223c
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 1.05 TiB used: 394.58 GiB (36.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCPNRY-1T00-1006 size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Generic model: STORAGE
size: 116.48 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1404 scheme: MBR
ID-1: / raw-size: 441.54 GiB size: 441.54 GiB (100.00%)
used: 292.98 GiB (66.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 441.54 GiB size: 441.54 GiB (100.00%)
ID-4: /var/log raw-size: 441.54 GiB size: 441.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 441.54 GiB size: 441.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.63 GiB used: 512 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 33.7 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 32 GiB note: est. available: 30.63 GiB
used: 10.79 GiB (35.2%)
Processes: 433 Power: uptime: 1h 50m states: freeze,mem,disk
suspend, test_resume image: 12.2 GiB services: upowerd Init: systemd
v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1555 libs: 483 tools: pacseek,paru Compilers:
gcc: 14.2.1 Shell: fish v: 3.7.1 running-in: foot inxi: 3.3.36
