What is the easiest way to resolve these?
Compare the both files (. pacnew + pacman.conf) and if the same -->delete .pacnew or rename .pacnew to pacorg. (as backup) Default you need “only” pacman.conf.
do you have a preferred method/tool?
garuda-rani now is supposed to enumerate through all the .pacnew files and prompt you to compare and make the appropriate changes. Alternatively, you may use pacdiff -s in terminal.
Check files with the alias in confg.fish the difference
pacdiff
# Compare .pacnew & .pacsave files
alias pacdiff='sudo -H DIFFPROG=meld pacdiff'
Maybe you must install meld, we are missing your
Hello there, I used to be able to merge .pacnew file through Garuda Rani, by pressing the Start Merging button. However, when I do that now, something flickers but the meld view of comparing and merging the difference does not show-up, which used to be followed by the prompt that asks if the merging was done.
How can I fix this problem? Why is Start Merging via Garuda Rani is apparently broken, at least for me? Here is my garuda-inxi output.
Kernel: 6.15.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=3cb44b40-10ea-4ba9-b5f2-d55ffacaaed6 rw rootflags=subvol=@
quiet resume=UUID=19bcb6f6-be63-4a3e-b2f7-80c5ca918637 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.4.2 tk: Qt v: N/A info: frameworks v: 6.15.0
wm: kwin_wayland with: ulauncher vt: 1 dm: SDDM Distro: Garuda
Type: Laptop System: HP product: HP Laptop 15-bs0xx v: Type1ProductConfigId
Mobo: HP model: 832A v: 23.78 serial: <superuser required>
part-nu: 1WP51UA#ABA uuid: <superuser required> UEFI: Insyde v: F.65
date: 12/06/2019
ID-1: BAT1 charge: 20.9 Wh (100.0%) condition: 20.9/31.1 Wh (67.4%)
volts: 12.7 min: 11.1 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i3-7100U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF6
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2400 min/max: 400/2400 scaling: driver: intel_pstate
governor: powersave cores: 1: 2400 2: 2400 3: 2400 4: 2400 bogomips: 19200
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
Device-2: Sunplus Innovation HP TrueVision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4
chip-ID: 1bcf:2c9b class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x10ec built: 2017 res:
mode: 1366x768 hz: 60 scale: 95% (0.95) to: 1438x808 dpi: 101 gamma: 1.2
modes: 1366x768
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 11.32 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 620 (KBL GT2) driver: mesa intel v: 25.1.4-arch1.2
device-ID: 8086:5916 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.6 256 bits) driver: mesa llvmpipe v: 25.1.4-arch1.2 (LLVM
API: ALSA v: k6.15.4-zen2-1-zen status: kernel-api tools: N/A
lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 8087:0aa7
Local Storage: total: 1.82 TiB used: 66.14 GiB (3.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 072 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD4
ID-1: / raw-size: 87.89 GiB size: 87.89 GiB (100.00%)
used: 52.96 GiB (60.3%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 640 MiB size: 638.7 MiB (99.80%)
used: 620 KiB (0.1%) fs: vfat dev: /dev/sda8 maj-min: 8:8
ID-3: /home raw-size: 73.24 GiB size: 73.24 GiB (100.00%)
used: 13.19 GiB (18.0%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-4: /var/log raw-size: 87.89 GiB size: 87.89 GiB (100.00%)
ID-5: /var/tmp raw-size: 87.89 GiB size: 87.89 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.59 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 50.0 C pch: 41.5 C mobo: N/A
Memory: total: 12 GiB available: 11.59 GiB used: 4.36 GiB (37.6%)
Processes: 284 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 4.62 GiB services: org_kde_powerdevil,
Packages: 2346 pm: pacman pkgs: 2335 libs: 455 tools: octopi,paru
pm: flatpak pkgs: 11 Compilers: clang: 20.1.7 gcc: 15.1.1 Shell: garuda-inxi
default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
Garuda (2.7.3-1):
System install date: 2025-03-22
Last full system update: 2025-07-03
Sounds like you may have the same issue as me. When I click the button to start the merge it attempts to open a window that looks like a terminal window, which appears for a split second showing Size: 123 x 52 and then closes.
@Scoobin, correct, something like that is what is happening. Something shows-up for a split second and vanishes immediately. So, do you have any workaround you do to fix to reconcile the pacman file?
I don’t have a fix and I do have meld installed so I can go to the terminal and run pacdiff and meld pops up.
Has meld improved? It shows the difference much more nice and clearly than last time I managed to do this. ![]()
garuda-inxi:
root=UUID=b71c31f1-55e9-4354-a076-2d2364f5e63d rw rootflags=subvol=@
nvidia-drm.modeset=1 nouveau.modeset=0 nvidia.NVreg_EnableGpuFirmware=0
drm.edid_firmware=DP-1:edid/AOC_edid.bin mt7921e.disable_aspm=Y
pcie_aspm=off quiet loglevel=3 sysrq_always_enabled=1 ibt=off
wm: kwin_wayland with: krunner vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506QM_TUF506QM
Mobo: ASUSTeK model: FA506QM v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FA506QM.314
date: 01/07/2023
ID-1: BAT1 charge: 41.6 Wh (59.9%) condition: 69.4/90.2 Wh (76.9%)
volts: 15.5 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
microcode: 0xA500011
Speed (MHz): avg: 4419 min/max: 403/4465 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4419 2: 4419 3: 4419
4: 4419 5: 4419 6: 4419 7: 4419 8: 4419 9: 4419 10: 4419 11: 4419 12: 4419
13: 4419 14: 4419 15: 4419 16: 4419 bogomips: 102208
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 575.64.03 alternate: nouveau,nvidia_drm
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1 empty: none bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: HDMI-A-1 off: eDP-1 empty: none bus-ID: 06:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 57.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 322e:202c
class-ID: 0e02
unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-1 model: AOC CQ27G4 serial: <filter> built: 2024 res:
mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: HDMI-A-1 model: Sony TV serial: <filter> built: 2010 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 30 gamma: 1.2
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-3: eDP-1 model: Najing CEC Panda 0x004d built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11:
drv: radeonsi inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.2
renoir ACO DRM 3.63 6.15.4-zen2-1-zen) device-ID: 1002:1638
memory: 500 MiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.313 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.1.4-arch1.2
device-ID: 1002:1638 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 575.64.03
device-ID: 10de:2520 surfaces: N/A device: 2 type: cpu name: llvmpipe
de: kscreen-console,kscreen-doctor gpu: lact, nvidia-settings, nvidia-smi
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.5
lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:3563
Local Storage: total: 3.25 TiB used: 1.34 TiB (41.2%)
fw-rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
fw-rev: FXM7201Q temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: A-Data model: USB Flash Drive
size: 58.88 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1.00 scheme: MBR
model: WD10EAVS-00D7B1 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: N/A serial: <filter> fw-rev: 1.75 scheme: MBR
ID-1: / raw-size: 90 GiB size: 90 GiB (100.00%) used: 73.33 GiB (81.5%)
fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:2
used: 23.7 MiB (9.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
ID-3: /home raw-size: 90 GiB size: 90 GiB (100.00%)
used: 73.33 GiB (81.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:2
ID-4: /var/log raw-size: 90 GiB size: 90 GiB (100.00%)
ID-5: /var/tmp raw-size: 90 GiB size: 90 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.02 GiB used: 1.57 GiB (10.5%)
System Temperatures: cpu: 66.9 C mobo: 42.0 C gpu: amdgpu temp: 55.0 C
Memory: total: 16 GiB note: est. available: 15.02 GiB used: 5.93 GiB (39.5%)
Processes: 455 Power: uptime: 6h 8m states: freeze,mem,disk
suspend, test_resume image: 5.92 GiB services: org_kde_powerdevil,
Packages: 1782 pm: pacman pkgs: 1746 libs: 500 tools: octopi,pacseek,paru
pm: flatpak pkgs: 36 Compilers: gcc: 15.1.1 Shell: garuda-inxi default: fish
v: 4.0.2 running-in: yakuake inxi: 3.3.38
Garuda (2.7.3-1):
System install date: 2024-08-27
Last full system update: 2025-07-04
Failed units: memory_monitor.service
Thank you. For me, pacdiff does not start meld, but only when I give (M)erge it opens up in meld. Is that what you are also saying?
That is what I needed to do
Thank you. I just did this and about to reboot to see if all is well ![]()
󰛓 ❯ pacdiff -s
==> pacnew file found for /etc/pacman.d/mirrorlist
:: (V)iew, (M)erge, (S)kip, (R)emove pacnew, (O)verwrite with pacnew, (Q)uit: [v/m/s/r/o/q] m
2025-07-04 01:29:03,934 CRITICAL Gtk:
(org.gnome.Meld:14183): GLib-GIO-CRITICAL **: 01:29:03.934: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
2025-07-04 01:29:03,935 CRITICAL Gtk:
(org.gnome.Meld:14183): GLib-GIO-CRITICAL **: 01:29:03.935: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(org.gnome.Meld:14183): GLib-GIO-CRITICAL **: 01:29:03.935: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
:: Would you like to use the results of the merge? [y/n] y
'/tmp/pacdiff-merge-mirrorlist.Tsp/mirrorlist.merged.65W' -> '/etc/pacman.d/mirrorlist'
removed '/etc/pacman.d/mirrorlist.pacnew'
removed '/tmp/pacdiff-merge-mirrorlist.Tsp/mirrorlist.merged.65W'
removed '/tmp/pacdiff-merge-mirrorlist.Tsp/mirrorlist.base.Qut'
removed directory '/tmp/pacdiff-merge-mirrorlist.Tsp'
Yeah that’s right. I didn’t really have a clue what I was doing on the rust files. Oh well ![]()
Hello, looks like I do not have a pacdiff-merge but only pacdiff under /usr/bin. Is there something I should be doing to get to what you are suggesting? Here is what I have:
[âś–] ó°›“ ls -al /usr/bin/pacdiff*
.rwxr-xr-x 9.3k root 9 Jun 20:55  /usr/bin/pacdiff
If you already updated then this is expected. It lives in the correct location now.
