Hello everyone, so I need to change my GPU, my Nvidia 750ti just died a horrible death and now I’m gonna get me a Radeon RX580 as a good linux user should always lean on the AMD side of things (tho I haven’t bought it yet so I’m still accepting recommendations on the same budget xD)
I found this post:
But tho I believe it to be as simple as plug and play, as I used proprietary drivers to install my Garuda sys I just want to be sure everything will be actually that easy as to just switch and turn the pc on.
Or should I immediately try something like this:
Additionally while I wait for the new gpu to arrive, I need to use my motherboard HDMI port to use my stuff. But it doesn’t seem to get me video beyond the grub page? If I boot zorin on grub, it works just fine, but no Garuda entry can get me video, can anyone help me with this?
Thanks in great advance!
inxi
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "pt_BR.UTF-8",
LC_NAME = "pt_BR.UTF-8",
LC_MONETARY = "pt_BR.UTF-8",
LC_PAPER = "pt_BR.UTF-8",
LC_IDENTIFICATION = "pt_BR.UTF-8",
LC_TELEPHONE = "pt_BR.UTF-8",
LC_MEASUREMENT = "pt_BR.UTF-8",
LC_TIME = "pt_BR.UTF-8",
LC_NUMERIC = "pt_BR.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 6.5.10-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc available: hpet,acpi_pm parameters: pti=on
root=UUID=33da784c-6400-4145-99e3-93bc3c7463b2 rw rootflags=subvol=@
quiet
cryptdevice=UUID=5b16040e-5d39-4cd0-80b7-423ffe50eaff:luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
root=/dev/mapper/luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
Desktop: LXQt v: 1.4.0 tk: Qt v: 5.15.11 info: cairo-dock, lxqt-panel
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME H310M-E R2.0/BR v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1605
date: 07/14/2020
Info: model: Intel Core i3-8100 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF4
desc: 1x6 MiB
Speed (MHz): avg: 2200 high: 3601 min/max: 800/3600 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 3600 3: 800
4: 3601 bogomips: 28808
Device-1: NVIDIA GM107 [GeForce GTX 750] driver: nvidia v: 545.29.02
2023-10; EOL~2026-12-xx) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1381 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 1360x768 s-dpi: 90 s-size: 384x300mm (15.12x11.81")
s-diag: 487mm (19.18")
Monitor-1: Unknown-1 mapped: HDMI-0 res: 1360x768 hz: 60 dpi: 49
size: 708x398mm (27.87x15.67") modes: 1024x768
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 750/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.3.269 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 750 driver: nvidia v: 545.29.02
device-ID: 10de:1381 surfaces: xcb,xlib
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
API: ALSA v: k6.5.10-hardened1-1-hardened status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Local Storage: total: 2.78 TiB used: 788.47 GiB (27.7%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 55.9 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: Sb10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000NM0053
size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: G00A scheme: GPT
ID-1: / raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
used: 192.04 GiB (34.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
ID-2: /boot/efi raw-size: 5.59 GiB size: 5.58 GiB (99.80%)
used: 242.2 MiB (4.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
ID-4: /var/log raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
ID-5: /var/tmp raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.0 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 33%
Processes: 238 Uptime: 3m wakeups: 0 Memory: total: 16 GiB
available: 15.56 GiB used: 2.9 GiB (18.6%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: 1810 pm: pacman pkgs: 1757 libs: 540
tools: pamac,paru pm: flatpak pkgs: 53 Shell: Bash v: 5.2.15
running-in: qterminal inxi: 3.3.31
Garuda (2.6.19-1):
System install date: 2023-11-15
Last full system update: 2023-09-12
Is partially upgraded: Yes
(also, the above inxi is from the last post since my gpu is not able to do anything right now so I can’t get to my garuda system. if you feel like I should stick a live-boot to get the latest-and-greatest inxi of the system, I’ll provide it right away. last update was actually 20/nov, not partial since bluish solved my issue with updating as well).
