Whenever I reboot, turn off, or shut down my computer my monitor settings change back to what they were when I first installed this operating system.
I go to change it in Monitor Settings (when I hit "About" it tells me it's LXRandR 0.3.2) Afterwards hitting "Apply" then "Save"
I'm currently on a fresh install of garuda i3wm (garuda-i3-linux-zen-211028.iso).
I have 2 monitors. A 1680x1050 acer monitor and a 1920x1080 msi monitor. I want to configure them such that the acer monitor is on the left and my msi monitor is on the right running at 144 hz. The orientation and relative locations are correct on every boot but I can't get the 144hz to stay.
I've tried out the Display Manager multi-monitor configuration guide but it didn't work, the files I created are still on my system however.
Aside from that, all I've done so far is run sudo Pacman -Syu to keep things up to date, changed my resolution a few times using the xrandr, and ran inxi -Fxz for this post.
output from inxi -Fxz:
System: Kernel: 5.15.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: i3 4.20.1 Distro: Garuda Linux
Machine: Type: Desktop System: Gigabyte product: B250M-DS3H v: N/A serial: <filter>
Mobo: Gigabyte model: B250M-DS3H-CF v: x.x serial: <filter> UEFI-[Legacy]: American Megatrends v: F7
date: 07/07/2017
CPU: Info: Dual Core model: Intel Pentium G4560 bits: 64 type: MT MCP arch: Kaby Lake rev: 9 cache: L2: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27999
Speed: 3500 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3500 2: 3501 3: 3500 4: 3500
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: nvidia v: 495.44 bus-ID: 01:00.0
Display: x11 server: X.Org 1.21.1.1 driver: loaded: nvidia unloaded: modesetting resolution: 1: 1680x1050~60Hz
2: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.15.4-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: d000 bus-ID: 03:00.0
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8 bus-ID: 1-7:5
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Drives: Local Storage: total: 3.21 TiB used: 12.39 GiB (0.4%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G3X0C-00SJG0 size: 465.76 GiB temp: 37.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-22MFCA0 size: 931.51 GiB
ID-3: /dev/sdb vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
ID-4: /dev/sdc type: USB vendor: A-Data model: USB Flash Drive size: 28.91 GiB
Partition: ID-1: / size: 922.71 GiB used: 12.39 GiB (1.3%) fs: btrfs dev: /dev/sda1
ID-2: /home size: 922.71 GiB used: 12.39 GiB (1.3%) fs: btrfs dev: /dev/sda1
ID-3: /var/log size: 922.71 GiB used: 12.39 GiB (1.3%) fs: btrfs dev: /dev/sda1
ID-4: /var/tmp size: 922.71 GiB used: 12.39 GiB (1.3%) fs: btrfs dev: /dev/sda1
Swap: ID-1: swap-1 type: zram size: 7.72 GiB used: 256 KiB (0.0%) dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/sda2
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 57 C
Info: Processes: 237 Uptime: 2m Memory: 7.72 GiB used: 1.55 GiB (20.0%) Init: systemd Compilers: gcc: 11.1.0
Packages: 1194 Shell: Bash v: 5.1.8 inxi: 3.3.08
output from xrandr -q:
Screen 0: minimum 8 x 8, current 3600 x 1080, maximum 32767 x 32767
DVI-D-0 connected primary 1680x1050+0+0 (normal left inverted right x axis y axis) 474mm x 296mm
1680x1050 59.88*+ 59.95
1600x1200 60.00
1440x900 74.98 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
640x480 75.00 72.81 59.94
HDMI-0 connected 1920x1080+1680+0 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.00*+ 144.00 119.88 59.94
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x960 60.00
1280x720 60.00 59.94
1152x864 75.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
