Hi,
Bellow my garuda-inxi:
╰─λ garuda-inxi
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=a680dad4-4010-429f-858a-4e9a766c822f rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: P55-US3L serial: <superuser required>
BIOS: Award v: FE date: 03/05/2010
Info: model: Intel Core i5 750 bits: 64 type: MCP arch: Nehalem family: 6
model-id: 0x1E (30) stepping: 5 microcode: 0xA
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2178 high: 2389 min/max: 1197/2661 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2344 2: 2291
3: 2389 4: 1688 bogomips: 21317
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
STIBP: disabled, RSB filling
Device-1: AMD Redwood XT [Radeon HD 5670/5690/5730] vendor: Gigabyte
driver: radeon v: kernel alternate: amdgpu pcie: gen: 2 speed: 5 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DVI-I-1,VGA-1 bus-ID: 01:00.0
chip-ID: 1002:68d8 class-ID: 0300
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1.2:3 chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
alternate: fbdev,vesa gpu: radeon display-ID: :0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-0 model: AOC 2757M serial: <filter>
built: 2012 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
OpenGL:
renderer: AMD REDWOOD (DRM 2.50.0 / 5.17.9-zen1-1-zen LLVM 13.0.1)
v: 3.3 Mesa 22.0.4 compat-v: 3.1 direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
Device-2: AMD Redwood HDMI Audio [Radeon HD 5000 Series] vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 1002:aa60 class-ID: 0403
Device-3: Creative Labs CA0106/CA0111 [SB Live!/Audigy/X-Fi Series]
driver: snd_ca0106 v: kernel bus-ID: 06:04.0 chip-ID: 1102:0007
class-ID: 0401
Device-4: Philips s SAA7131/SAA7133/SAA7135 Video Broadcast Decoder
vendor: Avermedia DVB-T Super 007 driver: saa7134 v: 0, 2, 17
bus-ID: 06:05.0 chip-ID: 1131:7133 class-ID: 0480
Device-5: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: ee00 bus-ID: 02:00.0
chip-ID: 10ec:818b class-ID: 0280
lanes: 1 port: ce00 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 447.13 GiB used: 245.14 GiB (54.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: GOODRAM model: N/A size: 447.13 GiB
block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s type: SSD
serial: <filter> rev: 01.7 scheme: MBR
ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
used: 46.25 GiB (23.7%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /home raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-3: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-4: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.68 GiB used: 239.5 MiB (2.0%)
System Temperatures: cpu: 55.0 C mobo: N/A gpu: radeon temp: 60.0 C
Processes: 305 Uptime: 12h 26m wakeups: 0 Memory: 11.68 GiB
used: 7.87 GiB (67.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 Packages: 1561 pacman: 1548 lib: 360 snap: 13 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-13
Last full system update: 2022-05-20
My problem is fact that after applying a new theme :
And after adjusting colors:
I'm expecting that my windows will be looking like this one:
That example of VS Code. That one is just fine because it doesn't include any pink color.
However I have noticed that my preffered theme +color settings are not appied to all programs (like Remmina, Thunderbird, other windows with settings.. ) where I'm able to see colors / gradients which I've thought previously edited. Examples:
I'm almost sure I have done everything to remove that pink color from my Color settings.
But somehow it's defined somewhere:
Program like JamesDSP at least has option to change theme:
But Remmina for example use garuda's default theme:
Can someone help we with that? How to evenly adjust selected theme to all windows/apps?
