Hello, i’m currently using Garuda Xfce but i wanted to make the switch to dragonized.
So i made a bootable usb using DD
but it still isn’t booting a live session of dragonized, just my installed Xfce session.
I’ve already changed the boot order so that the USB’s get booted first.
Is there any way i can still switch to dragonized or am i stuck with Xfce?
<kbd>System:
Kernel: 6.1.70-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e364120a-e1b7-4190-933f-d2f783bbd534 rw rootflags=subvol=@
Type: Laptop System: Micro-Star product: GL62M 7REX v: REV:1.0
Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16J9IMS.324 date: 03/23/2018
ID-1: BAT1 charge: 34.6 Wh (98.0%) condition: 35.3/42.4 Wh (83.4%)
volts: 12.2 min: 10.8 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 high: 802 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 802
5: 800 6: 800 7: 800 8: 800 bogomips: 44817
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915
active: HDMI-A-2,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 545.29.06
2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0302
Device-3: Chicony USB 2.0 Webcam Device driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:10
chip-ID: 04f2:b521 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver:
X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915 display-ID: :0.0
Screen-1: 0 s-res: 2944x1080 s-dpi: 96 s-size: 779x286mm (30.67x11.26")
s-diag: 830mm (32.67")
Monitor-1: HDMI-A-2 mapped: HDMI-2 pos: bottom-r
model: Philips PHL 15PFL4122 serial: <filter> built: 2007 res: 1024x768
dpi: 86 gamma: 1.2 size: 304x228mm (11.97x8.98") diag: 386mm (15.2")
ratio: 4:3 modes: max: 1920x1080i min: 720x400
Monitor-2: eDP-1 pos: primary,top-left model: ChiMei InnoLux 0x15d6
built: 2015 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 11.33 GiB unified: yes
API: Vulkan v: 1.3.274 layers: 10 device: 0 type: integrated-gpu
name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 23.3.2-arch1.2
device-ID: 8086:591b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1050 Ti driver: nvidia v: 545.29.06
device-ID: 10de:1c8c surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM
Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: HP HyperX QuadCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
chip-ID: 03f0:0491 class-ID: 0300 serial: <filter>
API: ALSA v: k6.1.70-1-lts status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Micro-Star MSI
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 1969:10a1 class-ID: 0200
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:9 chip-ID: 8087:0aa7
Local Storage: total: 1.03 TiB used: 31.17 GiB (3.0%)
model: MZVLW128HEGR-00000 size: 119.24 GiB block-size: physical: 512 B
fw-rev: CXB7401Q temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010B7E610
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A01 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Generic model: Flash Disk
size: 3.75 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 1.0a
scheme: MBR
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 31.17 GiB (26.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.61 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C pch: 53.5 C mobo: N/A
Processes: 291 Uptime: 5m wakeups: 0 Memory: total: 12 GiB
available: 11.61 GiB used: 2.78 GiB (23.9%) Init: systemd v: 255
pm: pacman pkgs: 1596 libs: 467 tools: gnome-software,paru Shell: Bash
v: 5.2.21 running-in: xfce4-terminal inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-01
Last full system update: 2024-01-03
Failed units: <kbd>
