Before you open a new help request, read relevant sections of the Arch and Garuda wiki. Thoroughly search your issue and any error messages in the forum and on the web.
Post your terminal in- and output from:
inxi -Faz
Not sure about other Garuda DEs, on mine the system shell is bash, while fish is the custom command run by the terminal -- alacritty for me, but perhaps it's konsole on KDE -- hard to say which is yours.
Look in the relevant config files for your terminal or post the necessary info if you need assistance.
Welcome.
I just noticed the template still asks for inxi -Faz rather than garuda-inxi.
Ah, ok, I changed it 5 days ago, it's not one template for all, but each theme has its own. So sometimes a theme can slip through.
Now that begs the question, where did that come from?
