Is there some instructions how to change the profile that is used in Konsole? When i use a different color scheme, not al colors change. The prompt colors stay the same.
How do you (think you) change color scheme?
In Konsole i go to settings-configure konsole - I select the profile i want to change. Then i select apperance and select a theme i want to use. All colors change except the prompt colors.
The prompt definition is defined in your shell’s configuration AFAIK.
Then why did you ask about Konsole profile change problem???
I didn't know that these colors are not in the profile settings. Is there a description somewhere how to change these colors?
It depends on which shell you are using.
For example, for fish
, look here
Check your running shell
echo $SHELL
Garuda ships with fish or zsh as default and includes default configuration for new users. You can find them in /etc/skel/
(unhide hidden files).
Check for your local config in your $HOME.
It is using the fish shell.
Is there a config file where i can change these colors? I want to change them to a lighter color. They are to dark when i use a black background.
/home/$USER/.config/fish/config.fish
or run in terminal (fish)
fish_config
I think this is what i was looking for,thanks.
You can thank me by changing the topic title to the proper one (Changing fish terminal colors, or similar).
