Kernel: 6.8.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=50d4c2af-2fd2-443e-819b-f21c29243442 rw rootflags=subvol=@
Desktop: Hyprland v: 0.39.1 with: waybar tools: avail: swayidle,swaylock
vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
UEFI: American Megatrends v: H.60 date: 11/06/2019
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4250 min/max: N/A cores: 1: 4250 2: 4250 3: 4250 4: 4250
5: 4250 6: 4250 7: 4250 8: 4250 9: 4250 10: 4250 11: 4250 12: 4250 13: 4250
14: 4250 15: 4250 16: 4250 bogomips: 136010
active: DP-1,HDMI-A-1 empty: DP-2,DP-3,Writeback-1 bus-ID: 2f:00.0
chip-ID: 1002:73df class-ID: 0300
compositor: Hyprland v: 0.39.1 driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 3840x1080 display-ID: 1
Monitor-1: DP-1 pos: primary,left model: Dell U2419H serial: <filter>
built: 2020 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 scale: 1
Monitor-2: HDMI-A-1 pos: right model: Dell U2419H serial: <filter>
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 6750 XT (RADV NAVI22) driver: mesa radv v: 24.0.6-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.6-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab28
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech PRO X Wireless Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 046d:0aba class-ID: 0300
API: ALSA v: k6.8.8-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.05 TiB used: 21.84 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 980 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 31.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 36.9 C
scheme: MBR
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
used: 21.84 GiB (9.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 31.29 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.6 C mobo: N/A gpu: amdgpu temp: 36.0 C
mem: 32.0 C
Memory: total: 32 GiB available: 31.29 GiB used: 2.44 GiB (7.8%)
Processes: 336 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.5 GiB services: upowerd Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1282 libs: 382 tools: pacseek,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: foot
inxi: 3.3.34
System install date: 2024-05-01
Last full system update: 2024-05-01 ↻
Hi! I changed the default browser to firefox developer edition, and removed firedragon, but now the default shortcut to open the browser(Meta + O
) no longer works.
Here is my ~/.config/hypr/hyprstart
file:
#!/bin/sh
cd ~
# user preferred settings
#cursor size
export XCURSOR_SIZE=24
# text editor
export MICRO_TRUECOLOR=1
export EDITOR=/usr/bin/micro
#browser
export BROWSER=firefoxdeveloperedition.desktop
#terminal
export TERM=foot
#mail
export MAIL=thunderbird
# check /usr/local/bin/hyprstart
This is what I get when I am checking what is the default browser:
$ sudo xdg-settings get default-web-browser
And finally here is what I have for my ~/.config/mimeapps.list
[Added Associations]
application/x-shellscript=code.desktop;
[Default Applications]
text/html=firefoxdeveloperedition.desktop
x-scheme-handler/http=firefoxdeveloperedition.desktop
x-scheme-handler/https=firefoxdeveloperedition.desktop
x-scheme-handler/about=firefoxdeveloperedition.desktop
x-scheme-handler/unknown=firefoxdeveloperedition.desktop
Still, no shortcut working…
What am I missing?
