I am newbie in this aera, I want to move from having Zen be default kernel in the grub list to the 6.12-lts kernel. I would like to not have to dive down into the menus to pick it. With the boot editor, I do not see a way for me to set this as a top level pick.
I need windows to be the first top level because my kids use my PC during the during the day for school and then the linux-lts to be second for when I am home. I would like to flip flop zen with lts.
╭─brett@I9 in ~
╰─λ garuda-inxi
Kernel: 6.13.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=c31be1c8-8b6d-4962-95cf-1bed6c6e8ce7 rw rootflags=subvol=@
rd.driver.pre=vfio-pci intel_iommu=on rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 vfio_pci.ids=10de:1c82,10de:0fb9
pcie_acs_override=downstream,multifunction video=efifb:off iommu=pt
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
wm: kwin_wayland tools: avail: hypridle,hyprlock vt: 1 dm: SDDM
Mobo: ASUSTeK model: TUF GAMING Z590-PLUS WIFI v: Rev 1.xx
UEFI: American Megatrends v: 1801 date: 12/26/2022
Info: model: 11th Gen Intel Core i9-11900KF bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x63
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB
Speed (MHz): avg: 800 min/max: 800/5100:5300 scaling: driver: intel_pstate
bogomips: 112128
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: Dell
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-2,DP-3,HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2504
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: vfio-pci v: N/A alternate: nouveau,nvidia_drm,nvidia
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 04:00.0 chip-ID: 10de:1c82 class-ID: 0300
Device-3: Adomax Nuroum C40
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7.4.2:15 chip-ID: 0627:a6bf
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7.4.3:16
d-rect: 6400x2520 display-ID: 0
Monitor-1: DP-2 pos: bottom-l model: HP 27es serial: <filter> built: 2016
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: DP-3 pos: top-center model: Gigabyte AORUS FI32Q
serial: <filter> built: 2021 res: mode: 2560x1440 hz: 120 scale: 100% (1)
dpi: 93 gamma: 1.2 size: 698x392mm (27.48x15.43") diag: 801mm (31.5")
Monitor-3: HDMI-A-1 pos: bottom-r model: HP 27es serial: <filter>
built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.86.16 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2504
wl: nwg-displays,wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
Device-3: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: vfio-pci alternate: snd_hda_intel pcie: speed: Unknown lanes: 63
link-max: gen: 3 speed: 8 GT/s bus-ID: 04:00.1 chip-ID: 10de:0fb9
Device-4: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 1-7.2:10 chip-ID: 1038:12ad class-ID: 0300
Device-5: GN Netcom Jabra Engage 75 driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7.4.1:14
chip-ID: 0b0e:1112 class-ID: 0300 serial: <filter>
Device-6: Adomax Nuroum C40
Device-7: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.13.3-zen1-1-zen status: kernel-api tools: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:13 chip-ID: 8087:0026
Local Storage: total: 9.48 TiB used: 605.33 GiB (6.2%)
ID-1: /dev/nvme0n1 maj-min: 259:11 model: PCIe SSD size: 931.51 GiB
tech: SSD serial: <filter> fw-rev: EHFM60.0 temp: 29.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 35.9 C
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 233010WD temp: 28.9 C scheme: MBR
ID-4: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: MBR
ID-5: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SDSSDH3 512G
tech: SSD serial: <filter> fw-rev: 1000 scheme: MBR
ID-7: /dev/sdd maj-min: 8:48 vendor: ASMedia model: T ASM236X NVME
size: 119.24 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
ID-8: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 860 EVO 500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 0301 scheme: GPT
ID-9: /dev/sdf maj-min: 8:80 vendor: Samsung model: SSD 860 EVO 500GB
ID-10: /dev/sdg maj-min: 8:96 vendor: Samsung model: SSD 860 EVO 500G
ID-11: /dev/sdh maj-min: 8:112 vendor: Samsung model: SSD 860 EVO 500G
ID-12: /dev/sdi maj-min: 8:128 model: SATA SSD size: 476.94 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 0301
ID-13: /dev/sdj maj-min: 8:144 model: External USB3.0 size: 223.57 GiB
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 0301
ID-14: /dev/sdk maj-min: 8:160 model: External USB3.0 size: 476.94 GiB
ID-15: /dev/sdl maj-min: 8:176 model: External USB3.0 size: 931.51 GiB
scheme: MBR
ID-16: /dev/sdm maj-min: 8:192 vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 0103 scheme: MBR
ID-17: /dev/sdn maj-min: 8:208 vendor: Samsung model: SSD 850 PRO 256GB
fw-rev: 0103 scheme: GPT
ID-1: / raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
used: 178.45 GiB (87.0%) fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:8
used: 44.9 MiB (46.8%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
ID-3: /home raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
ID-4: /var/log raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
ID-5: /var/tmp raw-size: 205.13 GiB size: 205.13 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.0 C mobo: 27.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1396 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 4041 fan-7: 0
Memory: total: 32 GiB note: est. available: 31.15 GiB used: 4.4 GiB (14.1%)
Processes: 444 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.39 GiB services: org_kde_powerdevil,
Packages: 1974 pm: pacman pkgs: 1967 libs: 503
tools: octopi,pacseek,pamac,paru,yay pm: flatpak pkgs: 7 Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date: 2024-11-23
Last full system update: 2025-02-22
